J’ai actuellement un serveur dédié chez ovh, sur lequel j’ai installé proxmox et shorewall. Je veux mettre deux noms de domaine pour accèder à ce serveur.
Mais pour l’instant, mes noms de domaines ne fonctionnement pas.
Voici mes fichiers de config :
named.conf.local
// Do any local configuration here
// Consider adding the 1918 zones here, if they are not used in your
// organization
//include "/etc/bind/zones.rfc1918";
zone "lmb1.net" {
type master;
file "/etc/bind/zones/db.lmb1.net";
allow-transfer
213.251.188.140;
notify yes;
zone "lmb2.net" {
type master;
file "/etc/bind/zones/db.lmb2.net";
allow-transfer
213.251.188.140;
notify yes;
named.conf.options
options {
directory "/var/cache/bind";
// If there is a firewall between you and nameservers you want
// to talk to, you might need to uncomment the query-source
// directive below. Previous versions of BIND always asked
// questions using port 53, but BIND 8.1 and later use an unprivileged
// port by default.
query-source address * port 53;
// If your ISP provided one or more IP addresses for stable
// nameservers, you probably want to use them as forwarders.
// Uncomment the following block, and insert the addresses replacing
// the all-0's placeholder.
// forwarders {
// 0.0.0.0;
auth-nxdomain no; # conform to RFC1035
listen-on-v6 { any; };
listen-on { any; };
allow-query { any; };
allow-recursion { any; };
[code]$TTL 604800
lmb1.net IN SOA ns359956.ovh.net. postmaster.lmb1.net. (
2009082801 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
604800 ) ; Minimum
IN NS ns359956.ovh.net.
IN NS sdns1.ovh.net.
IN MX 10 mail.lmb1.net
www IN A 91.121.160.149
mail IN A 91.121.160.149
pop IN A 91.121.160.149
smtp IN A 91.121.160.149
imap IN A 91.121.160.149
sql IN A 91.121.160.149
ftp IN A 91.121.160.149
IN A 91.121.160.149
[code]$TTL 604800
lmb2.net IN SOA ns359956.ovh.net. postmaster.lmb2.net. (
2009082801 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
604800 ) ; Minimum
IN MX 10 mail.lmb2.net
IN A 91.121.160.149
shorewall/rules
#ACTION SOURCE DEST PROTO DEST SOURCE ORIGINAL RATE
# Permit access to SSH
SSH/ACCEPT net fw - - - - 6/min:5
# Permit access to Proxmox Manager and Console
ACCEPT net fw tcp 53,80,443,953,5900
ACCEPT net fw udp domain
#ACCEPT fw net tcp 53,953
#ACCEPT fw net udp domain
# DNS Rules
DNS/ACCEPT all all
# PING Rules
Ping/ACCEPT all all
#vz-demo
DNAT net dmz:10.0.1.101:80 tcp 8001 - 91.121.160.149
DNAT net dmz:10.0.1.101:22 tcp 22101 - 91.121.160.149
#vz-mail
DNAT net dmz:10.0.1.102:22 tcp 22102 - 91.121.160.149
DNAT net dmz:10.0.1.102:80 tcp 8002 - 91.121.160.149
#vz-mysql (for lm)
DNAT net dmz:10.0.1.103:22 tcp 22103 - 91.121.160.149
DNAT net dmz:10.0.1.103:80 tcp 8003 - 91.121.160.149
#vz-lm
DNAT net dmz:10.0.1.104:80 tcp 8004 - 91.121.160.149
DNAT net dmz:10.0.1.104:22 tcp 22104 - 91.121.160.149
DNAT net dmz:10.0.1.104:21 tcp 21104 - 91.121.160.149
#vz-discount
DNAT net dmz:10.0.1.105:80 tcp 8005 - 91.121.160.149
DNAT net dmz:10.0.1.105:22 tcp 22105 - 91.121.160.149
#vz-pro
DNAT net dmz:10.0.1.106:80 tcp 8006 - 91.121.160.149
DNAT net dmz:10.0.1.106:22 tcp 22106 - 91.121.160.149
#vz-pme
DNAT net dmz:10.0.1.107:80 tcp 8007 - 91.121.160.149
DNAT net dmz:10.0.1.107:22 tcp 22107 - 91.121.160.149
#vz-sqldiscount
DNAT net dmz:10.0.1.108:22 tcp 22108 - 91.121.160.149
DNAT net dmz:10.0.1.108:80 tcp 8008 - 91.121.160.149
#vz-sqlpro
DNAT net dmz:10.0.1.109:22 tcp 22109 - 91.121.160.149
DNAT net dmz:10.0.1.109:80 tcp 8009 - 91.121.160.149
#vz-sqlpme
DNAT net dmz:10.0.1.110:22 tcp 22110 - 91.121.160.149
DNAT net dmz:10.0.1.110:80 tcp 8010 - 91.121.160.149
Donc, si quelqu’un a une idée, je suis preneur.
Merci d’avance.
