Pb : enter runlevel / no more process left
J’ai du bidouiller quelque chose qu’il ne fallait pas sur la lenny de mon portable, il ne veut plus demarrer.
Il se bloque sur une ligne “enter runlevel”, si je tape 1 par exemple il met “no more process left”
Y aurait-il une methode pour recuperer le systeme a votrea vis ??
Keb
Tu n’aurais pas bidouillé /etc/inittab ?
Tu as essayé de démarrer en runlevel 2 ou 3 aussi, à tous hasards ?
En démarrant ta machine avec un livecd, tu devrais vérifier que l’inittab ressemble à:
[quote]# /etc/inittab: init(8) configuration.
$Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
The default runlevel.
Boot-time system configuration/initialization script.
This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
What to do in single-user mode.
~~:S:wait:/sbin/sulogin
/etc/init.d executes the S and K scripts upon change
of runlevel.
Runlevel 0 is halt.
Runlevel 1 is single-user.
Runlevels 2-5 are multi-user.
Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo “Keyboard Request–edit /etc/inittab to let this work.”
What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
/sbin/getty invocations for the runlevels.
The “id” field MUST be the same as the last
characters of the device (after “tty”).
Format:
Note that on most Debian systems tty7 is used by the X Window System,
so if you want to add more getty’s go ahead but skip tty7 if you run X.
1:2345:respawn:/sbin/getty 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
Example how to put a getty on a serial line (for a terminal)
#T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
Runlevel 2 ou 3 ca donne rien.
J’ai demarrer en mode console et apparement inittab est vide !!!
remets celui que je t’ai donné.
