Postfix refuse de recevoir mes mails
Je viens d’installer postfix + courier-imap sur mon serveur (Debian lenny), mais celui-ci rejette les mails qu’il reçoit.
extrait des logs de postfix :
Sep 14 11:23:45 r24242 postfix/smtpd[9536]: connect from smtp22.services.sfr.fr[93.17.128.11]
Sep 14 11:23:45 r24242 postfix/smtpd[9536]: NOQUEUE: reject: RCPT from smtp22.services.sfr.fr[93.17.128.11]: 554 5.7.1 <ctalpaert@numeriforge.com>: Relay access denied; from=<ctalpaert@sfr.fr> to=<ctalpaert@numeriforge.com> proto=ESMTP helo=<smtp22.services.sfr.fr>
Sep 14 11:23:45 r24242 postfix/smtpd[9536]: disconnect from smtp22.services.sfr.fr[93.17.128.11]
mon fichier /etc/postfix/main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
myhostname = mail2.numeriforge.com
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = mail2.numeriforge.com, localhost
#relayhost =
#mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
Merci pour vôtre aide précieuse.
Cédric
dans le mail
dans postfix :
donc si tu veux qu ele serveur accepte les maisl à destination de numeriforge.com ajoute ce domaien dans mydestination. sinon il pensera que c’est pour du relai et il va refuser.
Ça marche \o/
Merci beaucoup Thomas
j’ai oublié une virgule, mais si ça marche c’est que tu l’as corrigé.
