Alors j’ai essayé vos conseils;
Pour le MD5 c’etait bien vu, mais je viens de vérifier et le CD est ok.
(et puis je me trompe peut être mais en netinstall, les fichiers sont téléchargés sur les miroirs non?)
bref c’est pas ça.
pour l’arret,
- la commande “#halt” en tty1 j’ai donné le résultat plus haut.
- pour “#shutdown -h now” on obtient la même chose si ce n’est que cette fois c’est le CPU#0 qui est “stuck for 61s” et non plus le #7.
- pour “#shutdown -r now” c’est pareil
la commande “#dmesg | grep acpi” donne
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x10] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x12] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x14] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x16] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x11] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x12] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x13] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x14] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x15] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x16] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x17] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x18] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x19] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1a] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1b] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1c] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1d] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1e] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1f] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x20] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 1.142889] ACPI: Please send DMI info above to linux-acpi@vger.kernel.org
[ 1.142890] ACPI: If "acpi_osi=Linux" works better, please notify linux-acpi@vger.kernel.org
que je ne sais pas trop interpreter… ya du enabled et aussi du disabled mais pour [0x00]…
acpid etait déjà installé.
ainsi que:
#cat /var/log/gdm/:0.log
[code]cat /var/log/gdm/:0.log
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny2)
Current Operating System: Linux robin 2.6.26-2-amd64 #1 SMP Thu Nov 5 02:23:12 UTC 2009 x86_64
Build Date: 11 June 2009 09:45:25AM
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Wed Nov 25 10:32:14 2009
(==) Using config file: “/etc/X11/xorg.conf”
(II) Module “ddc” already built-in
expected keysym, got circumflex: line 257 of fr
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Warning: Duplicate shape name ""
Using last definition
Error: Section defined without a name
Definition ignored
Definition ignored
Definition ignored
Definition ignored
Warning: Multiple doodads named ""
Using first definition
(EE) Error compiling keymap (server-0)
(EE) XKB: Couldn’t compile keymap
SetClientVersion: 0 9
SetKbdSettings - type: 0 rate: 30 delay: 500 snumlk: 0
ici il y a des erreurs et des warnings mais idem je ne sais pas les interpreter.
en tout cas merci de votre aide
