Merci pour ton conseil, je m’en souviendrai sois en sur.
Voilà mes logs:
Sep 14 13:35:01 mawi postfix/virtual[28283]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:35:02 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28283 exit status 1
Sep 14 13:35:02 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:36:02 mawi postfix/virtual[28284]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:36:03 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28284 exit status 1
Sep 14 13:36:03 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:37:03 mawi postfix/virtual[28285]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:37:04 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28285 exit status 1
Sep 14 13:37:04 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:38:04 mawi postfix/virtual[28286]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:38:05 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28286 exit status 1
Sep 14 13:38:05 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:39:05 mawi postfix/virtual[28295]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:39:06 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28295 exit status 1
Sep 14 13:39:06 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:40:06 mawi postfix/virtual[28296]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:40:07 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28296 exit status 1
Sep 14 13:40:07 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:41:07 mawi postfix/virtual[28297]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:41:08 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28297 exit status 1
Sep 14 13:41:08 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:42:08 mawi postfix/virtual[28298]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:42:09 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28298 exit status 1
Sep 14 13:42:09 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:43:09 mawi postfix/virtual[28300]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:43:10 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28300 exit status 1
Sep 14 13:43:10 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:44:10 mawi postfix/virtual[28302]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:44:11 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28302 exit status 1
Sep 14 13:44:11 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:45:11 mawi postfix/virtual[28303]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:45:12 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28303 exit status 1
Sep 14 13:45:12 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:46:12 mawi postfix/virtual[28304]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:46:13 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28304 exit status 1
Sep 14 13:46:13 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:47:13 mawi postfix/virtual[28305]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:47:14 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28305 exit status 1
Sep 14 13:47:14 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:48:14 mawi postfix/virtual[28306]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:48:15 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28306 exit status 1
Sep 14 13:48:15 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:49:15 mawi postfix/virtual[28307]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:49:16 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28307 exit status 1
Sep 14 13:49:16 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:50:16 mawi postfix/virtual[28308]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:50:17 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28308 exit status 1
Sep 14 13:50:17 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:51:17 mawi postfix/virtual[28310]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:51:18 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28310 exit status 1
Sep 14 13:51:18 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:52:18 mawi postfix/virtual[28311]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:52:19 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28311 exit status 1
Sep 14 13:52:19 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:53:19 mawi postfix/virtual[28312]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:53:20 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28312 exit status 1
Sep 14 13:53:20 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:54:20 mawi postfix/virtual[28313]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:54:21 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28313 exit status 1
Sep 14 13:54:21 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:55:21 mawi postfix/virtual[28315]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:55:22 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28315 exit status 1
Sep 14 13:55:22 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:56:22 mawi postfix/virtual[28316]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:56:23 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28316 exit status 1
Sep 14 13:56:23 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:57:23 mawi postfix/virtual[28317]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:57:24 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28317 exit status 1
Sep 14 13:57:24 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:58:24 mawi postfix/virtual[28319]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:58:25 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28319 exit status 1
Sep 14 13:58:25 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 13:59:25 mawi postfix/virtual[28321]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 13:59:26 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28321 exit status 1
Sep 14 13:59:26 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:00:26 mawi postfix/virtual[28322]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:00:27 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28322 exit status 1
Sep 14 14:00:27 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:01:27 mawi postfix/virtual[28323]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:01:28 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28323 exit status 1
Sep 14 14:01:28 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:02:28 mawi postfix/virtual[28324]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:02:29 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28324 exit status 1
Sep 14 14:02:29 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:03:29 mawi postfix/virtual[28325]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:03:30 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28325 exit status 1
Sep 14 14:03:30 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:04:30 mawi postfix/virtual[28326]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:04:31 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28326 exit status 1
Sep 14 14:04:31 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:05:31 mawi postfix/virtual[28327]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:05:32 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28327 exit status 1
Sep 14 14:05:32 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:06:32 mawi postfix/virtual[28328]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:06:33 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28328 exit status 1
Sep 14 14:06:33 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:07:33 mawi postfix/virtual[28330]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:07:34 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28330 exit status 1
Sep 14 14:07:34 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:08:34 mawi postfix/virtual[28332]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:08:35 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28332 exit status 1
Sep 14 14:08:35 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:09:35 mawi postfix/virtual[28342]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:09:36 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28342 exit status 1
Sep 14 14:09:36 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:10:36 mawi postfix/virtual[28343]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:10:37 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28343 exit status 1
Sep 14 14:10:37 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:11:37 mawi postfix/virtual[28344]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:11:38 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28344 exit status 1
Sep 14 14:11:38 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:12:38 mawi postfix/virtual[28345]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:12:39 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28345 exit status 1
Sep 14 14:12:39 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:13:39 mawi postfix/virtual[28346]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:13:40 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28346 exit status 1
Sep 14 14:13:40 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:14:40 mawi postfix/virtual[28348]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:14:41 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28348 exit status 1
Sep 14 14:14:41 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:15:41 mawi postfix/virtual[28349]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:15:42 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28349 exit status 1
Sep 14 14:15:42 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:16:42 mawi postfix/virtual[28350]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:16:43 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28350 exit status 1
Sep 14 14:16:43 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:17:43 mawi postfix/virtual[28354]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:17:44 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28354 exit status 1
Sep 14 14:17:44 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:18:44 mawi postfix/virtual[28355]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:18:45 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28355 exit status 1
Sep 14 14:18:45 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:19:45 mawi postfix/virtual[28356]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:19:46 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28356 exit status 1
Sep 14 14:19:46 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:20:46 mawi postfix/virtual[28358]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:20:47 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28358 exit status 1
Sep 14 14:20:47 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:21:47 mawi postfix/virtual[28359]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:21:48 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28359 exit status 1
Sep 14 14:21:48 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:22:48 mawi postfix/virtual[28361]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:22:49 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28361 exit status 1
Sep 14 14:22:49 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:23:49 mawi postfix/virtual[28362]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:23:50 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28362 exit status 1
Sep 14 14:23:50 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:24:50 mawi postfix/virtual[28363]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:24:51 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28363 exit status 1
Sep 14 14:24:51 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:25:51 mawi postfix/virtual[28364]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:25:52 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28364 exit status 1
Sep 14 14:25:52 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:26:52 mawi postfix/virtual[28366]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:26:53 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28366 exit status 1
Sep 14 14:26:53 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:27:53 mawi postfix/virtual[28368]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:27:54 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28368 exit status 1
Sep 14 14:27:54 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:28:54 mawi postfix/virtual[28370]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:28:55 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28370 exit status 1
Sep 14 14:28:55 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:29:55 mawi postfix/virtual[28371]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:29:56 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28371 exit status 1
Sep 14 14:29:56 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:30:56 mawi postfix/virtual[28372]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:30:57 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28372 exit status 1
Sep 14 14:30:57 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:31:57 mawi postfix/virtual[28374]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:31:58 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28374 exit status 1
Sep 14 14:31:58 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:32:58 mawi postfix/virtual[28376]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:32:59 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28376 exit status 1
Sep 14 14:32:59 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:33:59 mawi postfix/virtual[28377]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:34:00 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28377 exit status 1
Sep 14 14:34:00 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:35:00 mawi postfix/virtual[28379]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:35:01 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28379 exit status 1
Sep 14 14:35:01 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:36:01 mawi postfix/virtual[28380]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:36:02 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28380 exit status 1
Sep 14 14:36:02 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:37:02 mawi postfix/virtual[28382]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:37:03 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28382 exit status 1
Sep 14 14:37:03 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:38:03 mawi postfix/virtual[28384]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:38:04 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28384 exit status 1
Sep 14 14:38:04 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:39:04 mawi postfix/virtual[28395]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:39:05 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28395 exit status 1
Sep 14 14:39:05 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:40:05 mawi postfix/virtual[28410]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:40:06 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28410 exit status 1
Sep 14 14:40:06 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:41:06 mawi postfix/virtual[28412]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:41:07 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28412 exit status 1
Sep 14 14:41:07 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:42:07 mawi postfix/virtual[28414]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:42:08 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28414 exit status 1
Sep 14 14:42:08 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:43:08 mawi postfix/virtual[28416]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:43:09 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28416 exit status 1
Sep 14 14:43:09 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:44:09 mawi postfix/virtual[28418]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:44:10 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28418 exit status 1
Sep 14 14:44:10 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:45:10 mawi postfix/virtual[28420]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:45:11 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28420 exit status 1
Sep 14 14:45:11 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:46:11 mawi postfix/virtual[28422]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:46:12 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28422 exit status 1
Sep 14 14:46:12 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:47:12 mawi postfix/virtual[28423]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:47:13 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28423 exit status 1
Sep 14 14:47:13 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:48:13 mawi postfix/virtual[28425]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:48:14 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28425 exit status 1
Sep 14 14:48:14 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:49:14 mawi postfix/virtual[28426]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:49:15 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28426 exit status 1
Sep 14 14:49:15 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:50:15 mawi postfix/virtual[28427]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:50:16 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28427 exit status 1
Sep 14 14:50:16 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:51:16 mawi postfix/virtual[28429]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:51:17 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28429 exit status 1
Sep 14 14:51:17 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:52:17 mawi postfix/virtual[28430]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:52:18 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28430 exit status 1
Sep 14 14:52:18 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:53:18 mawi postfix/virtual[28432]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:53:19 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28432 exit status 1
Sep 14 14:53:19 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:54:19 mawi postfix/virtual[28434]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:54:20 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28434 exit status 1
Sep 14 14:54:20 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:55:20 mawi postfix/virtual[28448]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:55:21 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28448 exit status 1
Sep 14 14:55:21 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:56:21 mawi postfix/virtual[28449]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:56:22 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28449 exit status 1
Sep 14 14:56:22 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:57:22 mawi postfix/virtual[28451]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:57:23 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28451 exit status 1
Sep 14 14:57:23 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:58:23 mawi postfix/virtual[28453]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:58:24 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28453 exit status 1
Sep 14 14:58:24 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 14:59:24 mawi postfix/virtual[28456]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 14:59:25 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28456 exit status 1
Sep 14 14:59:25 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:00:25 mawi postfix/virtual[28457]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:00:26 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28457 exit status 1
Sep 14 15:00:26 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:01:26 mawi postfix/virtual[28460]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:01:27 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28460 exit status 1
Sep 14 15:01:27 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:02:27 mawi postfix/virtual[28462]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:02:28 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28462 exit status 1
Sep 14 15:02:28 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:03:28 mawi postfix/virtual[28463]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:03:29 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28463 exit status 1
Sep 14 15:03:29 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:04:29 mawi postfix/virtual[28469]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:04:30 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28469 exit status 1
Sep 14 15:04:30 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:05:30 mawi postfix/virtual[28471]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:05:31 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28471 exit status 1
Sep 14 15:05:31 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:06:31 mawi postfix/virtual[28473]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:06:32 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28473 exit status 1
Sep 14 15:06:32 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:07:32 mawi postfix/virtual[28476]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:07:33 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28476 exit status 1
Sep 14 15:07:33 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:08:33 mawi postfix/virtual[28479]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:08:34 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28479 exit status 1
Sep 14 15:08:34 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:09:34 mawi postfix/virtual[28489]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:09:35 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28489 exit status 1
Sep 14 15:09:35 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:10:35 mawi postfix/virtual[28490]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:10:36 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28490 exit status 1
Sep 14 15:10:36 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:11:36 mawi postfix/virtual[28494]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:11:37 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28494 exit status 1
Sep 14 15:11:37 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:12:37 mawi postfix/virtual[28495]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:12:38 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28495 exit status 1
Sep 14 15:12:38 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:13:38 mawi postfix/virtual[28497]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:13:39 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28497 exit status 1
Sep 14 15:13:39 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:14:39 mawi postfix/virtual[28499]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:14:40 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28499 exit status 1
Sep 14 15:14:40 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:15:40 mawi postfix/virtual[28501]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:15:41 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28501 exit status 1
Sep 14 15:15:41 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:16:41 mawi postfix/virtual[28503]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:16:42 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28503 exit status 1
Sep 14 15:16:42 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:17:42 mawi postfix/virtual[28508]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:17:43 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28508 exit status 1
Sep 14 15:17:43 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:18:43 mawi postfix/virtual[28509]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:18:44 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28509 exit status 1
Sep 14 15:18:44 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:19:44 mawi postfix/virtual[28511]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:19:45 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28511 exit status 1
Sep 14 15:19:45 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:20:45 mawi postfix/virtual[28513]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:20:46 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28513 exit status 1
Sep 14 15:20:46 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:21:46 mawi postfix/virtual[28514]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:21:47 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28514 exit status 1
Sep 14 15:21:47 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:22:47 mawi postfix/virtual[28515]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:22:48 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28515 exit status 1
Sep 14 15:22:48 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:23:48 mawi postfix/virtual[28517]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:23:49 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28517 exit status 1
Sep 14 15:23:49 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:24:49 mawi postfix/virtual[28519]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:24:50 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28519 exit status 1
Sep 14 15:24:50 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:25:50 mawi postfix/virtual[28520]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:25:51 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28520 exit status 1
Sep 14 15:25:51 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:26:51 mawi postfix/virtual[28522]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:26:52 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28522 exit status 1
Sep 14 15:26:52 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:27:52 mawi postfix/virtual[28523]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:27:53 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28523 exit status 1
Sep 14 15:27:53 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:28:53 mawi postfix/virtual[28525]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:28:54 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28525 exit status 1
Sep 14 15:28:54 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:29:54 mawi postfix/virtual[28527]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:29:55 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28527 exit status 1
Sep 14 15:29:55 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:30:55 mawi postfix/virtual[28529]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:30:56 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28529 exit status 1
Sep 14 15:30:56 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:31:56 mawi postfix/virtual[28531]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:31:57 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28531 exit status 1
Sep 14 15:31:57 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:32:57 mawi postfix/virtual[28533]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:32:58 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28533 exit status 1
Sep 14 15:32:58 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:33:58 mawi postfix/virtual[28534]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:33:59 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28534 exit status 1
Sep 14 15:33:59 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:34:59 mawi postfix/virtual[28536]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:35:00 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28536 exit status 1
Sep 14 15:35:00 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:36:00 mawi postfix/virtual[28554]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:36:01 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28554 exit status 1
Sep 14 15:36:01 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:37:01 mawi postfix/virtual[28555]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:37:02 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28555 exit status 1
Sep 14 15:37:02 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:38:02 mawi postfix/virtual[28572]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:38:03 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28572 exit status 1
Sep 14 15:38:03 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:39:03 mawi postfix/virtual[28622]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:39:04 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28622 exit status 1
Sep 14 15:39:04 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:40:04 mawi postfix/virtual[28640]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:40:05 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28640 exit status 1
Sep 14 15:40:05 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:41:05 mawi postfix/virtual[28641]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:41:06 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28641 exit status 1
Sep 14 15:41:06 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:42:06 mawi postfix/virtual[28643]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:42:07 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28643 exit status 1
Sep 14 15:42:07 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:43:07 mawi postfix/virtual[28645]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:43:08 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28645 exit status 1
Sep 14 15:43:08 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:44:08 mawi postfix/virtual[28669]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:44:09 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28669 exit status 1
Sep 14 15:44:09 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:45:09 mawi postfix/virtual[28745]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:45:10 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28745 exit status 1
Sep 14 15:45:10 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:45:43 mawi postfix/postfix-script[28750]: refreshing the Postfix mail system
Sep 14 15:45:43 mawi postfix/master[3075]: reload configuration /etc/postfix
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 4A29021F2A: from=<zongo@univ-ndere.edu.cm>, size=336, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 6A75A21F2B: from=<root@univ-ndere.edu.cm>, size=351, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 3F66621F28: from=<root@univ-ndere.edu.cm>, size=351, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 780CB21F29: from=<root@univ-ndere.edu.cm>, size=351, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 64CF921F25: from=<emafo@univ-ndere.edu.cm>, size=586, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: B3ABD21F2C: from=<zongo@univ-ndere.edu.cm>, size=454, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 5BC5F21F27: from=<root@univ-ndere.edu.cm>, size=351, nrcpt=1 (queue active)
Sep 14 15:45:43 mawi postfix/qmgr[28754]: 9C51521F2D: from=<root@univ-ndere.edu.cm>, size=350, nrcpt=1 (queue active)
Sep 14 15:46:10 mawi postfix/virtual[28757]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:46:11 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28757 exit status 1
Sep 14 15:46:11 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:47:11 mawi postfix/virtual[28785]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:47:12 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28785 exit status 1
Sep 14 15:47:12 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:48:12 mawi postfix/virtual[28792]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:48:13 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28792 exit status 1
Sep 14 15:48:13 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:49:13 mawi postfix/virtual[28793]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:49:14 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28793 exit status 1
Sep 14 15:49:14 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:49:35 mawi authdaemond: stopping authdaemond children
Sep 14 15:49:35 mawi authdaemond: modules="authldap", daemons=5
Sep 14 15:49:35 mawi authdaemond: Installing libauthldap
Sep 14 15:49:35 mawi authdaemond: Installation complete: authldap
Sep 14 15:50:14 mawi postfix/virtual[28843]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:50:15 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28843 exit status 1
Sep 14 15:50:15 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:51:15 mawi postfix/virtual[28844]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:51:16 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28844 exit status 1
Sep 14 15:51:16 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:52:16 mawi postfix/virtual[28845]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:52:17 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28845 exit status 1
Sep 14 15:52:17 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:53:17 mawi postfix/virtual[28846]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:53:18 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28846 exit status 1
Sep 14 15:53:18 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:54:18 mawi postfix/virtual[28874]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:54:19 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28874 exit status 1
Sep 14 15:54:19 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:55:19 mawi postfix/virtual[28894]: fatal: open /etc/postfix/ldap-accounts.cf: Permission denied
Sep 14 15:55:20 mawi postfix/master[3075]: warning: process /usr/lib/postfix/virtual pid 28894 exit status 1
Sep 14 15:55:20 mawi postfix/master[3075]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Sep 14 15:56:20 mawi postfix/virtual[28930]: 6A75A21F2B: to=<mzongo@univ-ndere.edu.cm>, relay=virtual, delay=87312, delays=86675/637/0/0.02, dsn=5.1.1, status=bounced (unknown user: "mzongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28929]: 4A29021F2A: to=<mzongo@univ-ndere.edu.cm>, relay=virtual, delay=87498, delays=86861/637/0/0.02, dsn=5.1.1, status=bounced (unknown user: "mzongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28930]: 64CF921F25: to=<mzongo@univ-ndere.edu.cm>, relay=virtual, delay=90591, delays=89954/637/0/0.02, dsn=5.1.1, status=bounced (unknown user: "mzongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28932]: 3F66621F28: to=<mzongo@univ-ndere.edu.cm>, relay=virtual, delay=89077, delays=88440/637/0/0.03, dsn=5.1.1, status=bounced (unknown user: "mzongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28933]: 780CB21F29: to=<mzongo@univ-ndere.edu.cm>, relay=virtual, delay=88284, delays=87647/637/0/0.03, dsn=5.1.1, status=bounced (unknown user: "mzongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28929]: 5BC5F21F27: to=<mzongo@univ-ndere.edu.cm>, relay=virtual, delay=90053, delays=89416/637/0/0.02, dsn=5.1.1, status=bounced (unknown user: "mzongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/cleanup[28940]: 4D6D521F32: message-id=<20110914145620.4D6D521F32@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/cleanup[28946]: 505F121F34: message-id=<20110914145620.505F121F34@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/cleanup[28949]: 522FA21F37: message-id=<20110914145620.522FA21F37@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/virtual[28935]: B3ABD21F2C: to=<jango@univ-ndere.edu.cm>, relay=virtual, delay=86063, delays=85426/637/0/0.03, dsn=5.1.1, status=bounced (unknown user: "jango@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28941]: 9C51521F2D: to=<jango@univ-ndere.edu.cm>, relay=virtual, delay=14262, delays=13625/637/0/0.02, dsn=5.1.1, status=bounced (unknown user: "jango@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/bounce[28934]: 6A75A21F2B: sender non-delivery notification: 4D6D521F32
Sep 14 15:56:20 mawi postfix/bounce[28937]: 4A29021F2A: sender non-delivery notification: 505F121F34
Sep 14 15:56:20 mawi postfix/cleanup[28946]: 537F221F39: message-id=<20110914145620.537F221F39@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/cleanup[28940]: 537BE21F38: message-id=<20110914145620.537BE21F38@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/cleanup[28950]: 5441E21F24: message-id=<20110914145620.5441E21F24@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 522FA21F37: from=<>, size=2146, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/bounce[28936]: 3F66621F28: sender non-delivery notification: 522FA21F37
Sep 14 15:56:20 mawi postfix/bounce[28943]: 64CF921F25: sender non-delivery notification: 5441E21F24
Sep 14 15:56:20 mawi postfix/bounce[28944]: 780CB21F29: sender non-delivery notification: 537F221F39
Sep 14 15:56:20 mawi postfix/bounce[28931]: 5BC5F21F27: sender non-delivery notification: 537BE21F38
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 6A75A21F2B: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 4A29021F2A: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 3F66621F28: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 64CF921F25: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 780CB21F29: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 5BC5F21F27: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 505F121F34: from=<>, size=2133, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 4D6D521F32: from=<>, size=2146, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 537BE21F38: from=<>, size=2146, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 5441E21F24: from=<>, size=2502, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 537F221F39: from=<>, size=2146, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/cleanup[28946]: 57FCE21F25: message-id=<20110914145620.57FCE21F25@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/cleanup[28950]: 57FE521F27: message-id=<20110914145620.57FE521F27@mawi.univ-ndere.edu.cm>
Sep 14 15:56:20 mawi postfix/virtual[28933]: 4D6D521F32: to=<root@univ-ndere.edu.cm>, relay=virtual, delay=0.06, delays=0.05/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "root@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28932]: 522FA21F37: to=<root@univ-ndere.edu.cm>, relay=virtual, delay=0.04, delays=0.01/0.02/0/0.01, dsn=5.1.1, status=bounced (unknown user: "root@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28930]: 505F121F34: to=<zongo@univ-ndere.edu.cm>, relay=virtual, delay=0.06, delays=0.05/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "zongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 4D6D521F32: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 522FA21F37: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 505F121F34: removed
Sep 14 15:56:20 mawi postfix/virtual[28941]: 537F221F39: to=<root@univ-ndere.edu.cm>, relay=virtual, delay=0.05, delays=0.03/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "root@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 57FE521F27: from=<>, size=2247, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/virtual[28935]: 537BE21F38: to=<root@univ-ndere.edu.cm>, relay=virtual, delay=0.05, delays=0.03/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "root@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28929]: 5441E21F24: to=<emafo@univ-ndere.edu.cm>, relay=virtual, delay=0.05, delays=0.03/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "emafo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/bounce[28943]: 9C51521F2D: sender non-delivery notification: 57FCE21F25
Sep 14 15:56:20 mawi postfix/bounce[28948]: B3ABD21F2C: sender non-delivery notification: 57FE521F27
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 9C51521F2D: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: B3ABD21F2C: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 57FCE21F25: from=<>, size=2141, nrcpt=1 (queue active)
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 537BE21F38: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 5441E21F24: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 537F221F39: removed
Sep 14 15:56:20 mawi postfix/virtual[28932]: 57FCE21F25: to=<root@univ-ndere.edu.cm>, relay=virtual, delay=0.03, delays=0.02/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "root@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/virtual[28933]: 57FE521F27: to=<zongo@univ-ndere.edu.cm>, relay=virtual, delay=0.03, delays=0.02/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "zongo@univ-ndere.edu.cm")
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 57FCE21F25: removed
Sep 14 15:56:20 mawi postfix/qmgr[28754]: 57FE521F27: removed
Sep 14 23:20:27 mawi postfix/smtpd[29321]: connect from unknown[77.232.1.125]
Sep 14 23:20:28 mawi postfix/smtpd[29321]: NOQUEUE: reject: RCPT from unknown[77.232.1.125]: 554 5.7.1 <new56@freemailhost.ru>: Relay access denied; from=<smtp2001soho@yahoo.com> to=<new56@freemailhost.ru> proto=SMTP helo=<195.24.195.186>
Sep 14 23:20:28 mawi postfix/smtpd[29321]: disconnect from unknown[77.232.1.125]
Sep 14 23:23:48 mawi postfix/anvil[29325]: statistics: max connection rate 1/60s for (smtp:77.232.1.125) at Sep 14 23:20:27
Sep 14 23:23:48 mawi postfix/anvil[29325]: statistics: max connection count 1 for (smtp:77.232.1.125) at Sep 14 23:20:27
Sep 14 23:23:48 mawi postfix/anvil[29325]: statistics: max cache size 1 at Sep 14 23:20:27
Cest vrai que je n’ai pas tout pris, mais il y a l’essentiel.
