je sur Linux debian 3.2.0-4-486 #1 Debian 3.2.51-1 i686 GNU/Linux
qui doit être wheezy.
Je souhaite installé pdfedit mais j’ai un léger souci à la fin du ./configure
sylvain@debian:~/pdfedit-0.4.5$ ./configure
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether make sets $(MAKE)... yes
checking for ranlib... ranlib
checking whether ln -s works... yes
checking how to run the C++ preprocessor... g++ -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for unistd.h... (cached) yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... no
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for size_t... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking how to run the C preprocessor... gcc -E
checking if zlib is wanted... checking for inflateEnd in -lz... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... (cached) yes
checking zlib in /usr/local... ok
checking for boostlib >= 1.20.0... yes
configure: Using default COPY="cp -f"
configure: Using default DEL_FILE="rm -f"
configure: Using default DEL_DIR="sh $(ROOT)/tools/rmdir.sh"
configure: Using default DEL_FORCE_DIR="rm -rf"
configure: Using default SYMLINK="ln -s"
configure: Using default MOVE="mv -f"
configure: Using default CHK_DIR_EXISTS="test -d"
configure: Using default MKDIR="mkdir -p"
configure: Using default ARCH=""
configure: Using default C_EXTRA="-fmessage-length=0 -D_FORTIFY_SOURCE=2 -fno-strict-aliasing"
configure: Using default EXTRA_UTILS_CFLAGS=""
configure: Using default EXTRA_KERNEL_CFLAGS=""
configure: Using default EXTRA_TESTS_CFLAGS=""
configure: Using default EXTRA_XPDF_CFLAGS=""
configure: Using default CXX_EXTRA="-fmessage-length=0 -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -fexceptions"
configure: Using default EXTRA_UTILS_CXXFLAGS=""
configure: Using default EXTRA_KERNEL_CXXFLAGS=""
configure: Using default EXTRA_TESTS_CXXFLAGS=""
configure: Using default EXTRA_GUI_CXXFLAGS=""
configure: Using default EXTRA_XPDF_CXXFLAGS=""
configure: Using default AR="ar cqs"
configure: Using default LIBPREFIX="lib"
checking whether we use stack protector... no
checking whether we are releasing... true
checking whether debug info is included... no
checking whether to enable observer debugging... no
checking for error_at_line... yes
checking for GNU libc compatible malloc... yes
checking whether lstat correctly handles trailing slash... yes
checking whether stat accepts an empty string... no
checking for strftime... yes
checking for atexit... yes
checking for floor... yes
checking for ftruncate... yes
checking for localtime_r... yes
checking for memset... yes
checking for mkdir... yes
checking for strdup... yes
checking for strerror... yes
checking for strpbrk... yes
checking for strstr... yes
checking for freetype-config... /usr/bin/freetype-config
checking for FreeType -- version >= 7.0.1... yes
checking whether to use t1 library... maybe
checking where to find the t1 header files...
checking t1lib.h usability... yes
checking t1lib.h presence... yes
checking for t1lib.h... yes
checking for T1_InitLib in -lt1... yes
using t1 library
checking whether we want to prepare pdfedit-core-dev package... no
checking whether we want to build PDFedit gui... yes
configure: error: QTDIR environment variable must be set
Donc la question est comment résoudre l’erreur QTDIR pour pouvoir continuer et faire le make?
J’ai chercher sur le web mais les solution apporté n’ont pas fonctionné (ou je n’ai pas su les appliqué correctement ce qui est aussi possible étant plus habitué à ubuntu).
Merci.
