Post a supprimer
Voilà j’aimerai me mettre en wifi sur mon PC portable qui est un “Sony VAIO VGN-N38Z” mais je ne sais pas comment faire, donc si quelqu’un pourrai m’expliquer ça serai gentil :smiley:
Merci,
FreKo`
Et bien tu donnes la version de ton kernel
Le résultat de lspci et lsusb
Salut debianhadic,
Alors voici pour lspci :
[quote]00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #3 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) Serial ATA Storage Controller IDE (rev 02)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8036 PCI-E Fast Ethernet Controller (rev 16)
06:00.0 Ethernet controller: Atheros Communications, Inc. Unknown device 001c (rev 01)
08:03.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
08:03.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller
08:03.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
et pour lsusb :
[quote]Bus 004 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bon j’ai l’impression que c’est ça :
Donc tu regardes ce qu’il y a de dispo :
~$ apt-cache search atheros
madwifi-doc - documentation for the Multiband Atheros Driver for WiFi
atl2-modules-2.6-amd64 - Driver for the Atheros L2 Fast Ethernet Adapter modules for Linux 2.6 on AMD64
atl2-modules-2.6.24-1-amd64 - Driver for the Atheros L2 Fast Ethernet Adapter modules for Linux 2.6.24 on AMD64
atl2-source - Linux Base Driver for the Atheros(R) L2 Fast Ethernet Adapter
hostapd - user space IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
madwifi-tools - tools for the Multiband Atheros Driver for WiFi
madwifi-source - source for the Multiband Atheros Driver for WiFi
Et la my godness, madwifi c’est pas mal ça non ?
# apt-get install module-assistant
# m-a prepare
# m-a a-i -i madwifi-source
# apt-get install wireless-tools
# apt-get install madwifi-tools
et la dans Système/Administration il devrait y avoir le nécessaire pour jouer avec ton wifi.
merci debianhadic, donc si j’ai bien compris j’ai juste à faire ceci :
[quote]# apt-get install module-assistant
m-a prepare
apt-get install madwifi-tools[/quote]
Si tout se passe bien, oui !
J’ai un petit soucis au moment ou je tape la commande [quote]aptitude m-a a-i -i madwifi-source[/quote]
ça me donne ceci :
[quote]debian-desktop:/home/jonathan# m-a a-i -i madwifi-source
Données de 1 paquets mises à jour
Récupération des sources du noyau de la version : 2.6.18-6-686
En-têtes du noyau disponibles dans /lib/modules/2.6.18-6-686/build
Création du lien symbolique…
apt-get-y install build-essential
Fait.
download
E: Impossible de trouver le paquet madwifi-source
Échec de l’installation des sources de madwifi-source.
Paquet ignoré. Vous devez peut-être ajouter quelque chose à sources.list, comme
les archives « contrib » et « non-free ».
Mise à jour des données de madwifi-source
ton sources.list ?
Voici ce que j’ai dans mon sources.list
[quote] GNU nano 2.0.2 Fichier : /etc/apt/sources.list
deb cdrom:[Debian GNU/Linux 4.0 r3 Etch - Official i386 NETINST Binary-1 20$
deb ftp.fr.debian.org/debian/ etch main
deb-src ftp.fr.debian.org/debian/ etch main
deb security.debian.org/ etch/updates main contrib
deb-src security.debian.org/ etch/updates main contrib
C’est vrai qu’il est pas beaucoup remplit :angry:
Déjà remplace le par ça :
deb http://ftp.fr.debian.org/debian/ etch main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ etch main contrib non-free
deb http://security.debian.org/ etch/updates main contrib
deb-src http://security.debian.org/ etch/updates main contrib
ensuite
# apt-get update
et tu recommences.
Voilà j’ai installé tout ce que tu m’as dit, mais par contre je ne voit pas d’onglet pour régler mon wifi, mon interface est XFCE.
Oula … Ouvre un autre fil avec XFCE dans le titre ! :wink:
Ok, alors si un administrateur peut supprimer ce sujet svp.
MERCI.
