Sous Squeeze, l’archiveur par défaut est squeeze, mais j’utilise beaucoup de 7z, zip, un peu de rar et très peu de tar et squeeze (l’archiveur) ne gère pas tous ces formats.
J’utilisais file-roller avant sous gnome, mais maintenant sur XFCE je préfère utiliser peazip.
Mon seul souci est de pouvoir intégrer le support de l’extraction/archivage peazip via thunar-archive-plugin…
J’ai vu quelque part qu’il fallait utiliser un .tap et un .desktop mais à part ça pas grand chose. Quelqu’un connait l’astuce ?
Sur le site officiel, ils parlent effectivement d’un .tap. Ils disent aussi de voir le README de l’archive des sources.Voici ce fichier, il doit falloir bidouiller un peu les fichiers, mais ça ne semble pas impossible :
[code]What is it?
The thunar-archive-plugin is a plugin for the Thunar File Manager, which
adds archive operations to the file context menus. Using this plugin you
will be able to extract and create archive files from within Thunar using
a single click.
Required packages
thunar-archive-plugin depends on the following packages:
- Thunar 0.4.0 or above
Supported archive managers
thunar-archive-plugin currently supports file-roller (the GNOME archive manager)
and ark (the KDE archive manager), but support for additional archive managers
can be easily added.
To add support for a new archive manager, all you need to do is to install
the .desktop file - with the list of supported mime types - for the archive
manager to the $(datadir)/applications/ folder (as usual), and in addition,
install a .tap file to $(libexecdir)/thunar-archive-plugin/, which provides
a wrapper script that invokes the archive manager with the appropriate
parameters for the actions “Create Archive”, “Extract Here” and “Extract To”.
The .tap and .desktop files should have the same basename, otherwise the
thunar-archive-plugin is not able to find the appropriate .tap file for an
archive manager. For example, if the name of the .desktop file is ark.desktop,
the .tap file must be named ark.tap.
See the scripts/ directory for examples of how to create said .tap files. The
template.tap file should provide a good starting point.
Note that the thunar-archive-plugin takes the applications from the desktop
database, so after installing new archive managers in $prefix (i.e. /usr or
/usr/local), make sure to run
update-desktop-database $prefix/share/applications
Most modern packagement systems will do this for you automatically, but if
you are installing archive managers manually, you may need to run the above
command first, otherwise you will get an error message telling you that no
support archive managers were found on your system.
Installation
The file ‘INSTALL’ contains generic installation instructions. For more
detailed information, visit the thunar-archive-plugin website at
http://xfce.org/~benny/projects/thunar-archive-plugin/.
How to report bugs?
Bugs should be reported to the Xfce bug tracking system
(http://bugzilla.xfce.org, product Thunar Plugins, component
thunar-archive-plugin). You will need to create an
account for yourself.
Déplacé dans support. le forum T&A est l’endroit ou on partage ses T&A…
Avec 74 messages, tu n’a pas encore pris connaissance des règles du forum ?
Avec 74 messages, tu n’a pas encore pris connaissance des règles du forum ?[/quote]
Pas fais attention, désolé
(74 messages quand même !)
Merci thuban d’avoir fait avancer le schmilblick. Pour un débutant comme moi, ça semble un peu chaud encore
A essayer dès que possible
Je suis désolé, je suis en pleins partiels là, j’ai pas trop le temps, mais je serais bien tenté de te faire un truc juste après (dans 1 semaine). D’ici là n’hésite pas à tenter. Tu peux aussi utiliser xarchiver, ou les actions personnalisées de thunar que tu ferais toi même (ajouter à l’archive, décompresser… seulement pour les 7z)
J’ai trouvé un fichier .tap pour xarchiver :
mail-archive.com/xfce4-commi … 00467.html
Reste à l’adapter pour peazip en peazip.tap.
