Quand j’ouvre une console, j’ai cette alerte :
bash: /home/ricardo/.bashrc: line 105: syntax error: unexpected end of file
Voilà le fichier concerné, auquel je n’ai jamais touché :
[code]# ---- language-env DON’T MODIFY THIS LINE!
umask 022
eval /usr/bin/dircolors
LESSCHARSET=‘iso8859’
if [ “$DISPLAY” ] ; then
PROMPT_COMMAND=‘echo -ne “\033]2;$LOGNAME@$HOSTNAME : $PWD\007\033]1;\007”‘
PS1=’\u@\h:\w$ ‘
LS_OPTIONS=’–color=auto’
LANG=‘ko_KR.eucKR’
XMODIFIERS=’@im=nabi
elif [ “${TERM:0:5}” = “linux” ] ; then
PS1=’\u@\h:\w$ ‘
LANG=‘C’
else
PS1=’\u@\h:\w$ ‘
LS_OPTIONS=’–classify’
LANG='ko_KR.eucKR’
fi
export PATH LANG LESSCHARSET XMODIFIERS
alias ls='ls $LS_OPTIONS’
alias l='ls $LS_OPTIONS -l’
alias la='ls $LS_OPTIONS -al’
alias jfbterm=‘LANG=ko_KR.eucKR /usr/bin/jfbterm’
#alias emacs=‘LANG=C emacs’
#alias telnet=‘telnet -L’
---- language-env end DON’T MODIFY THIS LINE!
~/.bashrc: executed by bash(1) for non-login shells.
see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
for examples
If not running interactively, don’t do anything
[ -z “$PS1” ] && return
don’t put duplicate lines in the history. See bash(1) for more options
export HISTCONTROL=ignoredups
check the window size after each command and, if necessary,
update the values of LINES and COLUMNS.
shopt -s checkwinsize
make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval “$(lesspipe)”
set variable identifying the chroot you work in (used in the prompt below)
if [ -z “$debian_chroot” ] && [ -r /etc/debian_chroot ]; then
debian_chroot=$(cat /etc/debian_chroot)
fi
set a fancy prompt (non-color, unless we know we “want” color)
case “$TERM” in
xterm-color)
PS1=’${debian_chroot:+($debian_chroot)}[\033[01;32m]\u@\h[\033[00m]:[\033[01;34m]\w[\033[00m]$ ‘
PS1=’${debian_chroot:+($debian_chroot)}\u@\h:\w$ '
esac
Comment in the above and uncomment this below for a color prompt
#PS1=’${debian_chroot:+($debian_chroot)}[\033[01;32m]\u@\h[\033[00m]:[\033[01;34m]\w[\033[00m]$ ’
If this is an xterm set the title to user@host:dir
case “$TERM” in
xterm*|rxvt*)
PROMPT_COMMAND=‘echo -ne “\033]0;${USER}@${HOSTNAME}: ${PWD/$HOME/~}\007”’
esac
Alias definitions.
You may want to put all your additions into a separate file like
~/.bash_aliases, instead of adding them here directly.
See /usr/share/doc/bash-doc/examples in the bash-doc package.
#if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
#fi
enable color support of ls and also add handy aliases
if [ “$TERM” != “dumb” ]; then
eval "dircolors -b"
alias ls=‘ls --color=auto’
#alias dir=‘ls --color=auto --format=vertical’
#alias vdir='ls --color=auto --format=long’
fi
some more ls aliases
#alias ll=‘ls -l’
#alias la=‘ls -A’
#alias l=‘ls -CF’
enable programmable completion features (you don’t need to enable
this, if it’s already enabled in /etc/bash.bashrc and /etc/profile
sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
[/quote]C’est qu’est-c’que j’fais : càd
Sur ce noyau, pas de problèmes en ce qui concerne cette alerte.
