bon j’ai fais un tour dans syslog et voila la derniere ligne
pour ce qui est des fichiers de config les voici:
named.conf:
[code]// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian.gz for information on the
// structure of BIND configuration files in Debian, BEFORE you customize
// this configuration file.
// If you are just adding zones, please do that in /etc/bind/named.conf.local
// inclusion du fichier options
include “/etc/bind/named.conf.options”;
//inclusion du fichier de cle
include “/etc/bind/espada.cm-key”;
// canal de connexion et de communication
controls {
inet 127.0.0.1 port 953 allow { localhost; } ;
// prime the server with knowledge of the root servers
zone “.” {
type hint;
file “/etc/bind/db.root”;
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone “localhost” {
type master;
file “/etc/bind/db.local”;
zone “127.in-addr.arpa” {
type master;
file “/etc/bind/db.127”;
zone “0.in-addr.arpa” {
type master;
file “/etc/bind/db.0”;
zone “255.in-addr.arpa” {
type master;
file “/etc/bind/db.255”;
include “/etc/bind/named.conf.local”;[/code]
rndc.conf:
[code]# serveur et cle par defaut
options {
default-server localhost;
default-key “espada-key”;
NB: espda.cm-key est le fichier dans lequel se trouve la cle en question ecrit dans le style
key "espada.cm" {
algorithm hmac-md5;
secret "<cle secrete>";
j’esper que vous me debloquerer
!! a plus.
