Pb avec xterminal!
bonjour,
j’ai installé un serveur linux debian ,et je voulais avoirle choix entre le mode graphique et le mode Konsole au démarrage j’ai installé xserver-xfree86
j’ai églement installé les gestionaire de fênetre kde et gnome, cependant quand je lance startx (avec mon user (qui n’est pas root)), j’ai le message suivant:
fatal server error:
no screens found
when reporting a problem related to a server crash , please send the full server output, not just last messages.
this can be found in the file “/var/log/XFree86.0.log”.
please report problems to submit@bugs.debian.org.
XI0: fatal I0 error 104 (connection reset by peer) on X server" :0.0"
after 0 request (0known processed) with 0events remaining.
et voici la config du fichier se trouvant ds : /etc/X11/XF86config-4
XF86Config-4 (XFree86 X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
This file is automatically updated on xserver-xfree86 package upgrades only
if it has not been modified since the last upgrade of the xserver-xfree86
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
dpkg-reconfigure xserver-xfree86
Section “Files”
FontPath “unix/:7100” # local font server
if the local font server has problems, we can fall back on these
FontPath “/usr/lib/X11/fonts/misc”
FontPath “/usr/lib/X11/fonts/cyrillic”
FontPath “/usr/lib/X11/fonts/100dpi/:unscaled”
FontPath “/usr/lib/X11/fonts/75dpi/:unscaled”
FontPath “/usr/lib/X11/fonts/Type1”
FontPath “/usr/lib/X11/fonts/CID”
FontPath “/usr/lib/X11/fonts/Speedo”
FontPath “/usr/lib/X11/fonts/100dpi”
FontPath “/usr/lib/X11/fonts/75dpi”
EndSection
Section “Module”
Load “GLcore”
Load “bitmap”
Load “dbe”
Load “ddc”
Load “dri”
Load “extmod”
Load “freetype”
Load “glx”
Load “int10”
Load “record”
Load “speedo”
Load “type1”
Load “vbe”
EndSection
Section “InputDevice”
Identifier “Generic Keyboard”
Driver “keyboard”
Option “CoreKeyboard”
Option “XkbRules” “xfree86”
Option “XkbModel” “pc105”
Option “XkbLayout” “fr”
EndSection
Identifier “Configured Mouse”
Driver “mouse”
Option “CorePointer”
Option “Device” “/dev/input/mice”
Option “Protocol” “ImPS/2”
Option “ZAxisMapping” “4 5”
EndSection
Section “Device”
Identifier “Intel Corporation 82865G Integrated Graphics Device (rev 02)”
Driver “ati”
BusID “PCI:0:02:0”
EndSection
Section “Monitor”
Identifier “HYUNDAI imagequest QV770”
HorizSync 30-70
VertRefresh 50-160
Option “DPMS”
EndSection
Section “Screen”
Identifier “Default Screen”
Device “Intel Corporation 82865G Integrated Graphics Device (rev 02)”
Monitor “HYUNDAI imagequest QV770”
DefaultDepth 24
SubSection “Display”
Depth 1
Modes “800x600” “640x480”
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section “ServerLayout”
Identifier “Default Layout”
Screen “Default Screen”
InputDevice “Generic Keyboard”
InputDevice “Configured Mouse”
EndSection
Section “DRI”
Mode 0666
EndSection
merci de m’aider
Il faut souvent rebooter pour que udev reconnaisse bien l’écran avec la bonne configuration de xfree86.
Sinon essayer de reconfigurer xfree86 pour être certain qu’il n’y ait pas de problème avec la carte en mettant le pilote vesa (pas le top mais passe-partout). Pour cela, en console, taper :[quote]su
mot_de_passe_root
dpkg-reconfigure xserver-xfree86[/quote] Bon courage !
