bonjour,
je doit installer un serveur mail sous ubuntu server.
je viens d’installer postfix, et j’ai testé l’installation en localhost et à distance, tout marchait bien.
la deuxieme etape consiste à lutter contre le spam basique par la configuration de main.cf
[code]#Restrictions
smtpd_helo_required = yes
strict_rfc821_envelopes = yes
Requirements for the HELO statement
smtpd_helo_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
reject_non_fqdn_hostname,
reject_invalid_hostname,
permit
#Requirements for the sender details
smtpd_sender_restrictions =
permit_mynetworks,
reject_non_fqdn_sender,
reject_unknown_sender_domain,
reject_unauth_pipelining,
reject_unauth_destination,
permit
#Requirements for the connecting server
smtpd_client_restrictions =
permit_mynetworks,
reject_rbl_client sbl-xbl.spamhaus.org,
reject_rbl_client list.dsbl.org,
permit
#requirement for the recipient address
smtpd_recipient_restrictions=
permit_mynetworks,
reject_non_fqdn_recipient,
reject_unknown_recipient_domain,
permit[/code]
et j’ai rechargé postfix,
just apres j’ai installé le paquet amavisd-new.
dans le fichier /etc/postfix/master.cf j’ai remplacé la ligne smtp inet du debut du fichier par :smtp inet n - - - - smtpd
-o content_filter=amavis:[127.0.0.1]:10024
et à la fin du fichier j’ai rajouté les lignes suivantes:
amavis unix - - - - 10 smtp
-o smtp_data_done_timeout=1200
-o smtp_send_xforward_command=yes
-o disable_dns_lookups=yes
-o max_use=20
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o local_recipient_maps=
-o relay_recipient_maps=
-o smtpd_restriction_classes=
-o smtpd_delay_reject=no
-o smtpd_client_restrictions=permit_mynetworks,reject
-o smtpd_helo_restrictions=
-o smtpd_sender_restrictions=
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o smtpd_data_restrictions=reject_unauth_pipelining
-o smtpd_end_of_data_restrictions=
-o mynetworks=127.0.0.0/8
-o smtpd_error_sleep_time=0
-o smtpd_soft_error_limit=1001
-o smtpd_hard_error_limit=1000
-o smtpd_client_connection_count_limit=0
-o smtpd_client_connection_rate_limit=0
-o receive_override_options= no_header_body_checks,no_unknown_recipient_checks
et je recharge postfix;
justapres j’ai testé : l’envoie de mail en local marche bien, l’envpoie de mail à l’exterieur ne marche pas.
aidez moi à corriger le probleme, c’est urgent.
merci.
[/quote]+1 :smt003
