LENNY
Linux proxi 2.6.26-2-686 #1 SMP Tue Mar 9 17:35:51 UTC 2010 i686 GNU/Linux
[b]
Stable (DVD debian d’install)
pas d’upgrade/ la première update a été faite à l’installation. il y a 3 semaines.
carte graphique
0a:03.0 VGA compatible controller: Matrox Graphics, Inc. MGA G200eW WPCM450 [Hermon] - Winbond/Nuvoton (rev 0a)
INITTAB
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
id:2:initdefault:[/b] # et pourtant je charge Gnome quand même....
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
# Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this work."
# What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
# /sbin/getty invocations for the runlevels.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
# <id>:<runlevels>:<action>:<process>
# Note that on most Debian systems tty7 is used by the X Window System,
# so if you want to add more getty's go ahead but skip tty7 if you run X.
1:2345:respawn:/sbin/getty 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
#T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
# Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
GNOME 2.22.3
XORG…je c po…
en dehors de ca tout marche bien sous gnome, mais faut pas que je ferme une session…triste. et gênant sur un serveur.
XORG.CONF
[code]
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 “Screen0” 0 0
InputDevice “Mouse0” "CorePointer"
InputDevice “Keyboard0” "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/etc/X11/rgb"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "glx"
Load "dbe"
Load "record"
Load "GLcore"
Load "dri"
Load "xtrap"
Load "extmod"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
Option “XkbLayout” "fr"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/input/mice"
Option “ZAxisMapping” "4 5 6 7"
EndSection
Section “Monitor”
#DisplaySize 400 250 # mm
Identifier "Monitor0"
VendorName "ACR"
ModelName “Acer X193HQ”
Comment all HorizSync and VertRefresh values to use DDC:
HorizSync 30.0 - 83.0
VertRefresh 55.0 - 75.0
Option "DPMS"
EndSection
Section “Device”
### Available Driver options are:-
### Values: : integer, : float, : “True”/“False”,
### : “String”, : " Hz/kHz/MHz"
### [arg]: arg optional
#Option “SWcursor” # []
#Option “HWcursor” # []
#Option “PciRetry” # []
#Option “SyncOnGreen” # []
#Option “NoAccel” # []
#Option “ShowCache” # []
#Option “Overlay” # []
#Option “MGASDRAM” # []
#Option “ShadowFB” # []
#Option “UseFBDev” # []
#Option “ColorKey” #
#Option “SetMclk” #
#Option “OverclockMem” # []
#Option “VideoKey” #
#Option “Rotate” # []
#Option “TexturedVideo” # []
#Option “Crtc2Half” # []
#Option “Crtc2Ram” #
#Option “Int10” # []
#Option “AGPMode” #
#Option “AGPSize” #
#Option “DigitalScreen1” # []
#Option “DigitalScreen2” # []
#Option “TV” # []
#Option “TVStandard” # []
#Option “CableType” # []
#Option “NoHal” # []
#Option “SwappedHead” # []
#Option “DRI” # []
#Option “MergedFB” # []
#Option “Monitor2HSync” # []
#Option “Monitor2VRefresh” # []
#Option “Monitor2Position” # []
#Option “MetaModes” # []
#Option “OldDmaInit” # []
#Option “ForcePciDma” # []
#Option “AccelMethod” # []
#Option “KVM” # []
Identifier "Card0"
Driver "mga"
VendorName "Matrox Graphics, Inc."
BoardName "Unknown Board"
BusID "PCI:10:3:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection[/code]
