Portable toshiba en bi-écran
Bonjour.
J’ai un second écran sur mon portable Toshiba Satellite.
J’aimerai bien faire du dual-screen, mais lorsque je branche le deuxième écran, celui intégré au portable s’éteint.
Voici le xorg.conf :
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
	FontPath	"/usr/share/fonts/X11/misc"
	FontPath	"/usr/X11R6/lib/X11/fonts/misc"
	FontPath	"/usr/share/fonts/X11/cyrillic"
	FontPath	"/usr/X11R6/lib/X11/fonts/cyrillic"
	FontPath	"/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/Type1"
	FontPath	"/usr/X11R6/lib/X11/fonts/Type1"
	FontPath	"/usr/share/fonts/X11/100dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi"
	FontPath	"/usr/share/fonts/X11/75dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi"
	# path to defoma fonts
	FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load	"i2c"
	Load	"bitmap"
	Load	"ddc"
	Load	"dri"
	Load	"extmod"
	Load	"freetype"
	Load	"glx"
	Load	"int10"
	Load	"vbe"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"fr"
	Option		"XkbVariant"	"latin9"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ImPS/2"
	Option		"Emulate3Buttons"	"true"
EndSection
	Identifier	"Synaptics Touchpad"
	Driver		"synaptics"
	Option		"SendCoreEvents"	"true"
	Option		"Device"		"/dev/psaux"
	Option		"Protocol"		"auto-dev"
	Option		"HorizScrollDelta"	"0"
EndSection
Section "Device"
	Identifier	"nVidia Corporation NV17 [GeForce4 420 Go]"
	Driver		"nv"
	BusID		"PCI:1:0:0"
EndSection
Section "Monitor"
	Identifier	"Écran générique"
	Option		"DPMS"
	HorizSync	28-51
	VertRefresh	43-60
  Gamma   1.00  1.00  1.00  # created by KGamma
EndSection
Section "Monitor"
	Identifier	"ASUS MM17T"
	Option		"DPMS"
  Gamma   0.00  0.00  0.00  # created by KGamma
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"nVidia Corporation NV17 [GeForce4 420 Go]"
	Monitor		"Écran générique"
	DefaultDepth	24
	SubSection "Display"
		Depth		1
		Modes		"1024x768"
	EndSubSection
		Depth		4
		Modes		"1024x768"
	EndSubSection
		Depth		8
		Modes		"1024x768"
	EndSubSection
		Depth		15
		Modes		"1024x768"
	EndSubSection
		Depth		16
		Modes		"1024x768"
	EndSubSection
		Depth		24
		Modes		"1024x768"
	EndSubSection
EndSection
Section "Screen"
	Identifier	"ASUS Screen"
	Monitor		"ASUS MM17T"
	DefaultDepth	24
		Depth		1
		Modes		"1024x768"
	EndSubSection
		Depth		4
		Modes		"1024x768"
	EndSubSection
		Depth		8
		Modes		"1024x768"
	EndSubSection
		Depth		15
		Modes		"1024x768"
	EndSubSection
		Depth		16
		Modes		"1024x768"
	EndSubSection
		Depth		24
		Modes		"1280x1024"
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier      "Default Layout"
        Screen	0	"Default Screen"
	Screen	1	"ASUS Screen"
	Option "xinerama" "off"
        Option "clone" "on"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
	InputDevice	"Synaptics Touchpad"
EndSection
Section "DRI"
	Mode	0666
EndSection
Merci :slightly_smiling:
C’est un problème “classique” que l’on rencontre lorsqu’on veut connecter un 2ème écran ou un vidéoprojecteur.
Regarde ICI
Génial !!! Merci :slightly_smiling:
