Bonjour à tous
Voila, j’aimerais pouvoir brancher mon ordinateur portable sur ma télé pour regarder des films en duppliquant l’écran principal. Je sais qu’il faut modicier le fichier xorg.conf mais je n’ai aucune idée de comment. Merci d’avance pour votre aide. Voila mon fichier xorg.conf
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "nVidia Corporation GeForce 7000M"
Driver "nvidia"
Option “XAANoOffscreenPixmaps” "true"
Option “AllowGLXWithComposite” "true"
Option “TripleBuffer” "true"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Option “AddARGBGLXVisuals” "true"
DefaultDepth 24
EndSection
Section "Extensions"
Option “Composite” "Enable"
EndSection[/code]
