bon ben c’est toujours pas ca
le make distclean et le make mrproper me renvoient “pas de regles pour fabriquer la cible. arret”
le make clean s’execute mais renvoie des erreures semblables a celles du make linux-dri-x86 précedent.
et le nouveau make linux-dri-x86 ne fonctionne toujours pas (même problème)
not in ../../../../../src/mesa/transform/stddef.h
not in ../../../../../src/mesa/shader/stddef.h
not in ../../../../../src/mesa/swrast/stddef.h
not in ../../../../../src/mesa/swrast_setup/stddef.h
not in ../../../../../src/egl/main/stddef.h
not in ../../../../../src/egl/drivers/dri/stddef.h
not in /usr/include/drm/stddef.h
not in /usr/include/stddef.h
makedepend: warning: ../../common/driverfuncs.c (reading ../../../../../src/mesa/main/glheader.h, line 72): cannot find include file "float.h"
not in ./float.h
not in ../../../../../src/mesa/drivers/dri/common/float.h
not in server/float.h
not in ../../../../../include/float.h
not in ../../../../../include/GL/internal/float.h
not in ../../../../../src/mesa/float.h
not in ../../../../../src/mesa/main/float.h
not in ../../../../../src/mesa/glapi/float.h
not in ../../../../../src/mesa/math/float.h
not in ../../../../../src/mesa/transform/float.h
not in ../../../../../src/mesa/shader/float.h
not in ../../../../../src/mesa/swrast/float.h
not in ../../../../../src/mesa/swrast_setup/float.h
not in ../../../../../src/egl/main/float.h
not in ../../../../../src/egl/drivers/dri/float.h
not in /usr/include/drm/float.h
not in /usr/include/float.h
makedepend: warning: ../../common/driverfuncs.c (reading ../../../../../src/mesa/main/glheader.h, line 73): cannot find include file "stdarg.h"
not in ./stdarg.h
not in ../../../../../src/mesa/drivers/dri/common/stdarg.h
not in server/stdarg.h
not in ../../../../../include/stdarg.h
not in ../../../../../include/GL/internal/stdarg.h
not in ../../../../../src/mesa/stdarg.h
not in ../../../../../src/mesa/main/stdarg.h
not in ../../../../../src/mesa/glapi/stdarg.h
not in ../../../../../src/mesa/math/stdarg.h
not in ../../../../../src/mesa/transform/stdarg.h
not in ../../../../../src/mesa/shader/stdarg.h
not in ../../../../../src/mesa/swrast/stdarg.h
not in ../../../../../src/mesa/swrast_setup/stdarg.h
not in ../../../../../src/egl/main/stdarg.h
not in ../../../../../src/egl/drivers/dri/stdarg.h
not in /usr/include/drm/stdarg.h
not in /usr/include/stdarg.h
makedepend: warning: ../../common/driverfuncs.c (reading /usr/include/inttypes.h, line 38): cannot find include file "stddef.h"
not in ./stddef.h
not in ../../../../../src/mesa/drivers/dri/common/stddef.h
not in server/stddef.h
not in ../../../../../include/stddef.h
not in ../../../../../include/GL/internal/stddef.h
not in ../../../../../src/mesa/stddef.h
not in ../../../../../src/mesa/main/stddef.h
not in ../../../../../src/mesa/glapi/stddef.h
not in ../../../../../src/mesa/math/stddef.h
makedepend: warning: ../../common/driverfuncs.c (reading ../../../../../include/GL/glext.h, line 3044): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: ../common/utils.c (reading /usr/include/drm/drm.h), line 196: # warning "__SIZE_TYPE__ not defined. Assuming sizeof(size_t) == sizeof(unsigned long)!"
makedepend: warning: ../common/vblank.c (reading /usr/include/unistd.h, line 195): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: ../common/dri_util.c, line 20: cannot find include file "stdarg.h"
not in ./stdarg.h
makedepend: warning: ../common/dri_util.c (reading /usr/include/sys/mman.h, line 26): cannot find include file "stddef.h"
not in ./stddef.h
make[4]: quittant le répertoire « /root/Mesa/src/mesa/drivers/dri/ffb »
make[4]: entrant dans le répertoire « /root/Mesa/src/mesa/drivers/dri/ffb »
rm -f *.o */*.o *~ *.so *~ server/*.o
rm -f depend depend.bak
rm -f common/*.o
make[3]: quittant le répertoire « /root/Mesa/src/mesa/drivers/dri »
(cd x86 ; make clean)
make[3]: entrant dans le répertoire « /root/Mesa/src/mesa/x86 »
rm -f matypes.h gen_matypes
make[3]: quittant le répertoire « /root/Mesa/src/mesa/x86 »
(cd x86-64 ; make clean)
make[3]: entrant dans le répertoire « /root/Mesa/src/mesa/x86-64 »
rm -f matypes.h
make[3]: quittant le répertoire « /root/Mesa/src/mesa/x86-64 »
make[2]: quittant le répertoire « /root/Mesa/src/mesa »
make[2]: entrant dans le répertoire « /root/Mesa/src/glu »
make[3]: entrant dans le répertoire « /root/Mesa/src/glu/sgi »
rm -f *.o */*.o */*/*.o
rm -f *.lo */*.lo */*/*.lo
rm -f *.la */*.la */*/*.la
make[3]: quittant le répertoire « /root/Mesa/src/glu/sgi »
make[2]: quittant le répertoire « /root/Mesa/src/glu »
make[2]: entrant dans le répertoire « /root/Mesa/src/glut/glx »
Makefile:120: depend: Aucun fichier ou répertoire de ce type
running makedepend
makedepend: warning: glut_8x13.c (reading ../../../include/GL/glext.h, line 3044): cannot find include file "stddef.h"
not in ../../../include/stddef.h
makedepend: warning: glut_bitmap.c (reading /usr/include/bits/types.h, line 31): cannot find include file "stddef.h"
makedepend: warning: glut_bitmap.c (reading /usr/include/sys/types.h, line 147): cannot find include file "stddef.h"
makedepend: warning: glut_bitmap.c (reading /usr/include/X11/Xlib.h, line 75): cannot find include file "stddef.h"
makedepend: warning: glut_cindex.c (reading /usr/include/stdlib.h, line 33): cannot find include file "stddef.h"
makedepend: warning: glut_cindex.c (reading /usr/include/alloca.h, line 25): cannot find include file "stddef.h"
makedepend: warning: glut_cmap.c (reading /usr/include/string.h, line 33): cannot find include file "stddef.h"
makedepend: warning: glut_cmap.c (reading /usr/include/stdio.h, line 34): cannot find include file "stddef.h"
makedepend: warning: glut_cmap.c (reading /usr/include/_G_config.h, line 14): cannot find include file "stddef.h"
makedepend: warning: glut_cmap.c (reading /usr/include/wchar.h, line 48): cannot find include file "stddef.h"
makedepend: warning: glut_cmap.c (reading /usr/include/gconv.h, line 31): cannot find include file "stddef.h"
makedepend: warning: glut_cmap.c (reading /usr/include/libio.h, line 53): cannot find include file "stdarg.h"
not in ../../../include/stdarg.h
makedepend: warning: glut_event.c (reading /usr/include/unistd.h, line 195): cannot find include file "stddef.h"
makedepend: warning: glut_util.c, line 9: cannot find include file "stdarg.h"
makedepend: warning: glut_warp.c, line 9: cannot find include file "stdarg.h"
make[2]: quittant le répertoire « /root/Mesa/src/glut/glx »
rm -f *.o *~
rm -f *.lo
rm -f *.la
rm -rf .libs
rm -rf depend depend.bak
make[2]: entrant dans le répertoire « /root/Mesa/src/glw »
Makefile:57: depend: Aucun fichier ou répertoire de ce type
touch depend
makedepend -fdepend -I../../include GLwDrawA.c \
> /dev/null
makedepend: warning: GLwDrawA.c (reading /usr/include/bits/types.h, line 31): cannot find include file "stddef.h"
not in ../../include/stddef.h
makedepend: warning: GLwDrawA.c (reading /usr/include/sys/types.h, line 147): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/X11/Xlib.h, line 75): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/string.h, line 33): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/X11/Intrinsic.h, line 93): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading ../../include/GL/glext.h, line 3044): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/stdio.h, line 34): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/_G_config.h, line 14): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/wchar.h, line 48): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/gconv.h, line 31): cannot find include file "stddef.h"
makedepend: warning: GLwDrawA.c (reading /usr/include/libio.h, line 53): cannot find include file "stdarg.h"
not in ../../include/stdarg.h
make[2]: quittant le répertoire « /root/Mesa/src/glw »
rm depend depend.bak
rm -f *.o *~
make[1]: quittant le répertoire « /root/Mesa/src »
make[1]: entrant dans le répertoire « /root/Mesa/progs »
make[2]: entrant dans le répertoire « /root/Mesa/progs/tests »
rm -f afsmultiarb antialias arbfpspec arbfptest1 arbfptexture arbfptrig arbnpot arbvptest1 arbvptest3 arbvptorus arbvpwarpmesh blendminmax blendsquare bufferobj bug_3050 bug_3101 bug_3195 copypixrate crossbar cva dinoshade floattex fbotest1 fbotest2 fbotexture fog fogcoord fptest1 fptexture getprocaddress interleave invert jkrahntest manytex mipmap_limits multipal no_s3tc packedpixels pbo projtex readrate seccolor sharedtex stencilwrap stencil_wrap subtexrate tex1d texcompress2 texfilt texline texobjshare texrect texwrap vao-01 vao-02 vparray vptest1 vptest2 vptest3 vptorus vpwarpmesh yuvrect yuvsquare zreaddraw
rm -f *.o
rm -f getproclist.h
make[2]: quittant le répertoire « /root/Mesa/progs/tests »
make[1]: quittant le répertoire « /root/Mesa/progs »
laptop:~/Mesa# make linux-dri-x86
(cd configs && rm -f current && ln -s linux-dri-x86 current)
make default
make[1]: entrant dans le répertoire « /root/Mesa »
make[2]: entrant dans le répertoire « /root/Mesa/src »
Making sources for linux-dri-x86
make[3]: entrant dans le répertoire « /root/Mesa/src/glx/x11 »
Makefile:95: depend: Aucun fichier ou répertoire de ce type
touch depend
makedepend -fdepend -I. -I../../../include -I../../../include/GL/internal -I../../../src/mesa/main -I../../../src/mesa/glapi -I../../../src/mesa/drivers/dri/common `pkg-config --cflags libdrm` -I/usr/X11R6/include glcontextmodes.c clientattrib.c compsize.c eval.c glxcmds.c glxext.c glxextensions.c indirect.c indirect_init.c indirect_size.c indirect_window_pos.c indirect_transpose_matrix.c indirect_vertex_array.c indirect_vertex_program.c pixel.c pixelstore.c render2.c renderpix.c single2.c singlepix.c vertarr.c xfont.c glx_pbuffer.c glx_query.c glx_texture_compression.c dri_glx.c XF86dri.c \
../../../src/mesa/main/dispatch.c ../../../src/mesa/glapi/glapi.c ../../../src/mesa/glapi/glthread.c ../../../src/mesa/x86/glapi_x86.S
makedepend: warning: glcontextmodes.c (reading /usr/include/bits/types.h, line 31): cannot find include file "stddef.h"
not in ./stddef.h
not in ../../../include/GL/internal/stddef.h
not in ../../../src/mesa/main/stddef.h
not in ../../../src/mesa/glapi/stddef.h
not in ../../../src/mesa/drivers/dri/common/stddef.h
not in /usr/X11R6/include/stddef.h
makedepend: warning: glcontextmodes.c (reading /usr/include/sys/types.h, line 147): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: glcontextmodes.c (reading /usr/include/X11/Xlib.h, line 75): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: glcontextmodes.c (reading ../../../include/GL/glext.h, line 3044): cannot find include file "stddef.h" not in ./stddef.h
makedepend: warning: glcontextmodes.c (reading /usr/include/string.h, line 33): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: glcontextmodes.c (reading /usr/include/stdlib.h, line 33): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: glcontextmodes.c (reading /usr/include/alloca.h, line 25): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: glcontextmodes.c (reading /usr/include/X11/Xlibint.h, line 346): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: clientattrib.c (reading /usr/include/stdio.h, line 34): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: clientattrib.c (reading /usr/include/_G_config.h, line 14): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: clientattrib.c (reading /usr/include/wchar.h, line 48): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: clientattrib.c (reading /usr/include/gconv.h, line 31): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: clientattrib.c (reading /usr/include/libio.h, line 53): cannot find include file "stdarg.h"
not in ./stdarg.h
not in ../../../include/GL/internal/stdarg.h
not in ../../../src/mesa/main/stdarg.h
not in ../../../src/mesa/glapi/stdarg.h
not in ../../../src/mesa/drivers/dri/common/stdarg.h
not in /usr/X11R6/include/stdarg.h
makedepend: warning: glxcmds.c (reading /usr/include/inttypes.h, line 38): cannot find include file "stddef.h"
not in ./stddef.h
makedepend: warning: glxcmds.c (reading /usr/include/limits.h, line 124): cannot find include file "limits.h"
makedepend: warning: glxcmds.c (reading ../../../src/mesa/main/glheader.h, line 72): cannot find include file "float.h"
not in ./float.h
not in ../../../include/float.h
not in ../../../include/GL/internal/float.h
not in ../../../src/mesa/main/float.h
not in ../../../src/mesa/glapi/float.h
not in ../../../src/mesa/drivers/dri/common/float.h
not in /usr/X11R6/include/float.h
makedepend: warning: glxcmds.c (reading ../../../src/mesa/main/glheader.h, line 73): cannot find include file "stdarg.h"
not in ./stdarg.h
makedepend: warning: XF86dri.c (reading /usr/include/drm/drm.h), line 196: # warning "__SIZE_TYPE__ not defined. Assuming sizeof(size_t) == sizeof(unsigned long)!"
make[3]: quittant le répertoire « /root/Mesa/src/glx/x11 »
gcc -c -I. -I../../../include -I../../../include/GL/internal -I../../../src/mesa/main -I../../../src/mesa/glapi -I../../../src/mesa/drivers/dri/common `pkg-config --cflags libdrm` -I/usr/X11R6/include -Wall -Wmissing-prototypes -std=c99 -ffast-math -O -g -m32 -D_POSIX_SOURCE -D_POSIX_C_SOURCE=199309L -D_SVID_SOURCE -D_BSD_SOURCE -D_GNU_SOURCE -DPTHREADS -DUSE_EXTERNAL_DXTN_LIB=1 -DIN_DRI_DRIVER -DGLX_DIRECT_RENDERING -DHAVE_ALIAS -DUSE_X86_ASM -DUSE_MMX_ASM -DUSE_3DNOW_ASM -DUSE_SSE_ASM -DXF86VIDMODE -D_REENTRANT -UIN_DRI_DRIVER -DDEFAULT_DRIVER_DIR=\"/usr/X11R6/lib/modules/dri\" glcontextmodes.c -o glcontextmodes.o
gcc -c -I. -I../../../include -I../../../include/GL/internal -I../../../src/mesa/main -I../../../src/mesa/glapi -I../../../src/mesa/drivers/dri/common `pkg-config --cflags libdrm` -I/usr/X11R6/include -Wall -Wmissing-prototypes -std=c99 -ffast-math -O -g -m32 -D_POSIX_SOURCE -D_POSIX_C_SOURCE=199309L -D_SVID_SOURCE -D_BSD_SOURCE -D_GNU_SOURCE -DPTHREADS -DUSE_EXTERNAL_DXTN_LIB=1 -DIN_DRI_DRIVER -DGLX_DIRECT_RENDERING -DHAVE_ALIAS -DUSE_X86_ASM -DUSE_MMX_ASM -DUSE_3DNOW_ASM -DUSE_SSE_ASM -DXF86VIDMODE -D_REENTRANT -UIN_DRI_DRIVER -DDEFAULT_DRIVER_DIR=\"/usr/X11R6/lib/modules/dri\" clientattrib.c -o clientattrib.ogcc -c -I. -I../../../include -I../../../include/GL/internal -I../../../src/mesa/main -I../../../src/mesa/glapi -I../../../src/mesa/drivers/dri/common `pkg-config --cflags libdrm` -I/usr/X11R6/include -Wall -Wmissing-prototypes -std=c99 -ffast-math -O -g -m32 -D_POSIX_SOURCE -D_POSIX_C_SOURCE=199309L -D_SVID_SOURCE -D_BSD_SOURCE -D_GNU_SOURCE -DPTHREADS -DUSE_EXTERNAL_DXTN_LIB=1 -DIN_DRI_DRIVER -DGLX_DIRECT_RENDERING -DHAVE_ALIAS -DUSE_X86_ASM -DUSE_MMX_ASM -DUSE_3DNOW_ASM -DUSE_SSE_ASM -DXF86VIDMODE -D_REENTRANT -UIN_DRI_DRIVER -DDEFAULT_DRIVER_DIR=\"/usr/X11R6/lib/modules/dri\" compsize.c -o compsize.o
gcc -c -I. -I../../../include -I../../../include/GL/internal -I../../../src/mesa/main -I../../../src/mesa/glapi -I../../../src/mesa/drivers/dri/common `pkg-config --cflags libdrm` -I/usr/X11R6/include -Wall -Wmissing-prototypes -std=c99 -ffast-math -O -g -m32 -D_POSIX_SOURCE -D_POSIX_C_SOURCE=199309L -D_SVID_SOURCE -D_BSD_SOURCE -D_GNU_SOURCE -DPTHREADS -DUSE_EXTERNAL_DXTN_LIB=1 -DIN_DRI_DRIVER -DGLX_DIRECT_RENDERING -DHAVE_ALIAS -DUSE_X86_ASM -DUSE_MMX_ASM -DUSE_3DNOW_ASM -DUSE_SSE_ASM -DXF86VIDMODE -D_REENTRANT -UIN_DRI_DRIVER -DDEFAULT_DRIVER_DIR=\"/usr/X11R6/lib/modules/dri\" eval.c -o eval.o
gcc -c -I. -I../../../include -I../../../include/GL/internal -I../../../src/mesa/main -I../../../src/mesa/glapi -I../../../src/mesa/drivers/dri/common `pkg-config --cflags libdrm` -I/usr/X11R6/include -Wall -Wmissing-prototypes -std=c99 -ffast-math -O -g -m32 -D_POSIX_SOURCE -D_POSIX_C_SOURCE=199309L -D_SVID_SOURCE -D_BSD_SOURCE -D_GNU_SOURCE -DPTHREADS -DUSE_EXTERNAL_DXTN_LIB=1 -DIN_DRI_DRIVER -DGLX_DIRECT_RENDERING -DHAVE_ALIAS -DUSE_X86_ASM -DUSE_MMX_ASM -DUSE_3DNOW_ASM -DUSE_SSE_ASM -DXF86VIDMODE -D_REENTRANT -UIN_DRI_DRIVER -DDEFAULT_DRIVER_DIR=\"/usr/X11R6/lib/modules/dri\" glxcmds.c -o glxcmds.o
glxcmds.c:51:38: error: X11/extensions/xf86vmode.h: Aucun fichier ou répertoire de ce type
glxcmds.c: In function ‘glXGetMscRateOML’:
glxcmds.c:2275: error: ‘XF86VidModeModeLine’ undeclared (first use in this function)
glxcmds.c:2275: error: (Each undeclared identifier is reported only once
glxcmds.c:2275: error: for each function it appears in.)
glxcmds.c:2275: error: expected ‘;’ before ‘mode_line’
glxcmds.c:2283: warning: implicit declaration of function ‘XF86VidModeQueryVersion’
glxcmds.c:2284: warning: implicit declaration of function ‘XF86VidModeGetModeLine’
glxcmds.c:2285: error: ‘mode_line’ undeclared (first use in this function)
make[3]: *** [glxcmds.o] Erreur 1
make[2]: *** [subdirs] Erreur 1
make[2]: quittant le répertoire « /root/Mesa/src »
make[1]: *** [default] Erreur 1
make[1]: quittant le répertoire « /root/Mesa »
make: *** [linux-dri-x86] Erreur 2
