Plantage serveur X
Bonjour à tous
Récemment je rencontre un problème assez gênant avec le serveur X. Je suis sous Debian Lenny 32bits, noyau 2.6.30-1-686.
De en temps en temps, le serveur X plante et fait planter GDM, voici le log de gdm :
[code]X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny1)
Current Operating System: Linux debian 2.6.30-1-686 #1 SMP Sun Jun 14 16:11:32 UTC 2009 i686
Build Date: 15 March 2009 03:18:10PM
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Jun 22 09:55:33 2009
(==) Using config file: “/etc/X11/xorg.conf”
(II) Module “ddc” already built-in
(II) Module “i2c” already built-in
(II) Module “ramdac” already built-in
(WW) intel(0): Failed to set up write-combining range (0xd0000000,0x10000000)
expected keysym, got circumflex: line 257 of fr
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Error in I830WaitLpRing(), timeout for 2 seconds
pgetbl_ctl: 0x00000001 getbl_err: 0x00000000
ipeir: 0x00000000 iphdr: 0x7d000006
LP ring tail: 0x0000afd0 head: 0x0000afec len: 0x0001f001 start 0x00000000
eir: 0x0000 esr: 0x0000 emr: 0xffff
instdone: 0xfa41 instpm: 0x0000
memmode: 0x00000306 instps: 0x80007826
hwstam: 0xeffe ier: 0x0053 imr: 0xffae iir: 0x0000
Ring at virtual 0xa7980000 head 0xafec tail 0xafd0 count 32761
0000af6c: 02000000
0000af70: 54f00006
0000af74: 03cc2000
0000af78: 001001d4
0000af7c: 001401d8
0000af80: 01000000
0000af84: 00000000
0000af88: 00000010
0000af8c: 02000000
0000af90: 54f00006
0000af94: 03cc2000
0000af98: 001001d8
0000af9c: 001401dc
0000afa0: 01000000
0000afa4: 00000000
0000afa8: 00000010
0000afac: 02000000
0000afb0: 54f00006
0000afb4: 03cc2000
0000afb8: 001001dc
0000afbc: 001401e0
0000afc0: 01000000
0000afc4: 00000000
0000afc8: 00000010
0000afcc: 02000000
0000afd0: 00000720
0000afd4: 00000000
0000afd8: 00000720
0000afdc: 00000000
0000afe0: 00000720
0000afe4: 00000000
0000afe8: 00000720
0000afec: 00000000
Ring end
space: 20 wanted 32
Fatal server error:
lockup[/code]
Je précise que j’ai le même problème avec le noyau 2.6.29-2-686, d’où l’installation du noyau disponible il y a quelques jours afin de voir s’il résoudrerai le problème.
Ma carte graphique est : 82G33/G31 Express Integrated Graphics Controller (Intel)
Merci de venir en aide. :slightly_smiling:
Up! :neutral_face:
Salut essaye ceci :
  • tu le server X avec un petit ctrl+alt+suppr
  • aptitude install xorg mesa-utils
  • aptitude install desktop
essaye ça en rajoutant ton cd d’installation dans ton sources.list
voila :smiley:
En faisant ctrl+alt+suppr, il me propose soit de fermer la session, soit d’éteindre/redémarrer/hiberner le PC, que dois-je faire ?
Merci. :slightly_smiling:
