apres un peu de trie voila ce qu’il reste
# cat /var/log/Xorg.0.log | grep -i -E '(glx|fglrx)'
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="FireGL - ATI Technologies Inc."
(II) Loading extension GLX
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
(II) fglrx(0): pEnt->device->identifier=0x8a7bb0
(II) fglrx(0): === [atiddxPreInit] === begin
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DPMS" "true"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(**) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(--) fglrx(0): Chipset: "ATI Mobility Radeon HD 3650" (Chipset = 0x9591)
(--) fglrx(0): (PciSubVendor = 0x1043, PciSubDevice = 0x1872)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xe0000000
(--) fglrx(0): MMIO registers at 0xfcef0000
(--) fglrx(0): I/O port at 0x0000c000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 10.88
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: M86
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
(--) fglrx(0): Video RAM: 1048576 kByte, Type: DDR2
(II) fglrx(0): PCIE card detected
(--) fglrx(0): Using per-process page tables (PPPT) as GART.
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(WW) fglrx(0): Hasn't establisted DRM connection
(II) fglrx(0): [FB] MC range(MCFBBase = 0xc0000000, MCFBSize = 0x40000000)
(WW) fglrx(0): No DRM connection for driver fglrx.
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(II) fglrx(0): RandR 1.2 support is enabled!
(II) fglrx(0): RandR 1.2 rotation support is enabled!
(==) fglrx(0): Center Mode is disabled
(II) fglrx(0): ***Display: ConnectedDisplayTypes=0x00000002, disabled=0x00000000
(II) fglrx(0): Connected Display1: LCD on internal LVDS [lvds]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: AUO Model: 1247 Serial#: 0
(II) fglrx(0): Year: 2005 Week: 1
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Digital Display Input
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 30 vert.: 19
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): No DPMS capabilities specified; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.580 redY: 0.340 greenX: 0.310 greenY: 0.550
(II) fglrx(0): blueX: 0.155 blueY: 0.145 whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 87.6 MHz Image Size: 304 x 190 mm
(II) fglrx(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 1600 h_border: 0
(II) fglrx(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 912 v_border: 0
(II) fglrx(0): AUO
(II) fglrx(0): B141PW01 V2
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 00ffffffffffff0006af471200000000
(II) fglrx(0): 010f0103801e13780a87c594574f8c27
(II) fglrx(0): 25505400000001010101010101010101
(II) fglrx(0): 0101010101013822a0a050840c303020
(II) fglrx(0): 360030be100000180000000f00000000
(II) fglrx(0): 00000000000000000020000000fe0041
(II) fglrx(0): 554f0a202020202020202020000000fe
(II) fglrx(0): 004231343150573031205632200a006d
(II) fglrx(0): End of Display1 EDID data --------------------
(II) fglrx(0): Output LCD using monitor section aticonfig-Monitor[0]-0
(II) fglrx(0): Output DFP_EXTTMDS has no monitor section
(II) fglrx(0): Output CRT1 has no monitor section
(II) fglrx(0): Output TV has no monitor section
(II) fglrx(0): EDID vendor "AUO", prod id 4679
(II) fglrx(0): Printing DDC gathered Modelines:
(II) fglrx(0): Modeline "1440x900"x0.0 87.60 1440 1488 1520 1600 900 903 909 912 -hsync -vsync (54.8 kHz)
(II) fglrx(0): Output LCD connected
(II) fglrx(0): Output DFP_EXTTMDS disconnected
(II) fglrx(0): Output CRT1 disconnected
(II) fglrx(0): Output TV disconnected
(II) fglrx(0): Output LCD using initial mode 1440x900
(**) fglrx(0): Display dimensions: (300, 190) mm
(**) fglrx(0): DPI set to (121, 192)
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): QBS disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): NoAccel = NO
(==) fglrx(0): NoDRI = NO
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x8000001d
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(WW) fglrx(0): could not detect X server version (query_status=-1)
(EE) fglrx(0): atiddxDriScreenInit failed, GPS not been initialized.
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed! *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO) *
(WW) fglrx(0): * no 3D acceleration available *
(WW) fglrx(0): ********************************************* *
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x10000000
(WW) fglrx(0): Failed to set up write-combining range (0xe0000000,0x10000000)
(II) fglrx(0): FBMM initialized for area (0,0)-(1472,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1472,1440) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1472 x 6751
(==) fglrx(0): Backing store disabled
(II) Loading extension FGLRXEXTENSION
(**) fglrx(0): DPMS enabled
(WW) fglrx(0): Textured Video not supported without DRI enabled.
(WW) fglrx(0): Video Overlay not supported on AVIVO based graphics cards. For XVideo support use Option "TexturedVideo".
(II) fglrx(0): GLESX enableFlags = 78
(II) fglrx(0): Acceleration enabled
(EE) fglrx(0): XMM failed to open CMMQS connection.
(II) fglrx(0): XMM failed to initialize!
(II) fglrx(0): Enable composite support successfully
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(==) fglrx(0): Silken mouse enabled
(==) fglrx(0): Using HW cursor of display infrastructure!
(==) fglrx(0): Using software cursor
(II) fglrx(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(II) fglrx(0): 'LVDS LCD' ConnectorType, abstracted as 'Panel'
(II) fglrx(0): 'eDP LCD' ConnectorType, abstracted as 'Panel'
(II) AIGLX: Screen 0 is not DRI capable
(II) fglrx(0): Setting screen physical size to 304 x 190
(II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
perso je sais pas quoi en tirer
il me dit 2 erreurs:
mais ça veut dire quoi ??
