Je possède un DELL PowerEdge R210 faisant office entre autre de serveur Nagios et &
J’ai récemment migré de Squeeze à Wheezy. Depuis, il arrive que parfois, le ping (la commande de base linux) ne marche plus vers telle ou telle machine située dans un autre sous réseau.
Pour refaire “partir” le ping, je fait
ou un
invoke-rc.d networking stop && invoke-rc.d networking start
Pour info
[code]cat /etc/debian_version
7.2
root@Pontos:~# dpkg --status firmware-bnx2
Package: firmware-bnx2
Status: install ok installed
Priority: optional
Section: non-free/kernel
Installed-Size: 660
Maintainer: Debian Kernel Team debian-kernel@lists.debian.org
Architecture: all
Multi-Arch: foreign
Source: firmware-nonfree
Version: 0.36+wheezy.1
Suggests: initramfs-tools, linux-image
Description: Binary firmware for Broadcom NetXtremeII
This package contains the binary firmware for Broadcom NetXtremeII network
adapters supported by the bnx2 driver.
Contents:
- Broadcom NetXtremeII 5706/5708 firmware (mips), version Linux 2.6.32 (bnx2/bnx2-mips-06-5.0.0.j3.fw)
- Broadcom NetXtremeII 5706/5708 firmware (rv2p), version Linux 2.6.32 (bnx2/bnx2-rv2p-06-5.0.0.j3.fw)
- Broadcom NetXtremeII 5709/5716 firmware (mips), version Linux 2.6.32 (bnx2/bnx2-mips-09-5.0.0.j3.fw)
- Broadcom NetXtremeII 5709/5716 firmware (rv2p), version Linux 2.6.32 (bnx2/bnx2-rv2p-09-5.0.0.j3.fw)
- Broadcom NetXtremeII 5709 A0/A1 firmware (rv2p), version Linux 2.6.32 (bnx2/bnx2-rv2p-09ax-5.0.0.j3.fw)
- bnx2/bnx2-rv2p-06-6.0.15.fw
- Broadcom NetXtremeII 5709/5716 firmware (rv2p), version Linux 2.6.37 (bnx2/bnx2-rv2p-09-6.0.17.fw)
- Broadcom NetXtremeII 5709 A0/A1 firmware (rv2p), version Linux 2.6.37 (bnx2/bnx2-rv2p-09ax-6.0.17.fw)
- Broadcom NetXtremeII 5706/5708 firmware (mips), version Linux 2.6.38 (bnx2/bnx2-mips-06-6.2.1.fw)
- Broadcom NetXtremeII 5706/5708 firmware (mips), version Linux 3.3 (bnx2/bnx2-mips-06-6.2.3.fw)
- Broadcom NetXtremeII 5709/5716 firmware (mips), version Linux 2.6.39 (bnx2/bnx2-mips-09-6.2.1a.fw)
- Broadcom NetXtremeII 5709/5716 firmware (mips), version Linux 3.3 (bnx2/bnx2-mips-09-6.2.1b.fw)
Homepage: http://git.kernel.org/?p=linux/kernel/git/firmware/linux-firmware.git
uname -a
Linux Pontos 3.2.0-4-amd64 #1 SMP Debian 3.2.46-1+deb7u1 x86_64 GNU/Linux
[quote]root@Pontos:~# lspci
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11)
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation 3400 Series Chipset LPC Interface Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 05)
01:00.0 SCSI storage controller: LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
02:00.0 Ethernet controller: Broadcom Corporation NetXtreme II BCM5716 Gigabit Ethernet (rev 20)
02:00.1 Ethernet controller: Broadcom Corporation NetXtreme II BCM5716 Gigabit Ethernet (rev 20)
03:03.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200eW WPCM450 (rev 0a)
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers (rev 04)
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 04)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 04)
ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 04)
ff:03.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller (rev 04)
ff:03.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder (rev 04)
ff:03.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
ff:03.4 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
ff:04.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers (rev 04)
ff:04.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers (rev 04)
ff:04.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers (rev 04)
ff:04.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
ff:05.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers (rev 04)
ff:05.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers (rev 04)
ff:05.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers (rev 04)
ff:05.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
Merci d’avance
