Il y en a pas dans /usr/share/phpmyadmin :
[quote]
browse_foreigners.php enum_editor.php pmd_help.php server_replication.php tbl_printview.php
bs_disp_as_mime_type.php export.php pmd_pdf.php server_sql.php tbl_relation.php
bs_play_media.php favicon.ico pmd_relation_new.php server_status.php tbl_replace.php
changelog.php import.php pmd_relation_upd.php server_synchronize.php tbl_row_action.php
chk_rel.php import_status.php pmd_save_pos.php server_variables.php tbl_select.php
config.sample.inc.php index.php prefs_forms.php setup tbl_sql.php
db_create.php js prefs_manage.php show_config_errors.php tbl_structure.php
db_datadict.php libraries print.css sql.php tbl_tracking.php
db_export.php license.php querywindow.php tbl_addfield.php themes
db_import.php locale schema_edit.php tbl_alter.php themes.php
db_operations.php main.php schema_export.php tbl_change.php transformation_overview.php
db_printview.php navigation.php server_binlog.php tbl_chart.php transformation_wrapper.php
db_qbe.php phpinfo.php server_collations.php tbl_create.php url.php
db_search.php phpmyadmin server_databases.php tbl_export.php user_password.php
db_sql.php phpmyadmin.css.php server_engines.php tbl_get_field.php view_create.php
db_structure.php pmd server_export.php tbl_import.php view_operations.php
db_tracking.php pmd_common.php server_import.php tbl_indexes.php webapp.php
docs.css pmd_display_field.php server_privileges.php tbl_move_copy.php
Documentation.html pmd_general.php server_processlist.php tbl_operations.php[/quote]
J’ai mit “chmod 777 -v -R /usr/share/phpmyadmin” pour voir et j’ai eu le message: “Wrong permissions on configuration file, should not be world writable!”
D’autre log:
[quote][Mon Nov 19 09:09:17 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:09:18 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:09:52 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:15:21 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:15:23 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:16:21 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:18:07 2012] [notice] caught SIGTERM, shutting down
[Mon Nov 19 09:18:09 2012] [notice] Apache/2.2.22 (Debian) PHP/5.4.4-9 configure d – resuming normal operations
[Mon Nov 19 09:18:12 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:18:13 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:20:01 2012] [notice] caught SIGTERM, shutting down
[Mon Nov 19 09:20:03 2012] [notice] Apache/2.2.22 (Debian) PHP/5.4.4-9 configure d – resuming normal operations
[Mon Nov 19 09:20:05 2012] [error] [client 192.168.1.13] (13)Permission denied: access to /phpmyadmin/index.php denied
[Mon Nov 19 09:20:07 2012] [error] [client 192.168.1.13] (13)Permission denied: access to /phpmyadmin/index.php denied
[Mon Nov 19 09:20:46 2012] [notice] caught SIGTERM, shutting down
[Mon Nov 19 09:20:48 2012] [notice] Apache/2.2.22 (Debian) PHP/5.4.4-9 configure d – resuming normal operations
[Mon Nov 19 09:20:52 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:20:54 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:23:36 2012] [notice] caught SIGTERM, shutting down
[Mon Nov 19 09:23:38 2012] [notice] Apache/2.2.22 (Debian) PHP/5.4.4-9 configure d – resuming normal operations
[Mon Nov 19 09:23:40 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable
[Mon Nov 19 09:23:42 2012] [crit] [client 192.168.1.13] (13)Permission denied: / usr/share/phpmyadmin/.htaccess pcfg_openfile: unable to check htaccess file, ens ure it is readable[/quote]
