Salut a tous,
j’ai un souci avec ma Sarge.
A chaque fois que j’utilise apt, j’ai le message suivant:
[quote]perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = “en_US:en_GB:en”,
LC_ALL = (unset),
LANG = "en"
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory[/quote] J’ai fait un dpkg-reconfigure locales en en choisissant que [quote]en ISO-8859-1[/quote](distrib en anglais).
Pourtant, j’ai toujours des problemes lors de l installation de nmap par exemple:
The following NEW packages will be installed:
nmap
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
Need to get 575kB of archives.
After unpacking 1933kB of additional disk space will be used.
Get:1 http://ftp.uk.debian.org stable/main nmap 3.81-1 [575kB]
Fetched 551kB in 10s (52.0kB/s)
LANGUAGE = "en_US:en_GB:en",
LC_ALL = (unset),
LANG = "en"
perl: warning: Falling back to the standard locale ("C").
Selecting previously deselected package nmap.
(Reading database ... 90423 files and directories currently installed.)
Unpacking nmap (from .../archives/nmap_3.81-1_i386.deb) ...
Setting up nmap (3.81-1) ...
J’ai fait un dpkg-reconfigure locales en ne selectionnant que [quote]en ISO-8859-1[/quote]
Une idee ?
