J’essaie de créé un serveur web ( Pour Openresultat ) avec apache Mysql php5 et phpmyadmin tous ce passai bien jusqu’a ce que je voulu aller sur la page d acceuil Phpmyadmin mais malheureusement j’ai ceci qui apparaît :
addJSON( ‘list’, PMA_RecentFavoriteTable::getInstance(‘recent’)->getHtmlList() ); exit; } if ($GLOBALS[‘PMA_Config’]->isGitRevision()) { if (isset($_REQUEST[‘git_revision’]) && $GLOBALS[‘is_ajax_request’] == true) { PMA_printGitRevision(); exit; } echo ‘
’; } // Handles some variables that may have been sent by the calling script $GLOBALS[‘db’] = ‘’; $GLOBALS[‘table’] = ‘’; $show_query = ‘1’; // Any message to display? if (! empty($message)) { echo PMA_Util::getMessage($message); unset($message); } $common_url_query = PMA_URL_getCommon(’’, ‘’); // when $server > 0, a server has been chosen so we can display // all MySQL-related information if ($server > 0) { include ‘libraries/server_common.inc.php’; include ‘libraries/StorageEngine.class.php’; // Use the verbose name of the server instead of the hostname // if a value is set $server_info = ‘’; if (! empty($cfg[‘Server’][‘verbose’])) { $server_info .= htmlspecialchars($cfg[‘Server’][‘verbose’]); if ($GLOBALS[‘cfg’][‘ShowServerInfo’]) { $server_info .= ’ (’; } } if ($GLOBALS[‘cfg’][‘ShowServerInfo’] || empty($cfg[‘Server’][‘verbose’])) { $server_info .= $GLOBALS[‘dbi’]->getHostInfo(); } if (! empty($cfg[‘Server’][‘verbose’]) && $GLOBALS[‘cfg’][‘ShowServerInfo’]) { $server_info .= ‘)’; } $mysql_cur_user_and_host = $GLOBALS[‘dbi’]->fetchValue(‘SELECT USER();’); // should we add the port info here? $short_server_info = (!empty($GLOBALS[‘cfg’][‘Server’][‘verbose’]) ? $GLOBALS[‘cfg’][‘Server’][‘verbose’] : $GLOBALS[‘cfg’][‘Server’][‘host’]); } echo ‘
’ . “\n”; // Anchor for favorite tables synchronization. echo PMA_RecentFavoriteTable::getInstance(‘favorite’)->getHtmlSyncFavoriteTables(); echo ‘
’; if ($server > 0 || count($cfg[‘Servers’]) > 1 ) { if ($cfg[‘DBG’][‘demo’]) { echo ‘
’; echo ‘
’ . __(‘phpMyAdmin Demo Server’) . ‘
’; echo ’
'; printf( __( 'You are using the demo server. You can do anything here, but ’ . 'please do not change root, debian-sys-maint and pma users. ’ . ‘More information is available at %s.’ ), ‘demo.phpmyadmin.net’ ); echo ‘
’; echo ‘
’; } echo ‘
’; echo ’
je vous épargne la suite je n’arrive pas régler le problème quelqu’un peut-il m’aider ?
puis réinstallé et tout fonctionné. ( le problème venait de libapache-mod-php5 qui c’était mal installé et il fallait purge php5 en priorité pour le réinstaller )
