VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 204k freed
vesafb: probe of vesafb0 failed with error -6
ACPI: Processor [CPU0] (supports C1 C2 C3, 8 throttling states)
ACPI: Thermal Zone [THRM] (53 C)
ACPI: Fan [FAN0] (off)
ACPI: Fan [FAN1] (off)
NET: Registered protocol family 1
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH4: IDE controller at PCI slot 0000:00:1f.1
PCI: Enabling device 0000:00:1f.1 (0005 -> 0007)
ACPI: PCI interrupt 0000:00:1f.1[A] -> GSI 6 (level, low) -> IRQ 6
ICH4: chipset revision 3
ICH4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x1860-0x1867, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0x1868-0x186f, BIOS settings: hdc:DMA, hdd:pio
hda: TOSHIBA MK6025GAS, ATA DISK drive
Using anticipatory io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 128KiB
hda: 117210240 sectors (60011 MB), CHS=65535/16/63, UDMA(100)
/dev/ide/host0/bus0/target0/lun0: p1 p2 p3
hdc: PIONEER DVD-RW DVR-K14RA, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: hda2: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 1455454
EXT3-fs: hda2: 1 orphan inode deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Adding 979956k swap on /dev/hda3. Priority:-1 extents:1
EXT3 FS on hda2, internal journal
Synaptics Touchpad, model: 1
Firmware: 5.9
Sensor: 18
new absolute packet format
Touchpad has extended capability bits
-> 4 multi-buttons, i.e. besides standard buttons
-> multifinger detection
-> palm detection
input: SynPS/2 Synaptics TouchPad on isa0060/serio4
mice: PS/2 mouse device common for all mice
hdc: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ts: Compaq touchscreen protocol output
lp: driver loaded but no devices found
Capability LSM initialized
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
cdrom: open failed.
EXT3 FS on hda1, internal journal
Real Time Clock Driver v1.12
input: PC Speaker
Linux agpgart interface v0.100 © Dave Jones
agpgart: Detected an Intel 855GM Chipset.
agpgart: Maximum main memory to use for agp memory: 438M
agpgart: AGP aperture is 256M @ 0xe0000000
cpci_hotplug: CompactPCI Hot Plug Core version: 0.2
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
shpchp: shpc_init : shpc_cap_offset == 0
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.2
ACPI: PCI interrupt 0000:00:1d.0[A] -> GSI 6 (level, low) -> IRQ 6
uhci_hcd 0000:00:1d.0: Intel Corp. 82801DB (ICH4) USB UHCI #1
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: irq 6, io base 00001800
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI interrupt 0000:00:1d.1[B] -> GSI 6 (level, low) -> IRQ 6
uhci_hcd 0000:00:1d.1: Intel Corp. 82801DB (ICH4) USB UHCI #2
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: irq 6, io base 00001820
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI interrupt 0000:00:1d.2[C] -> GSI 6 (level, low) -> IRQ 6
uhci_hcd 0000:00:1d.2: Intel Corp. 82801DB (ICH4) USB UHCI #3
hub 1-0:1.0: over-current change on port 1
hub 1-0:1.0: over-current change on port 2
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: irq 6, io base 00001840
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI interrupt 0000:00:1d.7[D] -> GSI 10 (level, low) -> IRQ 10
ehci_hcd 0000:00:1d.7: Intel Corp. 82801DB (ICH4) USB2 EHCI Controller
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: irq 10, pci mem e09fb000
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
ehci_hcd 0000:00:1d.7: fatal error
ehci_hcd 0000:00:1d.7: HC died; cleaning up
hw_random: cannot enable RNG, aborting
ACPI: PCI interrupt 0000:00:1f.5[B] -> GSI 10 (level, low) -> IRQ 10
PCI: Setting latency timer of device 0000:00:1f.5 to 64
intel8x0_measure_ac97_clock: measured 49586 usecs
intel8x0: clocking to 48000
ACPI: PCI interrupt 0000:00:1f.6[B] -> GSI 10 (level, low) -> IRQ 10
PCI: Setting latency timer of device 0000:00:1f.6 to 64
MC’97 0 converters and GPIO not ready (0x1)
b44.c:v0.94 (May 4, 2004)
ACPI: PCI interrupt 0000:02:02.0[A] -> GSI 6 (level, low) -> IRQ 6
eth0: Broadcom 4400 10/100BaseT Ethernet 00:c0:9f:5b:a1:98
ieee80211_crypt: registered algorithm 'NULL’
ipw2200: Intel® PRO/Wireless 2200/2915 Network Driver, 0.11
ipw2200: Copyright© 2003-2004 Intel Corporation
ACPI: PCI interrupt 0000:02:04.0[A] -> GSI 10 (level, low) -> IRQ 10
ipw2200: Detected Intel PRO/Wireless 2200BG Network Connection
Linux Kernel Card Services
options: [pci] [cardbus] [pm]
PCI: Enabling device 0000:02:06.0 (0104 -> 0106)
ACPI: PCI interrupt 0000:02:06.0[A] -> GSI 10 (level, low) -> IRQ 10
Yenta: CardBus bridge found at 0000:02:06.0 [1025:0064]
Yenta: ISA IRQ mask 0x08b8, PCI irq 10
Socket status: 30000006
ieee1394: Initialized config rom entry `ip1394’
ohci1394: $Rev: 1223 $ Ben Collins bcollins@debian.org
ACPI: PCI interrupt 0000:02:06.2[A] -> GSI 10 (level, low) -> IRQ 10
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[10] MMIO=[d020a000-d020a7ff] Max Packet=[2048]
usb usb4: string descriptor 0 read error: -19
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00c09f00002a1e00]
b44: eth0: Link is down.
NET: Registered protocol family 10
Disabled Privacy Extensions on device c02cc0c0(lo)
IPv6 over IPv4 tunneling driver
b44: eth0: Link is up at 100 Mbps, full duplex.
b44: eth0: Flow control is on for TX and on for RX.
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID]
ACPI: Sleep Button (CM) [SLPB]
cs: IO port probe 0x0100-0x04ff: clean.
cs: IO port probe 0x0800-0x08ff: excluding 0x800-0x807
cs: IO port probe 0x0c00-0x0cff: clean.
cs: IO port probe 0x0a00-0x0aff: clean.
cpufreq: CPU0 - ACPI performance management activated.
cpufreq: *P0: 1600 MHz, 24000 mW, 10 uS
cpufreq: P1: 1400 MHz, 20000 mW, 10 uS
cpufreq: P2: 1200 MHz, 18000 mW, 10 uS
cpufreq: P3: 800 MHz, 16000 mW, 10 uS
cpufreq: P4: 600 MHz, 12000 mW, 10 uS
eth0: no IPv6 routers present
atkbd.c: Unknown key pressed (translated set 2, code 0xb4 on isa0060/serio0).
atkbd.c: Use 'setkeycodes e034 ’ to make it known.
atkbd.c: Unknown key released (translated set 2, code 0xb4 on isa0060/serio0).
usb 2-1: new full speed USB device using address 2
SCSI subsystem initialized
Initializing USB Mass Storage driver…
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: Generic Model: USB Flash Disk Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 02
USB Mass Storage device found at 2
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb 2-1: USB disconnect, address 2
scsi: Device offlined - not ready after error recovery: host 0 channel 0 id 0 lun 0
sd 0:0:0:0: Illegal state transition cancel->offline
Badness in scsi_device_set_state at drivers/scsi/scsi_lib.c:1643
[] scsi_device_set_state+0xc4/0xcf [scsi_mod]
[] scsi_eh_offline_sdevs+0x47/0x60 [scsi_mod]
[] scsi_unjam_host+0x18d/0x1a2 [scsi_mod]
[] scsi_error_handler+0x116/0x15a [scsi_mod]
[] scsi_error_handler+0x0/0x15a [scsi_mod]
[] kernel_thread_helper+0x5/0xb
sda : READ CAPACITY failed.
sda : status=0, message=00, host=1, driver=00
sda : sense not available.
sda: Write Protect is off
sda: Mode Sense: 00 00 00 00
sda: assuming drive cache: write through
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
usb 2-1: new full speed USB device using address 3
scsi1 : SCSI emulation for USB Mass Storage devices
SCSI device sda: 260352 512-byte hdwr sectors (133 MB)
sda: Mode Sense: 00 06 00 00
/dev/scsi/host1/bus0/target0/lun0: p1
Attached scsi removable disk sda at scsi1, channel 0, id 0, lun 0
USB Mass Storage device found at 3
usb 2-1: control timeout on ep0in
usb 2-1: USB disconnect, address 3
usb 2-1: new full speed USB device using address 4
scsi2 : SCSI emulation for USB Mass Storage devices
/dev/scsi/host2/bus0/target0/lun0: p1
Attached scsi removable disk sda at scsi2, channel 0, id 0, lun 0
USB Mass Storage device found at 4
usb 2-1: USB disconnect, address 4
usb 3-2: new full speed USB device using address 2
scsi3 : SCSI emulation for USB Mass Storage devices
/dev/scsi/host3/bus0/target0/lun0: p1
Attached scsi removable disk sda at scsi3, channel 0, id 0, lun 0
usb 3-2: control timeout on ep0in
usb 3-2: USB disconnect, address 2
usb 2-2: new full speed USB device using address 5
scsi4 : SCSI emulation for USB Mass Storage devices
/dev/scsi/host4/bus0/target0/lun0: p1
Attached scsi removable disk sda at scsi4, channel 0, id 0, lun 0
USB Mass Storage device found at 5
usb 2-2: control timeout on ep0in
usb 2-2: USB disconnect, address 5
usb 3-2: new full speed USB device using address 3
scsi5 : SCSI emulation for USB Mass Storage devices
/dev/scsi/host5/bus0/target0/lun0: p1
Attached scsi removable disk sda at scsi5, channel 0, id 0, lun 0
