voivi mon pb:
je ne comprends pas comment resoudre ce pb?
apt-get -f install
1 partiellement installés ou enlevés.
Après cette opération, 0 o d’espace disque supplémentaires seront utilisés.
Paramétrage de initscripts (2.88dsf-13.1) …
insserv: warning: script ‘K07smfpd’ missing LSB tags and overrides
insserv: warning: script ‘smfpd’ missing LSB tags and overrides
insserv: There is a loop at service stop-bootlogd if started
insserv: There is a loop between service stop-bootlogd and mountnfs if started
insserv: loop involving service mountnfs at depth 6
insserv: loop involving service nfs-common at depth 5
insserv: There is a loop between service stop-bootlogd and checkroot if started
insserv: loop involving service checkroot at depth 3
insserv: loop involving service keyboard-setup at depth 2
insserv: loop involving service hwclock at depth 6
insserv: loop involving service hostname at depth 4
insserv: loop involving service alsa-utils at depth 10
insserv: Starting smfpd depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: Starting smfpd depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting smfpd depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: Max recursions depth 99 reached insserv: loop involving service portmap at depth 9 insserv: loop involving service fail2ban at depth 13 insserv: There is a loop between service stop-bootlogd and ifupdown if started insserv: loop involving service ifupdown at depth 8 insserv: loop involving service ifupdown-clean at depth 7 insserv: loop involving service module-init-tools at depth 7 insserv: There is a loop between service stop-bootlogd and mountall if started insserv: loop involving service mountall at depth 9 insserv: loop involving service checkfs at depth 8 insserv: loop involving service mtab at depth 7 insserv: There is a loop between service stop-bootlogd and udev if started insserv: loop involving service udev at depth 1 insserv: There is a loop at service smfpd if started insserv: Starting smfpd depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insseconfigured to not write apport reports
insserv: loop involving service gdm at depth 14
insserv: There is a loop between service stop-bootlogd and ifupdown-clean if started
insserv: loop involving service mountdevsubfs at depth 3
insserv: loop involving service mountkernfs at depth 1
insserv: loop involving service rsyslog at depth 14
insserv: loop involving service networking at depth 11
insserv: There is a loop between service stop-bootlogd and mountall-bootclean if started
insserv: loop involving service mountall-bootclean at depth 1
insserv: Starting smfpd depends on stop-bootlogd and therefore on system facility `$all’ which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg : erreur de traitement de initscripts (–configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d’état 1
initscripts
Merci de votre aide
