ça coince à la commande
sudo X -config /root/xorg.conf.new
X.Org X Server 1.7.5
Release Date: 2010-02-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-trunk-686 i686 Debian
Current Operating System: Linux bv-pc 2.6.30-2-686 #1 SMP Fri Dec 4 00:53:20 UTC 2009 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.30-2-686 root=UUID=fd481216-fc2b-4d01-9c8f-5ee3f19f7d1e ro vga=791
Build Date: 16 February 2010 08:37:23AM
xorg-server 2:1.7.5-1 (bgoglin@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check wiki.x.org
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 19 18:25:36 2010
(EE) Unable to locate/open config file: “/root/xorg.conf.new”
(==) Using default built-in configuration (30 lines)
FATAL: Module fbcon not found.
SELinux: Disabled on system, not enabling in X server
record: RECORD extension enabled at configure time.
record: This extension is known to be broken, disabling extension now…
record: bugs.freedesktop.org/show_bug.cgi?id=20500
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
(EE) ioctl EVIOCGNAME failed: Inappropriate ioctl for device
(EE) PreInit returned NULL for ““ImExPS/2 Logitech Wheel Mouse””
et là ça coince
écran noir, plus de clavier
par contre le sytème n’est pas complètement planter. toujours accés avec ssh
