Pb compiz sous squeeze
je n’arrive pas à activer compiz sous squeeze.
j’ai essayé ça : http://www.debian-fr.org/compiz-refuse-de-demarer-sous-sqeeze-neuve-t32075.html
~$ lspci|grep VGA 01:00.0 VGA compatible controller: ATI Technologies Inc RV770 LE [Radeon HD 4800 Series]
~$ lsmod | grep radeon radeon 511752 2 ttm 33494 1 radeon drm_kms_helper 18309 1 radeon drm 112088 5 radeon,ttm,drm_kms_helper i2c_algo_bit 3497 1 radeon i2c_core 12787 5 radeon,drm_kms_helper,i2c_i801,drm,i2c_algo_bit
~$ grep -i match /var/log/Xorg.0.log (==) Matched ati as autoconfigured driver 0 (==) Matched vesa as autoconfigured driver 1 (==) Matched fbdev as autoconfigured driver 2
~$ cat /var/log/Xorg.0.log | grep -i aiglx (==) AIGLX enabled (II) AIGLX: Screen 0 is not DRI2 capable (II) AIGLX: enabled GLX_MESA_copy_sub_buffer (II) AIGLX: enabled GLX_SGI_make_current_read (II) AIGLX: enabled GLX_texture_from_pixmap with driver support (II) AIGLX: Loaded and initialized /usr/lib/dri/r600_dri.so
~$ grep EXA /var/log/Xorg.0.log (==) RADEON(0): Will attempt to use R6xx/R7xx EXA support if DRI is enabled. (II) RADEON(0): Setting EXA maxPitchBytes (II) EXA(0): Offscreen pixmap area of 116867072 bytes (II) EXA(0): Driver registered support for the following operations:
~$ glxgears IRQ's not enabled, falling back to busy waits: 2 0 15725 frames in 5.0 seconds = 3144.818 FPS 15790 frames in 5.0 seconds = 3157.970 FPS 15783 frames in 5.0 seconds = 3156.452 FPS XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0" after 159577 requests (152084 known processed) with 0 events remaining.
est ce que qq peut m’aider ?? Merci.
bonjour,
peux-tu poster ton xorg.conf s’il te plait…
as-tu installer compiz,comme il faut?
une explication clair de ce que tu as deja fait serait la bienvenue
je déterre le post: j’ai aussi un souci avec compiz, histoire de bien utiliser mes ressources :067
la gars n’a pas posté le xorg.conf puisque visiblement squeeze configure tout ça de lui même sans ce beau fichier de conf.
Le souci c’est que du coup comment on fait pour activer compiz?
Bon j’ai pas encore trop gratter les forums, si quelqu’un à un truc tout prêt , qu’il n’hésite pas… :eusa-whistle:
01:05.0 VGA compatible controller: ATI Technologies Inc Radeon HD 3200 Graphics
Il te faut d’abord avoir l’affichage 3D, et pour cela installer le pilote vidéo adéquat. Vois le wiki pour ça.
