voici mon syslog, est mes erreur suite à postfix.
Quelqu’un de vous arrait-il un tuto sur le paramétrage de postifx avec webmail en serveur local et externe pour envoie de mail.
D’avance Merci
May 20 15:52:24 vmdebian postfix/postfix-script: stopping the Postfix mail system
May 20 15:52:24 vmdebian postfix/master[2432]: terminating on signal 15
May 20 15:52:26 vmdebian postfix/postqueue[3816]: warning: Mail system is down – accessing queue directly
May 20 15:52:30 vmdebian postfix/postfix-script: starting the Postfix mail system
May 20 15:52:30 vmdebian postfix/master[3886]: daemon started – version 2.3.8, configuration /etc/postfix
May 20 15:52:31 vmdebian postfix/cleanup[3889]: fatal: open /etc/postfix/mysql-virtual_aliases.cf: No such file or directory
May 20 15:52:32 vmdebian postfix/master[3886]: warning: process /usr/lib/postfix/cleanup pid 3889 exit status 1
May 20 15:52:32 vmdebian postfix/master[3886]: warning: /usr/lib/postfix/cleanup: bad command startup – throttling
