bonjour à tous, pas moyen de lire une vidéo avec VLC, ca plante directement
voila ce que ca donne au terminal
[0x1611818] main interface error: no interface module matched "globalhotkeys,none"
[0x1611818] main interface error: no suitable interface module
[0x1611098] main libvlc error: interface "globalhotkeys,none" initialization failed
swScaler: Palette is not supported as output pixel format
[0x1a4f3d8] swscale scale error: could not init SwScaler and/or allocate memory
QPainter::begin: Paint device returned engine == 0, type: 1
[????????] x11 video output error: X11 request 142.3 failed with error code 8:
BadMatch (invalid parameter attributes)
[????????] x11 video output notice: buggy X11 server claims shared memory
[????????] x11 video output notice: support though it does not work (OpenSSH?)
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 142 (MIT-SHM)
Minor opcode of failed request: 3 (X_ShmPutImage)
Serial number of failed request: 71
Current serial number in output stream: 72
cela semble être un problème de sortie X11. Problème de pilote?
j’utilise le pilote nvidia 185.18.36-2 sur le noyau 2.6.30 amd64
