Bonjour a tous
j’ai installé un serveur de messagerie dovecot avec postfix et postfixadmin. Comme Webmail j’ai installé Roundcube. via le Webmail envois de réception de mails ok
par contre quand j’essaie de configurer ma boite sur Thunderbird impossible de me connecter au serveur. Dans le mail.log j’ai un message :
dovecot: pop3-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=XX.XXX.XX.XXX, lip=XX.XXX.XX.XXX, session=<1QMFyHsS0wBO71Kd>
dovecot: imap-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=XX.XXX.XX.XXX, lip=XX.XXX.XX.XXX, session=<EAQFyHsS0gBO71Kd>
dovecot: imap-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=XX.XXX.XX.XXX, lip=XX.XXX.XX.XXX, session=<1wkFyHsS0ABO71Kd>
dovecot: pop3-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=XX.XXX.XX.XXX, lip=XX.XXX.XX.XXX, session=<6gkFyHsS0QBO71Kd>
j’ai rien trouvé sur les forums qui correspond à mon souci…
je vous joins mon dovecot -n# OS: Linux 3.14.32-xxxx-grs-ipv6-64 x86_64 ext4
auth_mechanisms = plain login
first_valid_uid = 5000
last_valid_uid = 5000
mail_gid = vmail
mail_location = maildir:/var/spool/vmail/%d/%n
mail_uid = vmail
namespace inbox {
inbox = yes
location =
mailbox Drafts {
special_use = \Drafts
mailbox Junk {
special_use = \Junk
mailbox Sent {
special_use = \Sent
mailbox "Sent Messages" {
special_use = \Sent
mailbox Trash {
special_use = \Trash
prefix =
passdb {
args = /etc/dovecot/dovecot-sql.conf.ext
driver = sql
protocols = " imap pop3"
service auth {
unix_listener /var/spool/postfix/private/auth {
group = postfix
mode = 0666
user = postfix
unix_listener auth-userdb {
group = vmail
mode = 0600
user = vmail
ssl_cert = </etc/ssl/certs/dovecot.pem
ssl_key = </etc/ssl/private/dovecot.pem
userdb {
driver = sql
protocol imap {
mail_plugins = " autocreate"
plugin {
autocreate = Trash
autocreate2 = Junk
autocreate3 = Drafts
autocreate4 = Sent
autosubscribe = Trash
autosubscribe2 = Junk
autosubscribe3 = Drafts
autosubscribe4 = Sent
avez vous une idée de la ou il faut que je cherche ?
Par avance merci.
