je suis retourné a la fnac a Nancy ce matin, j’ai noté 2 références :
le vaio vgn-sz1m\b
Processeur Intel Core Duo
Fréquence 1.67 GHz
Quantité de RAM 512 Mo
Type de RAM DDR2-SDRAM
Disque dur 80 Go
Vitesse de rotation du disque dur 5400 tours/minute
Puce graphique nVIDIA GeForce 7400 Turbo Cache
Taille mémoire graphique 128 Mo
Type de puce graphique Intégrée
Taille d'écran 13.3"
Résolution 1280x800
Lecteur CD/DVD Graveur DVD
Vitesse NC
Lecteur disquettes Non
Connectique 2 ports USB 2.0, 1 PCMCIA Type II, Wifi, 1 port FireWire, VGA, ExpressCard/34
Carte réseau 10/100 10/100
Modem 56k Oui
Autonomie moyenne 6h00
Système d'exploitation Windows XP Home
Poids 1.7 kg[/code]
acer tm 3012wlm4
[code] * Mfr Part Number: TM3012WTMI/LX.TAT06.045
* Processor: Intel Core Duo Processor T2300 (1.66GHz, 2MB L2 cache, FSB 667MHz)
* Chipset: Mobile Intel 945GM Express
* Memory: 512MB (1x 512, 2 slots total) DDR2-533 SDRAM; Max capacity 2GB
* Display: 12.1" WXGA (1280 x 800) TFT LCD, Upto 16.7 million colors
* Graphics & Video Module: Intel Graphics Media Accelerator 950
* Hard Disk Drive: 80GB SATA hard disk drive, 5400 RPM
* Optical Storage Device: External Super-Multi DVD-RW drive (DVD+R, DVD-R, DVD-RAM)
* Connectivity: Intel PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN; Bluetooth wireless PAN; Gigabit LAN; V.92 56Kbps data/fax modem
* Card Reader: 5-in-1 card reader (For MultiMediaCard, Secure Digital card, Memory Stick, Memory Stick PRO or xD-Picture Card)
* Camera: Acer OrbiCam integrated 1.3 megapixel CMOS camera with 225° rotation
* Interface: 3x USB 2.0; FireWire (IEEE 1394); RJ-11 modem; RJ-45 LAN; VGA; Headphones/speakers/line-out with SPDIF support; Microphone/line-in; FIR (fast infrared); Type II PC Card slot
* Audio: Integrated microphone and two speakers
* Battery Pack & life: 2x lithium ion batteries (not hot swappable): 6-cell - upto 3.0 hours life; 3-cell - upto 2.0 hours life
* AC Adapter: 65-watt AC adapter
* Dimensions: 11.7 x 8.3 x 1.0~1.3 inch / 297.5 x 210.0 x 24.5~32.4 mm
* Weight: 3.3 lbs / 1.5 kg (with three-cell battery and without external optical drive)
* Operating System: Microsoft Windows XP Professional
histoire de vous faire rire, voila la petite “discution” que j’ai eu avec le vendeur:
donc voila
, aux dernière nouvelles, laGeForce 7400 ne fait pas l’openGL…
franchement, moi qui cherche du travail, j’aurrai bien voulu le faire virer pour prendre sa place : / c’est abérant : /
enfin, je vais maintenant voir les pages que vous m’avez données, si ca me revient moins cher, je pourrai me faire un pc encore plus puissant, mais je ne savais pas qu’on pouvait faire des portables sur mesure…
Damsss > pour le poids, c’est pour ca que je cherche un ultra portable, moins c’est lourd, plus il y a d’autonomie… (je pense que cette equation est presque toujours valable concernant l’electronique)
bluenote> je veux bien le numéro
merci
MattoTop > je vais voir ce site , merci
fran.b> je vais tenter aussi la prochaine fois, avec ubuntu live cd…
pour savoir si debian est installable, il vaut mieu tester avec knoppix ou ubuntu live cd ?
