pas facile de faire un copier coller depuis une ligne de commande vers un forum phpBB,
mais on va y arriver, avec l’aide du CD Live de Sidux KDE
[code]X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux dz 2.6.18-5-686 #1 SMP Tue Dec 18 21:24:20 UTC 2007 i686
Build Date: 18 January 2008
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jan 25 21:09:58 2008
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “BenQ FP91G+”
() | |–>Device “nVidia Corporation NV11 [GeForce2 MX/MX 400]”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(–) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2530 card 1043,8030 rev 04 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2532 card 0000,0000 rev 04 class 06,04,00 hdr 01
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 04 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,2440 card 0000,0000 rev 04 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,244b card 1043,8028 rev 04 class 01,01,80 hdr 00
(II) PCI: 00:1f:2: chip 8086,2442 card 1043,8028 rev 04 class 0c,03,00 hdr 00
(II) PCI: 00:1f:4: chip 8086,2444 card 1043,8028 rev 04 class 0c,03,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,2445 card 1043,8095 rev 04 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0110 card 0000,0000 rev b2 class 03,00,00 hdr 00
(II) PCI: 02:04:0: chip 1033,0035 card 807d,0035 rev 41 class 0c,03,10 hdr 80
(II) PCI: 02:04:1: chip 1033,0035 card 807d,0035 rev 41 class 0c,03,10 hdr 00
(II) PCI: 02:04:2: chip 1033,00e0 card 807d,1043 rev 02 class 0c,03,20 hdr 00
(II) PCI: 02:0c:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xee000000 - 0xefefffff (0x1f00000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xeff00000 - 0xf7ffffff (0x8100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[1] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[2] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[3] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xec000000 - 0xedffffff (0x2000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) nVidia Corporation NV11 [GeForce2 MX/MX 400] rev 178, Mem @ 0xee000000/24, 0xf0000000/27, BIOS @ 0xefff0000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xf8000000 from 0xfbffffff to 0xf7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xec000000 - 0xec0000ff (0x100) MX[B]
[1] -1 0 0xec800000 - 0xec8000ff (0x100) MX[B]
[2] -1 0 0xed000000 - 0xed000fff (0x1000) MX[B]
[3] -1 0 0xed800000 - 0xed800fff (0x1000) MX[B]
[4] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[5] -1 0 0xefff0000 - 0xefffffff (0x10000) MXB
[6] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MXB
[7] -1 0 0xee000000 - 0xeeffffff (0x1000000) MXB
[8] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[9] -1 0 0x0000a400 - 0x0000a43f (0x40) IX[B]
[10] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[11] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[12] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[13] -1 0 0x0000b800 - 0x0000b80f (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xec000000 - 0xec0000ff (0x100) MX[B]
[5] -1 0 0xec800000 - 0xec8000ff (0x100) MX[B]
[6] -1 0 0xed000000 - 0xed000fff (0x1000) MX[B]
[7] -1 0 0xed800000 - 0xed800fff (0x1000) MX[B]
[8] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[9] -1 0 0xefff0000 - 0xefffffff (0x10000) MXB
[10] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MXB
[11] -1 0 0xee000000 - 0xeeffffff (0x1000000) MXB
[12] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[13] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[14] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[15] -1 0 0x0000a400 - 0x0000a43f (0x40) IX[B]
[16] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[17] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[18] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[19] -1 0 0x0000b800 - 0x0000b80f (0x10) IX[B]
(II) LoadModule: “i2c”
(II) Loading /usr/lib/xorg/modules/libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.2.0
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: “nv”
(II) Loading /usr/lib/xorg/modules/drivers/nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache™, GeForce 6200SE TurboCache™,
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100
(II) Primary Device is: PCI 01:00:0
(–) Chipset GeForce2 MX/MX 400 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[18] -1 0 0x0000a400 - 0x0000a43f (0x40) IX[B]
[19] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[20] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[21] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[22] -1 0 0x0000b800 - 0x0000b80f (0x10) IX[B]
[23] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[24] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module “int10”
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) NV(0): Initializing int10
(II) Loading sub module “vm86”
(II) LoadModule: “vm86”
(II) Loading /usr/lib/xorg/modules/libvm86.so
(II) Module vm86: vendor="X.Org Foundation"
(II) NV(0): Primary V_BIOS segment is: 0xc000
(–) NV(0): Chipset: “GeForce2 MX/MX 400”
() NV(0): Depth 24, (–) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module “vgahw”
(II) LoadModule: “vgahw”
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(==) NV(0): Using HW cursor
(–) NV(0): Linear framebuffer at 0xF0000000
(–) NV(0): MMIO registers at 0xEE000000
(II) Loading sub module “i2c”
(II) Reloading /usr/lib/xorg/modules/libi2c.so
(II) Loading sub module “ddc”
(II) Reloading /usr/lib/xorg/modules/libddc.so
(II) NV(0): I2C bus “DDC” initialized.
(II) NV(0): Probing for EDID on I2C bus A…
(II) NV(0): I2C device “DDC:ddc2” registered at address 0xA0.
(II) NV(0): I2C device “DDC:ddc2” removed.
(–) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: BNQ Model: 76a5 Serial#: 11233
(II) NV(0): Year: 2006 Week: 15
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) NV(0): Sync: Separate Composite
(II) NV(0): Max H-Image Size [cm]: horiz.: 38 vert.: 30
(II) NV(0): Gamma: 2.20
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): First detailed timing is preferred mode
(II) NV(0): redX: 0.634 redY: 0.354 greenX: 0.300 greenY: 0.614
(II) NV(0): blueX: 0.138 blueY: 0.076 whiteX: 0.310 whiteY: 0.330
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 720x400@70Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@67Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): 1280x1024@75Hz
(II) NV(0): 1152x870@75Hz
(II) NV(0): Manufacturer’s mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) NV(0): #1: hsize: 1280 vsize 1024 refresh: 76 vid: 36993
(II) NV(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): #3: hsize: 1280 vsize 1024 refresh: 72 vid: 35969
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 108.0 MHz Image Size: 376 x 301 mm
(II) NV(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) NV(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) NV(0): clock: 25.2 MHz Image Size: 376 x 301 mm
(II) NV(0): h_active: 640 h_sync: 656 h_sync_end 752 h_blank_end 800 h_border: 0
(II) NV(0): v_active: 350 v_sync: 387 v_sync_end 389 v_blanking: 449 v_border: 0
(II) NV(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 140 MHz
(II) NV(0): Monitor name: BenQ FP91G+
(II) NV(0): Probing for EDID on I2C bus B…
(II) NV(0): … none found
(II) NV(0): Unable to detect which CRTCNumber…
(==) NV(0): …Defaulting to CRTCNumber 0
(II) NV(0): Using CRT on CRTC 0
(–) NV(0): VideoRAM: 65536 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): BenQ FP91G+: Using default hsync range of 31.00-83.00 kHz
(II) NV(0): BenQ FP91G+: Using default vrefresh range of 56.00-76.00 Hz
(II) NV(0): Clock range: 12.00 to 350.00 MHz
(II) NV(0): Not using default mode “640x350” (vrefresh out of range)
(II) NV(0): Not using default mode “320x175” (vrefresh out of range)
(II) NV(0): Not using default mode “640x400” (vrefresh out of range)
(II) NV(0): Not using default mode “320x200” (vrefresh out of range)
(II) NV(0): Not using default mode “720x400” (vrefresh out of range)
(II) NV(0): Not using default mode “360x200” (vrefresh out of range)
(II) NV(0): Not using default mode “640x480” (vrefresh out of range)
(II) NV(0): Not using default mode “320x240” (vrefresh out of range)
(II) NV(0): Not using default mode “800x600” (vrefresh out of range)
(II) NV(0): Not using default mode “400x300” (vrefresh out of range)
(II) NV(0): Not using default mode “1024x768” (bad mode clock/interlace/doublescan)
(II) NV(0): Not using default mode “512x384” (bad mode clock/interlace/doublescan)
(II) NV(0): Not using default mode “1024x768” (vrefresh out of range)
(II) NV(0): Not using default mode “512x384” (vrefresh out of range)
(WW) (1280x960,BenQ FP91G+) mode clock 148.5MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1280x960” (hsync out of range)
(II) NV(0): Not using default mode “640x480” (hsync out of range)
(WW) (1280x1024,BenQ FP91G+) mode clock 157.5MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1280x1024” (hsync out of range)
(II) NV(0): Not using default mode “640x512” (hsync out of range)
(WW) (1600x1200,BenQ FP91G+) mode clock 162MHz exceeds DDC maximum 140MHz
(WW) (1600x1200,BenQ FP91G+) mode clock 175.5MHz exceeds DDC maximum 140MHz
(WW) (1600x1200,BenQ FP91G+) mode clock 189MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1600x1200” (hsync out of range)
(II) NV(0): Not using default mode “800x600” (hsync out of range)
(WW) (1600x1200,BenQ FP91G+) mode clock 202.5MHz exceeds DDC maximum 140MHz
(WW) (1600x1200,BenQ FP91G+) mode clock 229.5MHz exceeds DDC maximum 140MHz
(WW) (1792x1344,BenQ FP91G+) mode clock 204.8MHz exceeds DDC maximum 140MHz
(WW) (1792x1344,BenQ FP91G+) mode clock 261MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1792x1344” (hsync out of range)
(II) NV(0): Not using default mode “896x672” (hsync out of range)
(WW) (1856x1392,BenQ FP91G+) mode clock 218.3MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1856x1392” (hsync out of range)
(II) NV(0): Not using default mode “928x696” (hsync out of range)
(WW) (1856x1392,BenQ FP91G+) mode clock 288MHz exceeds DDC maximum 140MHz
(WW) (928x696,BenQ FP91G+) mode clock 144MHz exceeds DDC maximum 140MHz
(WW) (1920x1440,BenQ FP91G+) mode clock 234MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1920x1440” (hsync out of range)
(II) NV(0): Not using default mode “960x720” (hsync out of range)
(WW) (1920x1440,BenQ FP91G+) mode clock 297MHz exceeds DDC maximum 140MHz
(WW) (960x720,BenQ FP91G+) mode clock 148.5MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1152x768” (vrefresh out of range)
(II) NV(0): Not using default mode “576x384” (vrefresh out of range)
(II) NV(0): Not using default mode “1152x864” (vrefresh out of range)
(II) NV(0): Not using default mode “576x432” (vrefresh out of range)
(WW) (1400x1050,BenQ FP91G+) mode clock 151MHz exceeds DDC maximum 140MHz
(WW) (1400x1050,BenQ FP91G+) mode clock 155.8MHz exceeds DDC maximum 140MHz
(WW) (1400x1050,BenQ FP91G+) mode clock 184MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1400x1050” (hsync out of range)
(II) NV(0): Not using default mode “700x525” (hsync out of range)
(WW) (1680x1050,BenQ FP91G+) mode clock 147.14MHz exceeds DDC maximum 140MHz
(WW) (1920x1200,BenQ FP91G+) mode clock 193.16MHz exceeds DDC maximum 140MHz
(WW) (1920x1200,BenQ FP91G+) mode clock 230MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “1920x1200” (hsync out of range)
(II) NV(0): Not using default mode “960x600” (hsync out of range)
(WW) (1920x1440,BenQ FP91G+) mode clock 341.35MHz exceeds DDC maximum 140MHz
(WW) (960x720,BenQ FP91G+) mode clock 170.675MHz exceeds DDC maximum 140MHz
(WW) (2048x1536,BenQ FP91G+) mode clock 266.95MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “2048x1536” (hsync out of range)
(II) NV(0): Not using default mode “1024x768” (hsync out of range)
(WW) (2048x1536,BenQ FP91G+) mode clock 340.48MHz exceeds DDC maximum 140MHz
(WW) (1024x768,BenQ FP91G+) mode clock 170.24MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using default mode “2048x1536” (bad mode clock/interlace/doublescan)
(WW) (1024x768,BenQ FP91G+) mode clock 194.02MHz exceeds DDC maximum 140MHz
(II) NV(0): Not using mode “720x400” (no mode of this name)
(II) NV(0): Not using mode “640x350” (no mode of this name)
(II) NV(0): Not using default mode “1792x1344” (width too large for virtual size)
(II) NV(0): Not using default mode “1920x1200” (width too large for virtual size)
(II) NV(0): Not using default mode “1600x1200” (width too large for virtual size)
(II) NV(0): Not using default mode “1680x1050” (width too large for virtual size)
(II) NV(0): Not using default mode “1400x1050” (width too large for virtual size)
(II) NV(0): Not using default mode “1440x900” (width too large for virtual size)
(–) NV(0): Virtual size is 1280x1024 (pitch 1280)
() NV(0): *Default mode “1280x1024”: 135.0 MHz, 80.0 kHz, 75.0 Hz
(II) NV(0): Modeline “1280x1024” 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
() NV(0): *Default mode “1152x864”: 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline “1152x864” 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync
() NV(0): *Default mode “1024x768”: 78.8 MHz, 60.1 kHz, 75.1 Hz
(II) NV(0): Modeline “1024x768” 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
() NV(0): *Default mode “832x624”: 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline “832x624” 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
() NV(0): *Default mode “800x600”: 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline “800x600” 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
() NV(0): *Default mode “640x480”: 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline “640x480” 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
() NV(0): Default mode “1280x1024”: 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline “1280x1024” 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
() NV(0): Default mode “1280x960”: 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline “1280x960” 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
() NV(0): Default mode “1280x800”: 83.5 MHz, 49.7 kHz, 60.0 Hz
(II) NV(0): Modeline “1280x800” 83.46 1280 1344 1480 1680 800 801 804 828
() NV(0): Default mode “1280x768”: 80.1 MHz, 47.7 kHz, 60.0 Hz
(II) NV(0): Modeline “1280x768” 80.14 1280 1344 1480 1680 768 769 772 795
() NV(0): Default mode “1024x768”: 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline “1024x768” 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
() NV(0): Default mode “1024x768”: 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline “1024x768” 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
() NV(0): Default mode “896x672”: 102.4 MHz, 83.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “896x672” 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync
() NV(0): Default mode “960x600”: 96.6 MHz, 74.5 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “960x600” 96.58 960 1024 1128 1296 600 600 602 621 doublescan
() NV(0): Default mode “800x600”: 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline “800x600” 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
() NV(0): Default mode “800x600”: 87.8 MHz, 81.2 kHz, 65.0 Hz (D)
(II) NV(0): Modeline “800x600” 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync
() NV(0): Default mode “800x600”: 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline “800x600” 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
() NV(0): Default mode “800x600”: 81.0 MHz, 75.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “800x600” 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync
() NV(0): Default mode “800x600”: 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline “800x600” 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
() NV(0): Default mode “840x525”: 73.6 MHz, 65.2 kHz, 60.1 Hz (D)
(II) NV(0): Modeline “840x525” 73.57 840 892 984 1128 525 525 527 543 doublescan
() NV(0): Default mode “700x525”: 77.9 MHz, 81.5 kHz, 74.8 Hz (D)
(II) NV(0): Modeline “700x525” 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync
() NV(0): Default mode “700x525”: 75.5 MHz, 77.0 kHz, 70.0 Hz (D)
(II) NV(0): Modeline “700x525” 75.50 700 732 828 980 525 525 527 550 doublescan +hsync +vsync
() NV(0): Default mode “700x525”: 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “700x525” 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync
() NV(0): Default mode “640x512”: 67.5 MHz, 80.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline “640x512” 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync
() NV(0): Default mode “640x512”: 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “640x512” 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync
() NV(0): Default mode “720x450”: 54.4 MHz, 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline “720x450” 54.42 720 736 940 956 450 459 463 473 doublescan +hsync +vsync
() NV(0): Default mode “640x480”: 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline “640x480” 31.50 640 664 704 832 480 489 491 520 -hsync -vsync
() NV(0): Default mode “640x480”: 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) NV(0): Modeline “640x480” 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
() NV(0): Default mode “640x480”: 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “640x480” 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync
() NV(0): Default mode “640x400”: 41.7 MHz, 49.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “640x400” 41.73 640 672 740 840 400 400 402 414 doublescan
() NV(0): Default mode “576x432”: 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline “576x432” 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync
() NV(0): Default mode “640x384”: 40.1 MHz, 47.7 kHz, 60.1 Hz (D)
(II) NV(0): Modeline “640x384” 40.07 640 672 740 840 384 384 386 397 doublescan
() NV(0): Default mode “512x384”: 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
(II) NV(0): Modeline “512x384” 39.40 512 520 568 656 384 384 386 400 doublescan +hsync +vsync
() NV(0): Default mode “512x384”: 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline “512x384” 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync
() NV(0): Default mode “512x384”: 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “512x384” 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync
() NV(0): Default mode “416x312”: 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline “416x312” 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync
() NV(0): Default mode “400x300”: 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) NV(0): Modeline “400x300” 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline “400x300” 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline “400x300” 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline “400x300” 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync
() NV(0): Default mode “320x240”: 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline “320x240” 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync
() NV(0): Default mode “320x240”: 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(II) NV(0): Modeline “320x240” 15.75 320 332 352 416 240 244 245 260 doublescan -hsync -vsync
() NV(0): Default mode “320x240”: 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline “320x240” 12.60 320 328 376 400 240 245 246 262 doublescan -hsync -vsync
(–) NV(0): Display dimensions: (380, 300) mm
(–) NV(0): DPI set to (85, 86)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module “xaa”
(II) LoadModule: “xaa”
(II) Loading /usr/lib/xorg/modules/libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B]
[1] 0 0 0xee000000 - 0xeeffffff (0x1000000) MX[B]
[2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[4] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[6] -1 0 0xec000000 - 0xec0000ff (0x100) MX[B]
[7] -1 0 0xec800000 - 0xec8000ff (0x100) MX[B]
[8] -1 0 0xed000000 - 0xed000fff (0x1000) MX[B]
[9] -1 0 0xed800000 - 0xed800fff (0x1000) MX[B]
[10] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[11] -1 0 0xefff0000 - 0xefffffff (0x10000) MXB
[12] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MXB
[13] -1 0 0xee000000 - 0xeeffffff (0x1000000) MXB
[14] 0 0 0x000a0000 - 0x000affff (0x10000) MSB
[15] 0 0 0x000b0000 - 0x000b7fff (0x8000) MSB
[16] 0 0 0x000b8000 - 0x000bffff (0x8000) MSB
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[20] -1 0 0x0000a400 - 0x0000a43f (0x40) IX[B]
[21] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[22] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[23] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[24] -1 0 0x0000b800 - 0x0000b80f (0x10) IX[B]
[25] 0 0 0x000003b0 - 0x000003bb (0xc) ISB
[26] 0 0 0x000003c0 - 0x000003df (0x20) ISB
(==) NV(0): Write-combining range (0xf0000000,0x4000000)
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
() Option “dpms”
() NV(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(EE) AIGLX: Screen 0 is not DRI capable
(II) Loading local sub module “GLcore”
(II) LoadModule: “GLcore”
(II) Loading /usr/lib/xorg/modules/extensions/libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
() Option “CoreKeyboard”
() Generic Keyboard: Core Keyboard
() Option “Protocol” “standard”
() Generic Keyboard: Protocol: standard
() Option “AutoRepeat” “500 30”
() Option “XkbRules” “xorg”
() Generic Keyboard: XkbRules: “xorg”
() Option “XkbModel” “pc105”
() Generic Keyboard: XkbModel: “pc105”
() Option “XkbLayout” “fr”
() Generic Keyboard: XkbLayout: “fr”
() Option “XkbVariant” “latin9”
() Generic Keyboard: XkbVariant: “latin9”
() Option “CustomKeycodes” “off”
() Generic Keyboard: CustomKeycodes disabled
() Option “Protocol” “ImPS/2”
() Configured Mouse: Device: “/dev/input/mice”
() Configured Mouse: Protocol: “ImPS/2”
() Option “CorePointer”
() Configured Mouse: Core Pointer
() Option “Device” “/dev/input/mice”
() Option “Emulate3Buttons” “true”
() Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Configured Mouse: ZAxisMapping: buttons 4 and 5
() Configured Mouse: Buttons: 9
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) XINPUT: Adding extended input device “Generic Keyboard” (type: KEYBOARD)
xkb_keycodes { include “xfree86+aliases(azerty)” };
xkb_types { include “complete” };
xkb_compatibility { include “complete” };
xkb_symbols { include “pc(pc105)+fr(latin9)” };
xkb_geometry { include “pc(pc105)” };
(II) Configured Mouse: ps2EnableDataReporting: succeeded
FreeFontPath: FPE “/usr/share/fonts/X11/misc” refcount is 2, should be 1; fixing.
(II) APM registered successfully
(==) RandR enabled
(WW) Open ACPI failed (/var/run/acpid.socket) (Connection refused)
FreeFontPath: FPE “/usr/share/fonts/X11/misc” refcount is 2, should be 1; fixing.[/code]
Mon driver vidéo est bien dans la liste
GeForce2 MX/MX 400
Si quelqu’un peux m’aider, sinon je sens que Etch-gnome vivra ses derniers instants !
