(edit : je serai absent de chez moi jusqu’au dimanche 12 donc je ne pourrait pas donner de retour d’ici la)
Pour clonezilla je boot sur un live CD, j’ai fais savedisk en disk to image que je sauvegarde sur un disque dur externe.
Je n’utilise pas les fonctionnalités qui passe par le réseau.
Oui je trouve aussi !
Voici les retour :
dmesg |grep eth
[ 1.092964] r8169 0000:02:00.0: eth0: RTL8168b/8111b at 0xffffc90000016000, d0:50:99:11:05:81, XID 0c000800 IRQ 72
[ 1.092969] r8169 0000:02:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 12.300828] r8169 0000:02:00.0: eth0: link down
[ 12.300845] r8169 0000:02:00.0: eth0: link down
[ 12.301905] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.886212] r8169 0000:02:00.0: eth0: link up
[ 13.887138] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 24.064152] eth0: no IPv6 routers present
[code]
ifconfig
eth0 Link encap:Ethernet HWaddr d0:50:99:11:05:81
inet adr:192.168.0.100 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: fe80::d250:99ff:fe11:581/64 Scope:Lien
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1440 (1.4 KiB)
Interruption:72 Adresse de base:0x6000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:23 errors:0 dropped:0 overruns:0 frame:0
TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2128 (2.0 KiB) TX bytes:2128 (2.0 KiB)[/code]
ping depuis 192.168.0.100 vers 192.168.0.100
[code]PING 192.168.0.100 (192.168.0.100) 56(84) bytes of data.
64 bytes from 192.168.0.100: icmp_req=1 ttl=64 time=0.086 ms
64 bytes from 192.168.0.100: icmp_req=2 ttl=64 time=0.110 ms
64 bytes from 192.168.0.100: icmp_req=3 ttl=64 time=0.107 ms
64 bytes from 192.168.0.100: icmp_req=4 ttl=64 time=0.100 ms
— 192.168.0.100 ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 2999ms
rtt min/avg/max/mdev = 0.086/0.100/0.110/0.015 ms[/code]
route -n
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
