Salut à tous,
je viens d’installer squeeze 64 bit sur mon ordinateur portable.
J’ai installé gnome complet lors de l’installe, sous gnome-alsamixer je trouve le son jusqu’au fond, mais aucun son vlc, smplayer, totem.
Mais j’ai du son avec mes écouteurs brancher bien entendu sur mes écouteurs pas les haut-parleur du portable.
# alsactl init
Unknown hardware: "HDA-Intel" "Intel G45 DEVIBX" "HDA:10ec0270,103c1425,00100100 HDA:80862804,80860101,00100000" "0x103c" "0x1425"
Hardware is initialized using a guess method
# lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:1a.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05)
00:1d.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05)
02:00.0 Network controller: RaLink Device 5390
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation Core Processor Reserved (rev 02)
ff:02.3 Host bridge: Intel Corporation Core Processor Reserved (rev 02)
# lsmod
Module Size Used by
sco 7209 2
bridge 39630 0
stp 1440 1 bridge
bnep 9427 2
parport_pc 18855 0
ppdev 5030 0
rfcomm 29613 0
l2cap 24736 6 bnep,rfcomm
bluetooth 41827 6 sco,bnep,rfcomm,l2cap
lp 7462 0
parport 27954 3 parport_pc,ppdev,lp
acpi_cpufreq 5571 1
rfkill 13044 3 bluetooth
cpufreq_userspace 1992 0
cpufreq_stats 2659 0
cpufreq_powersave 902 0
cpufreq_conservative 5162 0
binfmt_misc 6431 1
uinput 6376 1
fuse 50892 3
loop 11799 0
snd_hda_codec_intelhdmi 10695 1
snd_hda_codec_realtek 235602 0
snd_hda_intel 20035 1
snd_hda_codec 54244 3 snd_hda_codec_intelhdmi,snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 5380 1 snd_hda_codec
i915 256168 2
joydev 8459 0
drm_kms_helper 20065 1 i915
snd_pcm 60503 2 snd_hda_intel,snd_hda_codec
drm 142359 3 i915,drm_kms_helper
snd_seq 42881 0
i2c_algo_bit 4225 1 i915
snd_timer 15582 2 snd_pcm,snd_seq
snd_seq_device 4493 1 snd_seq
uvcvideo 52063 0
wmi 4323 0
video 17445 1 i915
snd 46446 11 snd_hda_codec_intelhdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device
i2c_i801 7830 0
videodev 29993 1 uvcvideo
output 1692 1 video
soundcore 4598 1 snd
snd_page_alloc 6249 2 snd_hda_intel,snd_pcm
v4l1_compat 11442 2 uvcvideo,videodev
v4l2_compat_ioctl32 8474 1 videodev
i2c_core 15819 6 i915,drm_kms_helper,drm,i2c_algo_bit,i2c_i801,videodev
evdev 7352 15
battery 4998 0
button 4650 1 i915
ac 2192 0
psmouse 49937 0
processor 29935 5 acpi_cpufreq
pcspkr 1699 0
serio_raw 3752 0
ext4 289033 1
mbcache 5050 1 ext4
jbd2 67015 1 ext4
crc16 1319 2 l2cap,ext4
sg 18744 0
sr_mod 12602 0
sd_mod 29921 3
cdrom 29415 1 sr_mod
crc_t10dif 1276 1 sd_mod
ahci 32374 2
libata 133632 1 ahci
scsi_mod 122149 4 sg,sr_mod,sd_mod,libata
ehci_hcd 32081 0
thermal 11674 0
r8169 29263 0
thermal_sys 11942 3 video,processor,thermal
mii 3210 1 r8169
usbcore 122386 3 uvcvideo,ehci_hcd
nls_base 6377 1 usbcore
