Bonjour à tous.
De retour de 5 jours d’absence, j’ai mis à jour (aptitude safe-upgrade) ce matin et, depuis (coincidence ?) le passage à KDE 4.3, plus de wifi.
Je dois passer par [quote]ifconfig wlan0 up[/quote] pour que les diodes de ma carte PCMCIA s’allument et KNetworkmanager ne me propose qu’une interface en eth0.
Avant cette maj, aucun pb de wifi.
Quelques renseignements :
[quote=“lshw -C network”]*-network
description: Network controller
product: BCM4306 802.11b/g Wireless LAN Controller
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: bus_master
configuration: driver=b43-pci-bridge latency=64
resources: irq:10 memory:d4000000-d4001fff
*-network
description: Wireless interface
physical id: 2
logical name: wlan0
serial: 00:0e:8e:03:22:13
capabilities: ethernet physical wireless
configuration: broadcast=yes multicast=yes wireless=IEEE 802.11bg[/quote]
[quote=“cat /etc/network/interfaces”]# This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
iface eth0 inet dhcp[/quote]
[quote=“iwconfig”]wlan0 IEEE 802.11bg ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=27 dBm
Retry min limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0[/quote]
[quote=“ifconfig”]wlan0 Link encap:Ethernet HWaddr 00:0e:8e:03:22:13
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)[/quote]
[quote=“iwlist wlan0 scan”]wlan0 Scan completed :
Cell 01 - Address: 00:17:33:39:C0:25
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=56/70 Signal level=-54 dBm
Encryption key:on
ESSID:"NEUF_C024"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=00000012ce4cf00c
Extra: Last beacon: 132ms ago
IE: Unknown: 00094E4555465F43303234
IE: Unknown: 010882848B962430486C
IE: Unknown: 03010B
IE: Unknown: 050400030000
IE: Unknown: 2A0100
IE: Unknown: 2F0100
IE: Unknown: 32040C121860
IE: Unknown: DD090010180201F0000000
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Authentication Suites (1) : PSK[/quote]
[quote=“nm-tool”]NetworkManager Tool
State: disconnected
Device: eth0 -----------------------------------------------------------------
Type: Wired
Driver: 8139too
State: unmanaged
Default: no
HW Address: 00:00:00:00:00:00Capabilities:
Carrier Detect: yes
Speed: 100 Mb/sWired Properties
Carrier: on
Quelqu’un aurait-il une piste ?
Merci d’avance !
Guillaume
