mon XF86config-4 :
[code]### BEGIN DEBCONF SECTION
XF86Config-4 (XFree86 server configuration file) generated by dexconf, the
Debian X Configuration tool, using values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
If you want your changes to this file preserved by dexconf, only make changes
before the “### BEGIN DEBCONF SECTION” line above, and/or after the
“### END DEBCONF SECTION” line below.
To change things within the debconf section, run the command:
dpkg-reconfigure xserver-xfree86
as root.  Also see "How do I add custom sections to a dexconf-generated
XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
Section "Files"
FontPath	“unix/:7100”			# local font server
# if the local font server has problems, we can fall back on these
FontPath	"/usr/lib/X11/fonts/misc"
FontPath	"/usr/lib/X11/fonts/cyrillic"
FontPath	"/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath	"/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath	"/usr/lib/X11/fonts/Type1"
FontPath	"/usr/lib/X11/fonts/Speedo"
FontPath	"/usr/lib/X11/fonts/100dpi"
FontPath	"/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load	"bitmap"
Load	"dbe"
Load	"ddc"
Load	"extmod"
Load	"freetype"
Load	"glx"
Load	"int10"
Load	"pex5"
Load	"record"
Load	"speedo"
Load	"type1"
Load	"vbe"
Load	"xie"
EndSection
Section "InputDevice"
Identifier	"Generic Keyboard"
Driver		"keyboard"
Option		"CoreKeyboard"
Option		“XkbRules”	"xfree86"
Option		“XkbModel”	"pc105"
Option		“XkbLayout”	"fr"
EndSection
Identifier	"Configured Mouse"
Driver		"mouse"
Option		"CorePointer"
Option		“Device”		"/dev/input/mice"
Option		“Protocol”		"ImPS/2"
Option		“ZAxisMapping”		"4 5"
EndSection
Section "Device"
Identifier	"geforce4mx"
Driver		"nv"
EndSection
Section "Monitor"
Identifier	"f700b"
HorizSync	30-68
VertRefresh	50-85
Option		"DPMS"
EndSection
Section "Screen"
Identifier	"Default Screen"
Device		"geforce4mx"
Monitor		"f700b"
DefaultDepth	24
SubSection "Display"
Depth		1
Modes		“1152x864” “1024x768” “800x600” "640x480"
EndSubSection
Depth		4
EndSubSection
Depth		8
EndSubSection
Depth		15
EndSubSection
Depth		16
EndSubSection
Depth		24
EndSubSection
EndSection
Section "ServerLayout"
Identifier	"Default Layout"
Screen		"Default Screen"
InputDevice	"Generic Keyboard"
InputDevice	"Configured Mouse"
EndSection
END DEBCONF SECTION[/code]
