Voici les réglages :
ENABLE="true"
GOVERNOR="ondemand"
MAX_SPEED="1667000"
MIN_SPEED="1000000"
Voici ce que me donne les dernières lignes de ps x --sort=pcpu :
773 ? S 0:00 [kjournald]
1083 ? Ss 0:00 dhclient -v -pf /var/run/dhclient.wlan0.pid -lf /var/lib/dhcp/dhclient.wlan0.leases wlan0
1170 ? S 0:00 [kconservative/0]
1171 ? S 0:00 [kconservative/1]
1215 ? Ss 0:00 /usr/sbin/cron
1238 ? Ss 0:00 /usr/sbin/sshd
1405 ? S 0:00 logger -t mysqld -p daemon.error
1415 ? S 0:00 /usr/lib/hal/hald-addon-generic-backlight
1416 ? S 0:00 /usr/lib/hal/hald-addon-rfkill-killswitch
1429 ? S 0:00 /usr/lib/hal/hald-addon-cpufreq
2122 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2123 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
2124 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2125 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2126 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
3457 ? Ss 0:00 /usr/sbin/acpi_fakekeyd
3504 ? Ss 0:00 /usr/sbin/acpid
4064 pts/0 R+ 0:00 ps x --sort=pcpu
6 ? S 0:00 [migration/1]
7 ? S 0:00 [ksoftirqd/1]
10 ? S 0:00 [events/1]
20 ? S 0:00 [kblockd/0]
21 ? S 0:00 [kblockd/1]
1407 ? S 0:00 hald-addon-input: Listening on /dev/input/event0 /dev/input/event6 /dev/input/event2 /dev/input/event7 /dev/input/event3 /dev/inpu
9 ? S 0:00 [events/0]
12 ? S 0:00 [khelper]
1257 ? S 0:00 hald-runner
1293 ? S 0:00 /bin/sh /usr/bin/mysqld_safe
523 ? S 0:00 [rtl8192CE/1]
2235 tty1 S+ 0:00 -bash
533 ? S 0:00 [flush-8:0]
522 ? S 0:00 [rtl8192CE/0]
2160 ? Sl 0:00 /usr/sbin/console-kit-daemon --no-daemon
1045 ? Ss 0:00 /usr/sbin/apache2 -k start
2479 pts/0 Ss 0:00 -bash
977 ? Sl 0:00 /usr/sbin/rsyslogd -c4
25 ? S 0:00 [kseriod]
323 ? S<s 0:00 udevd --daemon
521 ? S 0:00 [Ieee80211/1]
2121 tty1 Ss 0:00 /bin/login --
520 ? S 0:00 [Ieee80211/0]
1027 ? Ss 0:00 /sbin/wpa_supplicant -s -B -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -D wext -C /var/run/wpa_supplicant
259 ? S 0:00 [kjournald]
2459 ? Ss 0:00 sshd: root@pts/0
1 ? Ss 0:01 init [2]
et la commande top :
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1404 mysql 20 0 134m 18m 5524 S 0 1.8 0:00.68 mysqld
4251 root 20 0 2448 1152 896 R 0 0.1 0:00.10 top
1 root 20 0 2032 708 612 S 0 0.1 0:01.06 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
4 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/0
5 root RT 0 0 0 0 S 0 0.0 0:00.00 watchdog/0
6 root RT 0 0 0 0 S 0 0.0 0:00.01 migration/1
7 root 20 0 0 0 0 S 0 0.0 0:00.01 ksoftirqd/1
8 root RT 0 0 0 0 S 0 0.0 0:00.00 watchdog/1
9 root 20 0 0 0 0 S 0 0.0 0:00.03 events/0
10 root 20 0 0 0 0 S 0 0.0 0:00.02 events/1
11 root 20 0 0 0 0 S 0 0.0 0:00.00 cpuset
12 root 20 0 0 0 0 S 0 0.0 0:00.02 khelper
13 root 20 0 0 0 0 S 0 0.0 0:00.00 netns
14 root 20 0 0 0 0 S 0 0.0 0:00.00 async/mgr
15 root 20 0 0 0 0 S 0 0.0 0:00.00 pm
16 root 20 0 0 0 0 S 0 0.0 0:00.00 sync_supers
17 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default
18 root 20 0 0 0 0 S 0 0.0 0:00.00 kintegrityd/0
19 root 20 0 0 0 0 S 0 0.0 0:00.00 kintegrityd/1
20 root 20 0 0 0 0 S 0 0.0 0:00.01 kblockd/0
21 root 20 0 0 0 0 S 0 0.0 0:00.01 kblockd/1
22 root 20 0 0 0 0 S 0 0.0 0:00.00 kacpid
23 root 20 0 0 0 0 S 0 0.0 0:00.00 kacpi_notify
24 root 20 0 0 0 0 S 0 0.0 0:00.00 kacpi_hotplug
25 root 20 0 0 0 0 S 0 0.0 0:00.11 kseriod
28 root 20 0 0 0 0 S 0 0.0 0:00.00 kondemand/0
29 root 20 0 0 0 0 S 0 0.0 0:00.00 kondemand/1
30 root 20 0 0 0 0 S 0 0.0 0:00.00 khungtaskd
31 root 20 0 0 0 0 S 0 0.0 0:00.00 kswapd0
32 root 25 5 0 0 0 S 0 0.0 0:00.00 ksmd
33 root 20 0 0 0 0 S 0 0.0 0:00.00 aio/0
34 root 20 0 0 0 0 S 0 0.0 0:00.00 aio/1
35 root 20 0 0 0 0 S 0 0.0 0:00.00 crypto/0
36 root 20 0 0 0 0 S 0 0.0 0:00.00 crypto/1
201 root 20 0 0 0 0 S 0 0.0 0:00.00 ksuspend_usbd
202 root 20 0 0 0 0 S 0 0.0 0:00.00 khubd
211 root 20 0 0 0 0 S 0 0.0 0:00.00 ata/0
[edit: je me suis permis de remplacer les «quote» par des «code» pour conserver la tabulation
