Voilà, j’ai fait ce qu’il y a sur wiki.debian.org/fr/Xorg
# Xorg -configure
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32.29-dsa-ia32 i686 Debian
Current Operating System: Linux Serveur 2.6.32-5-686 #1 SMP Thu Nov 3 04:23:54 UTC 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=504d208a-40b8-4a9c-a0e0-2e045b60ce9e ro quiet
Build Date: 19 February 2011 02:37:36PM
xorg-server 2:1.7.7-13 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 24 15:44:21 2011
List of video drivers:
savage
openchrome
ati
r128
radeon
siliconmotion
voodoo
geode
nv
ark
tseng
neomagic
tdfx
ztv
s3virge
i128
mach64
i740
mga
cirrus
rendition
vmwlegacy
s3
sis
vesa
sisusb
trident
nouveau
intel
vmware
chips
apm
fbdev
vmware: Please ignore above "FATAL: Module vmwgfx not found."
(++) Using config file: "/root/xorg.conf.new"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Xorg detected your mouse at device /dev/input/mice.
Please check your config if the mouse is still not
operational, as by default Xorg tries to autodetect
the protocol.
Your xorg.conf file is /root/xorg.conf.new
To test the server, run 'X -config /root/xorg.conf.new'
et donc je teste le serveur avec la commande donnée et ça me donne :
# X -config /root/xorg.conf.new
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 24 15:48:15 2011
invalid frequency 20.000 Mhz [freq >= 21.250 Mhz]
SELinux: Disabled on system, not enabling in X server
et rien ne se passe…
Au fait, merci de ton aide marcastro
