Bonsoir, je cherche quelqu’un ayant réussi à installer ces pilotes:
http://www.nvidia.fr/object/linux_nforce_amd64_1.0-0310_fr.html
J’obtiens le message d’erreur classique et ne trouve pas de solution avec l’ami google (et ce n’est pas faute de chercher :X)
[quote]nforce-installer log file '/var/log/nvidia-nforce-installer.log’
creation time: Thu Nov 8 00:15:03 2007
option status:
license pre-accepted : false
expert : false
uninstall : false
driver info : false
no precompiled interface : false
no ncurses color : false
no questions : false
silent : false
Installer install prefix : /usr
kernel source path : (not specified)
net kernel install path : (not specified)
audio kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
Using: nvidia-installer ncurses user interface
-> Found package NVIDIA network driver for Linux-x86_64
-> Found package NVIDIA audio driver for Linux-x86_64
-> Please select packages for installation:
Selections:
NVIDIA audio driver for Linux-x86_64 (1.0-7)
-> Starting install of NVIDIA audio driver for Linux-x86_64
-> Checking for loaded module nvsound
-> Checking for loaded module nvaudio
-> License accepted.
-> Skipping check for conflicting rpms.
-> /proc/version is Linux version 2.6.22-3-amd64 (Debian 2.6.22-5)
(maks@debian.org) (gcc version 4.1.3 20070831 (prerelease) (Debian
4.1.2-16)) #1 SMP Thu Oct 11 15:23:23 UTC 2007
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
-> Kernel source path: ‘/lib/modules/2.6.22-3-amd64/build’
-> Kernel output path: ‘/lib/modules/2.6.22-3-amd64/build’
-> Performing cc_version_check with CC=“cc”.
-> running command /bin/grep “^PATCHLEVEL =”
/lib/modules/2.6.22-3-amd64/build/Makefile | /usr/bin/cut -d " " -f 3
-> Kernel module filename is nvsound.ko
Cleaning kernel module build directory.
executing: ‘cd ./nvsound/main; make clean’…
rm -f *.ko mod. .cmd nv.o ~ core
-> Building kernel module:
executing: ‘cd ./nvsound/main; make module SYSSRC=/lib/modules/2.6.22-3-amd6
4/build SYSOUT=/lib/modules/2.6.22-3-amd64/build’…
make -C /lib/modules/2.6.22-3-amd64/build
KBUILD_SRC=/usr/src/linux-headers-2.6.22-3-amd64
KBUILD_EXTMOD="/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/ma
in" -f /usr/src/linux-headers-2.6.22-3-amd64/Makefile modules
test -e include/linux/autoconf.h -a -e include/config/auto.conf || (
echo;
echo " ERROR: Kernel configuration is invalid.";
echo " include/linux/autoconf.h or include/config/auto.conf are mis
sing.";
echo " Run ‘make oldconfig && make prepare’ on kernel src to fix it
echo;
/bin/false)
mkdir -p /tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/.tmp
_versions
rm -f /tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/.tmp_ve
rsions/
make -f /usr/src/linux-headers-2.6.22-3-amd64/scripts/Makefile.build obj=/tm
cc -Wp,-MD,/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/
.nvalinux.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.2.3/includ
e -D__KERNEL__ -Iinclude -Iinclude2 -I/usr/src/linux-headers-2.6.22-3-amd64/
include -include include/linux/autoconf.h -I/tmp/selfgz4618/NFORCE-Linux-x8
6_64-1.0-0310-pkg1/nvsound/main -Wall -Wundef -Wstrict-prototypes -Wno-trigr
aphs -fno-strict-aliasing -fno-common -Os -mtune=generic -m64 -mno-red-zone
-mcmodel=kernel -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fun
it-at-a-time -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -maccumulate-outgoing-ar
gs -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -fomit-frame-pointer -fn
o-stack-protector -Wdeclaration-after-statement -Wno-pointer-sign -I/tmp/se
lfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main -Wall -Wimplicit -Wr
eturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith
-Wno-multichar -Werror -O -MD -Wno-cast-qual -Wno-error -DNV_CHANGE_PAGE_ATT
R_PRESENT -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nvalin
ux)" -D"KBUILD_MODNAME=KBUILD_STR(nvsound)" -c -o /tmp/selfgz4618/NFORCE-Li
vsound/main/.tmp_nvalinux.o /tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg
1/nvsound/main/nvalinux.c
In file included from include/linux/list.h:8,
from include/linux/module.h:10,
from /tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvso
und/main/nvalinux.c:19:
include/linux/prefetch.h: In function ‘prefetch_range’:
include/linux/prefetch.h:62: warning: pointer of type ‘void *’ used in a
rithmetic
In file included from include/asm/pci.h:92,
from include/linux/pci.h:766,
und/main/nvalinux.c:29:
include/asm-generic/pci-dma-compat.h: In function ‘pci_map_page’:
include/asm-generic/pci-dma-compat.h:49: warning: pointer of type ‘void *�
�� used in arithmetic
/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/nvalinux.c: I
n function ‘AosFpuSave’:
/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/nvalinux.c:21
4: error: ‘struct task_struct’ has no member named ‘thread_info’
n function ‘AosFpuRestore’:
/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/nvalinux.c:23
5: error: ‘struct task_struct’ has no member named ‘thread_info’
n function ‘AosMemoryPhysicalAddressListGet’:
/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main/nvalinux.c:71
0: warning: unused variable ‘phys_addr’
make[4]: *** [/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvsound/main
/nvalinux.o] Erreur 1
make[3]: *** [module/tmp/selfgz4618/NFORCE-Linux-x86_64-1.0-0310-pkg1/nvso
und/main] Erreur 2
make[2]: *** [modules] Erreur 2
-> Error.
ERROR: The NVIDIA kernel module was not created.
ERROR: Installation of the audio driver has failed. Please see the file
’/var/log/nvidia-nforce-installer.log’ for details. You may find
suggestions on fixing installation problems in the README available on
the Linux driver download page at nvidia.com.
