Dans /usr/share/doc/rssh/examples
j’ai trouvé un script nommé mkchroot.sh
Je ne sais pas s’il est utile ou s’il fonctionne car je n’y connait pas grand chose en script.
Apparement c pour créer un chroot avec sftp et scp mais je n’en sais pas plus.
Je le post quand même, ça peut être intéressant de savoir si quelqu’un là déjà testé.
[code]#!/bin/sh
mkchroot.sh - set up a chroot jail.
This script is written to work for Red Hat 8/9 systems, but may work on
other systems. Or, it may not… In fact, it may not work at all. Use at
your own risk.
fail() {
echo "`basename $0`: fatal error" >&2
echo "$1" >&2
exit $2
Initialize - handle command-line args, and set up variables and such.
$1 is the directory to make the root of the chroot jail (required)
$2, if given, is the user who should own the jail (optional)
$3, if given, is the permissions on the directory (optional)
if [ -z “$1” ]; then
echo “basename $0: error parsing command line” >&2
echo " You must specify a directory to use as the chroot jail." >&2
exit 1
fi
jail_dir="$1"
if [ -n “$2” ]; then
owner="$2"
fi
if [ -n “$3” ]; then
perms="$3"
fi
build the jail
now make the directory
if [ ! -d “$jail_dir” ]; then
echo "Creating root jail directory."
mkdir -p “$jail_dir”
if [ $? -ne 0 ]; then
echo " `basename $0`: error creating jail directory." >&2
echo "Check permissions on parent directory." >&2
exit 2
fi
fi
if [ -n “$owner” -a whoami = “root” ]; then
echo "Setting owner of jail."
chown “$owner” “$jail_dir"
echo " basename $0: error changing owner of jail directory.” >&2
exit 3
fi
else
echo -e "NOT changing owner of root jail. \c"
if [ whoami != “root” ]; then
echo "You are not root."
else
echo
fi
fi
echo "Setting permissions of jail."
chmod “$perms” “$jail_dir"
echo " basename $0: error changing perms of jail directory.” >&2
exit 3
fi
else
echo -e "NOT changing perms of root jail. \c"
else
echo
fi
fi
copy SSH files
scp_path="/usr/bin/scp"
sftp_server_path="/usr/lib/openssh/sftp-server"
rssh_path="/usr/bin/rssh"
chroot_helper_path="/usr/lib/rssh/rssh_chroot_helper"
for jail_path in dirname "$jail_dir$scp_path" dirname "$jail_dir$sftp_server_path" dirname "$jail_dir$chroot_helper_path"; do
echo "setting up $jail_path"
if [ ! -d "$jail_path" ]; then
mkdir -p "$jail_path" || \
fail "Error creating $jail_path. Exiting." 4
fi
done
cp “$scp_path” “$jail_dir$scp_path” ||
fail “Error copying $scp_path. Exiting.” 5
cp “$sftp_server_path” “$jail_dir$sftp_server_path” ||
fail “Error copying $sftp_server_path. Exiting.” 5
cp “$rssh_path” “$jail_dir$rssh_path” ||
fail “Error copying $rssh_path. Exiting.” 5
cp “$chroot_helper_path” “$jail_dir$chroot_helper_path” ||
fail “Error copying $chroot_helper_path. Exiting.” 5
identify and copy libraries needed in the jail
for prog in $scp_path $sftp_server_path $rssh_path $chroot_helper_path; do
echo "Copying libraries for $prog."
libs=ldd $prog | tr -s ' ' | cut -d' ' -f3
for lib in $libs; do
mkdir -p "$jail_dir$(dirname $lib)"
echo -e "\t$lib"
cp “$lib” "$jail_dir$lib"
done
done
echo "copying name service resolution libraries…"
tar -cf - /lib/libnss_compat* /lib/libnss_files* | tar -C “$jail_dir” -xvf - |sed ‘s/^/\t/’
copy config files for the dynamic linker, nsswitch.conf, and the passwd file
echo "Setting up /etc in the chroot jail"
mkdir -p "$jail_dir/etc"
cp /etc/nsswitch.conf "$jail_dir/etc/"
cp /etc/passwd "$jail_dir/etc/"
cp /etc/ld.* “$jail_dir/etc/”
echo -e "Chroot jail configuration completed."
echo -e "\nNOTE: if you are not using the passwd file for authentication,"
echo -e “you may need to copy some of the /lib/libnss_* files into the jail.\n”
set up /dev/log
mkdir -p “$jail_dir/dev”
echo -e "NOTE: you must MANUALLY edit your syslog rc script to start syslogd"
echo -e "with appropriate options to log to $jail_dir/dev/log. In most cases,"
echo -e “you will need to start syslog as:\n"
echo -e " /sbin/syslogd -a $jail_dir/dev/log\n”
echo -e "NOTE: we make no guarantee that ANY of this will work for you… \c"
echo -e “if it\ndoesn’t, you’re on your own. Sorry!\n”[/code]
