Ppp instable
Bonjour à tous
Depuis que j’ai installé kdenetwork-manager pour gérer un dongle wifi ma connexion ppp (orange) n’est plus établie au boot. (j’ai désactivé kdenetwork au boot et débranché le dongle) :
[code]proliant:/etc/ppp# ifconfig
eth0 Link encap:Ethernet HWaddr xx.xx.xx.xx
inet adr:169.254.196.220 Bcast:169.254.255.255 Masque:255.255.0.0
adr inet6: fe80::21a:4bff:feb0:ffad/64 Scope:Lien
RX packets:101 errors:0 dropped:0 overruns:0 frame:0
TX packets:164 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8109 (7.9 KiB) TX bytes:20270 (19.7 KiB)
Interruption:17
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:264 errors:0 dropped:0 overruns:0 frame:0
TX packets:264 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:285818 (279.1 KiB) TX bytes:285818 (279.1 KiB)
ppp0 Link encap:Protocole Point-à-Point
inet adr:83.205.3.14 P-t-P:193.253.160.3 Masque:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:20 errors:0 dropped:0 overruns:0 frame:0
TX packets:15 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:3
RX bytes:2209 (2.1 KiB) TX bytes:1070 (1.0 KiB)
proliant:/etc/ppp# route -n
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
193.253.160.3 0.0.0.0 255.255.255.255 UH 0 0 0 ppp0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth0
proliant:/etc/ppp# ping 193.253.160.3
PING 193.253.160.3 (193.253.160.3) 56(84) bytes of data.
64 bytes from 193.253.160.3: icmp_seq=1 ttl=127 time=23.7 ms
64 bytes from 193.253.160.3: icmp_seq=2 ttl=127 time=24.9 ms
64 bytes from 193.253.160.3: icmp_seq=3 ttl=127 time=25.1 ms
^C
— 193.253.160.3 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2007ms
rtt min/avg/max/mdev = 23.727/24.594/25.156/0.648 ms
proliant:/etc/ppp# ping free.fr
ping: unknown host free.fr
proliant:/etc/ppp# /etc/init.d/networking restart
Reconfiguring network interfaces…Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/eth0/xx.xx.xx.xx
Sending on LPF/eth0/xx.xx.xx.xx
Sending on Socket/fallback
DHCPRELEASE on eth0 to 192.168.0.254 port 67
send_packet: Network is unreachable
send_packet: please consult README file regarding broadcast address.
Plugin rp-pppoe.so loaded.
done.
PING free.fr (212.27.48.10) 56(84) bytes of data.
64 bytes from www.free.fr (212.27.48.10): icmp_seq=1 ttl=119 time=34.0 ms
Quelque minute plus tard:
proliant:/etc/ppp# pon
64 bytes from www.free.fr (212.27.48.10): icmp_seq=1 ttl=119 time=34.7 ms
Merci pour vos suggestions
Aucun spécialiste réseau sur ce forum ou la question est mal posée ?
Change de fournisseurs d’accès, c’est de là que vient le problème :teasing-nutkick:
Plus sérieusement, ça vient du fait que ton interface “ppp0” est configurée à la place de “eth0”.
Donc :
On désactive l’interface “ppp0” :# ifdown ppp0puis on réinitialise “eth0” en la désactivant et la réactivant (je ne sais pas si c’est obligatoire mais “dans le doute, reboote” ^^ ) :[code]# ifdown eth0
ifup eth0[/code]et comme j’imagine que tu utilises le DHCP pour obtenir une adresse IP, on demande au serveur de nous en filer une :# dhclient
Ca devrait fonctionner.
Merci pour cette réponse mais j’avais complètement désinstallé network-manager entre temps et ça a remarché au boot suivant.
Pour info, voici la configuration gagnante:
[code]kmc@proliant:~/Desktop$ sudo ifconfig
eth0 Link encap:Ethernet HWaddr xx.xx.xx.xx.xx.xx
adr inet6: yyyy.yyyy.yyyy.yyyy.yyyy/64 Scope:Lien
RX packets:3562 errors:0 dropped:0 overruns:0 frame:0
TX packets:3477 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2968201 (2.8 MiB) TX bytes:553488 (540.5 KiB)
Interruption:17
RX packets:268 errors:0 dropped:0 overruns:0 frame:0
TX packets:268 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:285365 (278.6 KiB) TX bytes:285365 (278.6 KiB)
inet adr:z.z.z.z P-t-P:w.w.w.w Masque:255.255.255.255
RX packets:3517 errors:0 dropped:0 overruns:0 frame:0
TX packets:3403 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2873427 (2.7 MiB) TX bytes:455053 (444.3 KiB)
Résolution 2012 … :shhh:
1° ne jamais publier sur la toile mon IP et Mac !!!
[quote=“kmchen”]Merci pour cette réponse mais j’avais complètement désinstallé network-manager entre temps et ça a remarché au boot suivant.
eth0 Link encap:Ethernet HWaddr yy:yy:yy:yy:yy:yy
adr inet6: yyyy::yyy:yyyy:yyyy:yyyy/64 Scope:Lien
Interruption:17
inet adr:xxx.xxx.xxx.xxx P-t-P:xxx.xxx.xxx.xxx Masque:255.255.255.255
Corriges au plus vite … :016
ps: depuis ton premier post … :033
Chez moi, il y un moment que j’ai viré network-manager et sa clic …
P’tite recherche >>> ifplugd
# aptitude -s install ifplugd
