Polices libres
Bonjour, je voudrais installer les équivalents libres des polices les plus utilisées.
J’hésite entre deux paquets ttf-liberation et ttf-freefont. Je ne vois pas la différence entre les deux paquets et ne sait donc pas lequel installé.[code]# apt-cache show ttf-liberation
Package: ttf-liberation
Priority: optional
Section: x11
Installed-Size: 1696
Maintainer: Debian Fonts Task Force pkg-fonts-devel@lists.alioth.debian.org
Architecture: all
Version: 1.04.93-1
Depends: defoma
Filename: pool/main/t/ttf-liberation/ttf-liberation_1.04.93-1_all.deb
MD5sum: 847fba369fcf3941ce6a1a17f599559a
SHA1: 72df74333541a40e47dce039a60824d3a370c071
SHA256: 6889d8e1bdc7fe958f582e00fdb01969fb2fa8e52cb183888f8fb378dc81ccfc
Description: Free fonts with the same metrics as Times, Arial and Courier
A set of serif, sans-serif and monospaced fonts from Red Hat with
exactly the same metrics as the (non-free) Microsoft Times, Arial
and Courier fonts, which implies those fonts can serve as a drop-in
replacement. The font family is named Liberation.
Homepage: https://fedorahosted.org/liberation-fonts/
Tag: made-of::data:font, role::app-data, x11::font
Task: hungarian-desktop
[/code][code]Package: ttf-freefont
Priority: optional
Section: x11
Installed-Size: 3608
Architecture: all
Version: 20080912-1
Depends: defoma
Recommends: x-ttcidfont-conf
Filename: pool/main/t/ttf-freefont/ttf-freefont_20080912-1_all.deb
MD5sum: 83ff7fffa3d6a9c786dd322e3e68a140
SHA1: 6ae719085d0d892ec964904fb27eb4e4cef28011
SHA256: d162d07536bee3f67a14098cb8fa889612dd1b26b5233b2600a7050e7627288f
Description: Freefont Serif, Sans and Mono Truetype fonts
A set of free high-quality TrueType fonts covering the UCS
character set. These fonts are similar to the (in)famous Helvetica,
Times and Courier fonts.
Homepage: https://savannah.gnu.org/projects/freefont/
[quote=“sidell”]Bonjour, je voudrais installer les équivalents libres des polices les plus utilisées.
J’hésite entre deux paquets ttf-liberation et ttf-freefont. Je ne vois pas la différence entre les deux paquets et ne sait donc pas lequel installé.[/quote] N’hésites pas se sont deux paquets avec des polices différentes.
