Pb de connexion réseau. Host unreachable
Désolé, j’étais occupé. Je viens de voir ton message. Voila le résultat de la commande, c’est un peu long et c’est de l’hébreu pour moi
lspci -vv
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
	Subsystem: Hewlett-Packard Company Core Processor DMI
	Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
	Capabilities: <access denied>
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 16
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00002000-00002fff
	Memory behind bridge: de900000-deffffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity+ SERR+ NoISA+ VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Kernel driver in use: pcieport
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) (prog-if 20 [EHCI])
	Subsystem: Hewlett-Packard Company 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Region 0: Memory at df401800 (32-bit, non-prefetchable) [size=1K]
	Kernel driver in use: ehci-pci
	Kernel modules: ehci_pci
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) (prog-if 00 [Normal decode])
	Physical Slot: 1
	Interrupt: pin A routed to IRQ 17
	Bus: primary=00, secondary=10, subordinate=10, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: df000000-df0fffff
	Prefetchable memory behind bridge: 00000000c0000000-00000000c01fffff
	BridgeCtl: Parity- SERR+ NoISA+ VGA- MAbort- >Reset- FastB2B-
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05) (prog-if 00 [Normal decode])
	Physical Slot: 1
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin B routed to IRQ 16
	Bus: primary=00, secondary=1a, subordinate=1a, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: c0200000-c03fffff
	Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 05) (prog-if 00 [Normal decode])
	Physical Slot: 1
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin C routed to IRQ 18
	Bus: primary=00, secondary=1c, subordinate=1c, sec-latency=0
	I/O behind bridge: 00005000-00005fff
	Memory behind bridge: de000000-de8fffff
	Prefetchable memory behind bridge: 00000000dd000000-00000000ddffffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 05) (prog-if 00 [Normal decode])
	Physical Slot: 1
	Interrupt: pin D routed to IRQ 19
	Bus: primary=00, secondary=1e, subordinate=1e, sec-latency=0
	I/O behind bridge: 00006000-00006fff
	Memory behind bridge: df100000-df1fffff
	Prefetchable memory behind bridge: 00000000c0600000-00000000c07fffff
	BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 05) (prog-if 00 [Normal decode])
	Physical Slot: 1
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Bus: primary=00, secondary=20, subordinate=20, sec-latency=0
	I/O behind bridge: 00007000-00007fff
	Memory behind bridge: c0800000-c09fffff
	Prefetchable memory behind bridge: 00000000c0a00000-00000000c0bfffff
	BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) (prog-if 20 [EHCI])
	Latency: 0
	Interrupt: pin A routed to IRQ 23
	Region 0: Memory at df401c00 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
	Latency: 0
	Bus: primary=00, secondary=30, subordinate=30, sec-latency=32
	Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:1f.0 ISA bridge: Intel Corporation 3420 Chipset LPC Interface Controller (rev 05)
	Subsystem: Hewlett-Packard Company 3420 Chipset LPC Interface Controller
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller (rev 05) (prog-if 8f [PCI native mode controller, supports both channels switched to ISA compatibility mode, supports bus mastering])
	Subsystem: Hewlett-Packard Company 5 Series/3400 Series Chipset 4 port SATA IDE Controller
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Region 0: I/O ports at 1830 [size=8]
	Region 1: I/O ports at 1824 [size=4]
	Region 2: I/O ports at 1828 [size=8]
	Region 3: I/O ports at 1820 [size=4]
	Region 4: I/O ports at 1810 [size=16]
	Region 5: I/O ports at 1800 [size=16]
	Kernel driver in use: ata_piix
	Kernel modules: ata_piix, ata_generic
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
	Subsystem: Hewlett-Packard Company 5 Series/3400 Series Chipset SMBus Controller
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Region 0: Memory at df402000 (64-bit, non-prefetchable) [size=256]
	Region 4: I/O ports at 1840 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller (rev 05) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
	Subsystem: Hewlett-Packard Company 5 Series/3400 Series Chipset 2 port SATA IDE Controller
	Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0
	Interrupt: pin B routed to IRQ 17
	Region 0: I/O ports at 1888 [size=8]
	Region 1: I/O ports at 183c [size=4]
	Region 2: I/O ports at 1880 [size=8]
	Region 3: I/O ports at 1838 [size=4]
	Region 4: I/O ports at 1870 [size=16]
	Region 5: I/O ports at 1860 [size=16]
01:00.0 RAID bus controller: Hewlett-Packard Company Smart Array G6 controllers (rev 01)
	Subsystem: Hewlett-Packard Company Smart Array P212
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
	Region 0: Memory at dec00000 (64-bit, non-prefetchable) [size=4M]
	Region 2: Memory at de900000 (64-bit, non-prefetchable) [size=4K]
	Region 4: I/O ports at 2000 [size=256]
	[virtual] Expansion ROM at de980000 [disabled] [size=512K]
	Kernel driver in use: hpsa
	Kernel modules: hpsa
10:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
	Subsystem: Intel Corporation Gigabit CT Desktop Adapter
	Latency: 0, Cache Line Size: 64 bytes
	Region 0: Memory at df080000 (32-bit, non-prefetchable) [size=128K]
	Region 1: Memory at df000000 (32-bit, non-prefetchable) [size=512K]
	Region 2: I/O ports at 3000 [size=32]
	Region 3: Memory at df0a0000 (32-bit, non-prefetchable) [size=16K]
	[virtual] Expansion ROM at df0c0000 [disabled] [size=256K]
	Kernel driver in use: e1000e
	Kernel modules: e1000e
1c:00.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200e [Pilot] ServerEngines (SEP1) (rev 02) (prog-if 00 [VGA controller])
	Subsystem: Hewlett-Packard Company ProLiant DL140 G3
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 18
	Region 0: Memory at dd000000 (32-bit, prefetchable) [size=16M]
	Region 1: Memory at de800000 (32-bit, non-prefetchable) [size=16K]
	Region 2: Memory at de000000 (32-bit, non-prefetchable) [size=8M]
	[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
	Kernel driver in use: mgag200
	Kernel modules: mgag200
1e:00.0 Ethernet controller: Broadcom Limited NetXtreme BCM5723 Gigabit Ethernet PCIe (rev 10)
	Subsystem: Hewlett-Packard Company NC107i Integrated PCI Express Gigabit Server Adapter
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
	Interrupt: pin A routed to IRQ 19
	Region 0: Memory at df100000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: tg3
	Kernel modules: tg3
Bon courage
pas tout lu
mais as-tu tenté de mettre autrechose que 192.168.1.20 ? Peut être cette adresse est déjà prise?
Tu as essayé en dhcp pour voir?
Non je n’ai pas essayé en DHCP. Comme il s’agit de mon serveur sur lequel je pense faire de l’auto hébergement, il me faut une IP fixe. Elle est programmée au niveau de ma box fibre. J’ai défini avant de commencer un plan d’adressage afin de mettre tous mes appareils connectés en IP fixe. Et c’est bien le seul avec cette adresse.
par ailleurs,comme ça fonctionne parfaitementaavec mma nnouvelle carte réseau, ça ne vient pas de l’adresse.JJe ppencherai plutôtppour un pproblème de firmware pour le chipset Broadcom NetXtreme
Ce qui est intéressant est de se rendre compte que sur certains serveurs, relativement peu, selon la liste « Linux Hardware », la carte est correctement détectée, mais ne fonctionne pas. (cf, le bas de page).
Le pilote ‹ tg3 › en tout cas semble être le bon.
En tout cas, avec la nouvelle carte réseau de marque Intel, - ce dont je ne suis pas étonné, vu l’excellent support multi-os - tu as contourné le problème et ton serveur est maintenant joignable. :smiley:
Juste un petit souci. Je cherche comment mettre le sujet résolu, mais je ne trouve rien. Suffit-il de cocher Solution dans ton post?
Oui.
Ça n’a rien à voir avec DHCP. DHCP n’est pas un adressage dynamique mais une configuration dynamique. En clair, en DHCP ton IP peut tout à fait être fixe.
DHCP ça signifie Dynamic Host Configuration Protocol. Ce qui rend l’adresse IP variable, c’est la façon de configurer le serveur DHCP et le client DHCP uniquement.
D’ailleurs quand tu achête une IP fixe chez ton FAI, celle-ci n’est en général pas configurée à la main dans ta box :wink:
