j’ai un problème pour configurer Xorg avec ma carte I845GL, il me laisse en 640*480.
Que je fasse n’importe quoi il me jette.
Les actions que j’ai entrepris :
- utilisation des 915resolution
- changement de driver
- ajout des modelines
au final dans le /var/log/Xorg… j’ai :
(II) I810(0): Not using mode "1280x1024" (no mode of this name)
(II) I810(0): Not using mode "1024x768" (no mode of this name)
(II) I810(0): Not using mode "800x600" (no mode of this name)
(--) I810(0): Virtual size is 640x480 (pitch 640)
mon xorg.conf ressemble à ça :
Section "Module"
Load "bitmap"
Load "ddc"
# Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbVariant" "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
EndSection
Section "Device"
Identifier "Intel Corporation 82845G/GL[Brookdale-G]/GE Chipset Integrated Graphics Device"
Driver "i810"
BusID "PCI:0:2:0"
EndSection
Section "Monitor"
Identifier "DELL E772p"
Option "DPMS"
# HorizSync 28-49
# VertRefresh 43-72
# 1024x768 @ 60.00 Hz (GTF) hsync: 47.70 kHz; pclk: 64.11 MHz
Modeline "1024x768_60.00" 64.11 1024 1080 1184 1344 768 769 772 795 -HSync +Vsync
# 1024x768 @ 85.00 Hz (GTF) hsync: 68.60 kHz; pclk: 94.39 MHz
Modeline "1024x768_85.00" 94.39 1024 1088 1200 1376 768 769 772 807 -HSync +Vsync
# 1280x1024 @ 60.00 Hz (GTF) hsync: 63.60 kHz; pclk: 108.88 MHz
Modeline "1280x1024_60.00" 108.88 1280 1360 1496 1712 1024 1025 1028 1060 -HSync +Vsync
# 1280x1024 @ 85.00 Hz (GTF) hsync: 91.38 kHz; pclk: 159.36 MHz
Modeline "1280x1024_85.00" 159.36 1280 1376 1512 1744 1024 1025 1028 1075 -HSync +Vsync
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation 82845G/GL[Brookdale-G]/GE Chipset Integrated Graphics Device"
Monitor "DELL E772p"
DefaultDepth 16
SubSection "Display"
Depth 1
Modes "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
Donc la je ne sais plus quoi faire.
Allez un petit plus avant de raccrocher, j’ai updater le noyau en 2.6.18-4, et la il ne voulait plus du AGPGART, ça dit quelque chose à quelqu’un ? (du coup retour en 2.6.18-3)
merci d’avance.
