Pilotes pour les périphériques de mon ordi !
Bonjour à toutes et à tous,
Voila, je viens d’installer Debian Jessie sur mon ordi (detail en signature) et je n’est pas qlq pilote tel :
  • Lecteur empreinte,
  • Écran tactile etc.
Voila ce que donne :
lsusb :
xxx@xxxx:/home/xxx# lsusb Bus 003 Device 002: ID 8087:8000 Intel Corp. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 007: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader Bus 001 Device 006: ID 0bda:5720 Realtek Semiconductor Corp. Bus 001 Device 005: ID 04f3:0074 Elan Microelectronics Corp. Bus 001 Device 003: ID 8087:07dc Intel Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub xxxxx@xxxx:/home/xxxx#
lspci :
xxx@xxxx:/home/xxx## lspci 00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 09) 00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09) 00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 09) 00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04) 00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04) 00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04) 00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4) 00:1c.1 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 2 (rev e4) 00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4) 00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4) 00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4) 00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04) 00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04) 00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) 00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04) 03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10) 04:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73) 05:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader (rev 01) 06:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M] xxx@xxxx:/home/xxx#
Donc, Comment je peux savoir si le pilote est installé ou pas ?
Merci de m’aider sur la collecte des drivers !
Cordialement,
Salut et bienvenue,
Je ne sais pas vraiment comment on peut savoir si un pilote est installé ou manquant, mais si ton périphérique ne fonctionne pas, c’est probablement qu’il manque le pilote.
Pour ton lecteur d’empreintes, par exemple, une petite recherche à partir du lsusb te donne des solutions : startpage.com/do/dsearch?query= … e=francais
Pour le tactile je sais qu’il commence à exister des solutions, mais aucune expérience, désolé.
salut,
il faut explorer et exploiter le journal du démarrage:
@debian:~$ su - Mot de passe : root@debian:~# journalctl -b
Exemple:
root@debian:~# journalctl -b | grep firmware févr. 16 09:50:02 debian kernel: radeon 0000:01:05.0: firmware: direct-loading firmware radeon/RS780_pfp.bin févr. 16 09:50:02 debian kernel: radeon 0000:01:05.0: firmware: direct-loading firmware radeon/RS780_me.bin févr. 16 09:50:02 debian kernel: radeon 0000:01:05.0: firmware: direct-loading firmware radeon/R600_rlc.bin févr. 16 09:50:07 debian kernel: radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CEDAR_pfp.bin févr. 16 09:50:07 debian kernel: radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CEDAR_me.bin févr. 16 09:50:07 debian kernel: radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CEDAR_rlc.bin févr. 16 09:50:07 debian kernel: radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CEDAR_smc.bin févr. 16 09:50:07 debian kernel: radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CYPRESS_uvd.bin févr. 16 09:50:09 debian NetworkManager[642]: <info> monitoring kernel firmware directory '/lib/firmware'. févr. 16 09:50:10 debian kernel: r8169 0000:04:00.0: firmware: direct-loading firmware rtl_nic/rtl8168d-2.fw févr. 16 09:50:10 debian kernel: brcmsmac bcma0:0: firmware: direct-loading firmware brcm/bcm43xx-0.fw févr. 16 09:50:10 debian kernel: brcmsmac bcma0:0: firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
As tu bien activé les dépôts contrib et non-free pour avoir accès à toutes les ressources microcode (firmware)
Firmwares manquants dans Debian ? Apprenez à gérer le problème:
raphaelhertzog.fr/2011/10/28/fi … -probleme/
J’ai un lecteur d’empreintes digitales, que je fais fonctionner grâce à fprint
Mais, ton lsusb montre que tu as un lecteur “Validity”, marque qui n’est malheureusement pas supportée par fprint…
freedesktop.org/wiki/Softwa … d_devices/
Essaie quand même, on verra bien.
[quote=“TheJeje20”]Salut,
Essaie quand même, on verra bien.[/quote]
Bonjour TheJeje20, si ce n’est pas pris en charge, pourquoi perdre du temps à essayer puisque l’on sait que cela ne marchera pas, il faut être logique !
Bonjour joker_dz, j’ai un peu cherché et j’ai vu qu’un anglophone a compilé un pilote à partir des sources pour un autre lecteur d’empreinte ( Fingerprint scanner ) de la même marque :
Lui ou elle : ID 138a:0018 Validity Sensors, Inc. Fingerprint scanner
Toi : ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader
Si tu comprends la plus récente méthode qu’il explique, tu pourrais refaire la démarche pour ton modèle :http://askubuntu.com/questions/442838/driver-for-validity-sensors-fingerprint-scanner
Les sources à compiler pour ton lecteur d’empreinte : https://github.com/ars3niy/fprint_vfs5011
Bonjour --gilles–
On ne le sait pas, il y a une forte probabilité (c’est pas écrit “VFS5011 incompatible”).
C’est marqué “Validity VFS101” en titre de la section de “unsupported devices”, et la section fait comprendre qu’il y a peu d’espoir pour les autres lecteurs de la même marque.
Donc perdre 30 secondes à installer libpam-fprintd et 10 dépendances n’est peut-être pas idiot si on a une infime probabilité que ce modèle-là fonctionne avec fprint. ^^
Moi, c’est ce que j’essaierais en premier. Sauf bien sûr si je n’ai pas un accès direct à internet avec la machine concernée.
En tout cas, merci d’avoir déniché une solution qui semble convenir pour son modèle :slightly_smiling:
EDIT : Ben en fait, tu lui demandes aussi d’installer fprint, et d’y ajouter un “add-on” à compiler manuellement pour reconnaître son lecteur.
@joker_dz : je pense deviner que c’est ta première compilation… bon courage et n’hésite pas à nous demander de l’aide.
Tout ce que tu dois faire est marqué dans le fichier INSTALL.
Bonsoir,
Pour savoir si un matériel est compatible et quel paquet permet de le faire fonctionner, un article du wiki donne la solution :
isalo.org/wiki.debian-fr/Id … el-pilotes
