Pas de sond sur presario CQ56 squeeze
bon alsamixer ce lance pas de MM sont monter a fond.
apré recherche j’ai rajouter GRUB_CMDLINE_LINUX=“irqpoll” dans /etc/default/grub
puis fait update-grub
sa a rien changer je c’est plus trops quoi faire?
lspci | grep -i audio 00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
[code]cat /etc/modprobe.d/alsa-base.conf
autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-ioctl32 ; /sbin/modprobe --quiet snd-seq ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modprobe --quiet snd-seq-midi ; : ; }
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && { /sbin/modprobe --quiet snd-emu10k1-synth ; : ; }
Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
Keep snd-pcsp from beeing loaded as first soundcard
options snd-pcsp index=-2
Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-2
ligne rajouter mais aucun resulta
options snd-hda-intel enable_msi=1[/code]
lsmod | grep snd snd_hda_codec_realtek 235618 0 snd_hda_intel 20035 1 snd_hda_codec 54244 2 snd_hda_codec_realtek,snd_hda_intel snd_hwdep 5380 1 snd_hda_codec snd_pcm 60487 2 snd_hda_intel,snd_hda_codec snd_seq 42881 0 snd_timer 15598 2 snd_pcm,snd_seq snd_seq_device 4493 1 snd_seq snd 46526 10 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device soundcore 4598 1 snd snd_page_alloc 6249 2 snd_hda_intel,snd_pcm
j’ai en fin trouver la solution.
j’ai du recompiler les modules alsa:
je mais tous ce d’on je me souviens en espérant ne pas en oublier .
apt-get install alsa-source apt-get remove alsa-source m-a a-i alsa-source alsa force-reload
mes sources:
http://forums.debian.net/viewtopic.php?f=7&t=69198#p405928
https://help.ubuntu.com/community/HdaIntelSoundHowto
