Bonjour a tous !
j’essaye de mettre en place un relais smtp avec postfix pour utiliser office 365.
J’ai beau suivre plein de tuto, j’ai toujours cette erreur :
Apr 17 17:20:56 supervision postfix/smtp[23506]: warning: pod51017.outlook.com[157.56.249.214]:587 offered null AUTH mechanism list
Apr 17 17:20:56 supervision postfix/smtp[23506]: certificate verification failed for pod51017.outlook.com[157.56.249.214]:587: untrusted issuer /C=IE/O=Baltimore/OU=CyberTrust/CN=Baltimore CyberTrust Root
j’ai beau configuré et reconfiguré les options sasl, j’arrive a rien.
le main.cf :
[code]# See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = no
TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_tls_auth_only = yes
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
myhostname = supervision.dimsi.local
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = supervision.local, localhost
relayhost = pod51017.outlook.com:587
mynetworks = 127.0.0.0/8 172.16.0.0/24
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = loopback-only
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
smtp_sasl_security_options = noanonymous
smtp_tls_CAfile = /etc/postfix/cacert.pem
smtp_use_tls = yes
smtp_always_send_ehlo = yes
smtp_generic_maps=hash:/etc/postfix/generic
inet_protocols = all
merci d’avance pour toute aide,
N.B
