Bonjour à tous.
debian-said:/home/said# lspci
00:00.0 RAM memory: nVidia Corporation MCP67 Memory Controller (rev a2)
00:01.0 ISA bridge: nVidia Corporation MCP67 ISA Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP67 SMBus (rev a2)
00:01.2 RAM memory: nVidia Corporation MCP67 Memory Controller (rev a2)
00:01.3 Co-processor: nVidia Corporation MCP67 Co-processor (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:04.0 USB Controller: nVidia Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:04.1 USB Controller: nVidia Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:06.0 IDE interface: nVidia Corporation MCP67 IDE Controller (rev a1)
00:07.0 Audio device: nVidia Corporation MCP67 High Definition Audio (rev a1)
00:08.0 PCI bridge: nVidia Corporation MCP67 PCI Bridge (rev a2)
00:09.0 IDE interface: nVidia Corporation MCP67 AHCI Controller (rev a2)
00:0a.0 Ethernet controller: nVidia Corporation MCP67 Ethernet (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP67 PCI Express Bridge (rev a2)
00:0d.0 PCI bridge: nVidia Corporation MCP67 PCI Express Bridge (rev a2)
00:12.0 VGA compatible controller: nVidia Corporation GeForce 7000M (rev a2) (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:04.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
01:04.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
01:04.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12)
01:04.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 12)
05:00.0 Ethernet controller: Atheros Communications Inc. AR242x 802.11abg Wireless PCI Express Adapter (rev 01)
Voila mon problème est que je ne peux pas modifier la résolution de mon écran. Je débute sous linux et je ne comprend pas trop les manipulation a effectué je pense qu’il faut installer le pilote de ma carte graphique si qqn pouvait m’aider. Merci d’avance
debian-said:/home/said# uname -r
2.6.26-2-686
