J’ai un petit soucis de paramétrage de postfix à priori sur mon dédié (chez online.net). Il est en Debian Wheezy.
Je souhaite utiliser uniquement le smtp et en aucun cas, le pop / imap sur ce serveur.
J’ai suivi le tuto qui est ici, juste au niveau de postfix, je n’ai pas installé Courrier/Squirrelmail, etc.
Voici l’erreur que j’ai dans mon log en tente d’envoyer un mail depuis localhost en telnet sur une adresse externe.
Sep 24 01:09:09 SRV-WEB postfix/anvil[9706]: statistics: max connection rate 1/60s for (smtp:::1) at Sep 24 01:03:28
Sep 24 01:09:09 SRV-WEB postfix/anvil[9706]: statistics: max connection count 1 for (smtp:::1) at Sep 24 01:03:28
Sep 24 01:09:09 SRV-WEB postfix/anvil[9706]: statistics: max cache size 1 at Sep 24 01:03:28
Sep 24 01:09:20 SRV-WEB postfix/master[9493]: terminating on signal 15
Sep 24 01:09:20 SRV-WEB postfix/master[9887]: daemon started -- version 2.9.6, configuration /etc/postfix
Sep 24 01:09:49 SRV-WEB postfix/smtpd[9910]: connect from localhost[::1]
Sep 24 01:10:28 SRV-WEB postfix/proxymap[9911]: warning: connect to mysql server 127.0.0.1: Access denied for user 'mail_admin'@'localhost' (using password: YES)
Sep 24 01:10:28 SRV-WEB postfix/trivial-rewrite[9924]: warning: proxy:mysql:/etc/postfix/mysql-virtual_transports.cf lookup error for "*"
Sep 24 01:10:28 SRV-WEB postfix/trivial-rewrite[9924]: warning: proxy:mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Sep 24 01:10:28 SRV-WEB postfix/trivial-rewrite[9924]: warning: virtual_mailbox_domains lookup failure
Sep 24 01:10:53 SRV-WEB postfix/trivial-rewrite[9924]: warning: proxy:mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Sep 24 01:10:53 SRV-WEB postfix/trivial-rewrite[9924]: warning: virtual_mailbox_domains lookup failure
Sep 24 01:10:53 SRV-WEB postfix/smtpd[9910]: NOQUEUE: reject: RCPT from localhost[::1]: 451 4.3.0 <guillaume@serton.net>: Temporary lookup failure; from=<contact@dmi-corp.fr> to=<guillaume@serton.net> proto=ESMTP helo=<srv-web>
Sep 24 01:11:19 SRV-WEB postfix/smtpd[9910]: disconnect from localhost[::1]
Sep 24 01:14:39 SRV-WEB postfix/anvil[9913]: statistics: max connection rate 1/60s for (smtp:::1) at Sep 24 01:09:49
Sep 24 01:14:39 SRV-WEB postfix/anvil[9913]: statistics: max connection count 1 for (smtp:::1) at Sep 24 01:09:49
Sep 24 01:14:39 SRV-WEB postfix/anvil[9913]: statistics: max cache size 1 at Sep 24 01:09:49
J’ai recontrôler le user/password contenu dans les fichiers conf, et ils sont bon.
Voici le contenu de mon master.cf
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
append_dot_mydomain = no
biff = no
broken_sasl_auth_clients = yes
config_directory = /etc/postfix
html_directory = /usr/share/doc/postfix/html
inet_interfaces = all
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
mydestination = srv-web.dmi-fr.com, localhost, localhost.localdomain
myhostname = srv-web.dmi-fr.com
mynetworks = 127.0.0.0/8
myorigin = /etc/mailname
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
readme_directory = /usr/share/doc/postfix
recipient_delimiter = +
relayhost =
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtpd_use_tls = yes
transport_maps = proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_gid_maps = static:5000
virtual_mailbox_base = /home/vmail
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_limit_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_limit_maps.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_uid_maps = static:5000
postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_overquota_bounce=yes
postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_limit_message="The user you are trying to reach is over quota."
postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_extended=yes
postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_mailbox_limit_override=yes
