Problème amavisd
Quand je lance amavis lorsq s’une installation toute fraiche il m’affiche :
/etc/init.d/amavis restart
Stopping amavisd: amavisd-new.
Starting amavisd: fetch_modules: error loading optional module Razor2/Client/Agent.pm:
  syntax error at /usr/share/perl5/Razor2/Client/Agent.pm line 539, near "fore!"
  syntax error at /usr/share/perl5/Razor2/Client/Agent.pm line 542, near "}"
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 544.
  syntax error at /usr/share/perl5/Razor2/Client/Agent.pm line 546, near "}"
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 548.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 549.
  syntax error at /usr/share/perl5/Razor2/Client/Agent.pm line 551, near "}"
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 556.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 557.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 558.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 563.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 564.
  Global symbol "$objects" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 570.
  Global symbol "$objects" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 572.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 585.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 591.
  Global symbol "$self" requires explicit package name at /usr/share/perl5/Razor2/Client/Agent.pm line 593.
  syntax error at /usr/share/perl5/Razor2/Client/Agent.pm line 599, near "}"
  /usr/share/perl5/Razor2/Client/Agent.pm has too many errors.
  Compilation failed in require at /usr/sbin/amavisd-new line 197.
Une personne à une idée ?
Aucune idée ?
Arg bizarre cette erreur alors que je ne modifie rien lors de l’installation.
Tu peux me redonner le lien de ton tuto ?
Je suis étonné, je n’ai rien vu au sujet de razor…
Il est ici :
probleme-postfix-t32828.html
C’est ça: serion.co.nz/content/howto-setup … amavis-new ?
Oui mais e pense que sous squeeze il y a des probleme avec les paquets ou les dependances !
Je pense que je vais reinstaller sous lenny !
Re,
Tu fais comme tu veux…
  1. Mais si tu réinstalle à chaque problème tu ne progressera pas (si c’est ce que tu souhaite);
  2. Lenny est la oldstable… Ce n’est pas une bonne idée de choisir cette branche;
  3. Le problème ne doit pas être si difficile à trouver… C’est amavis qui ne trouve pas un module razor…
Et je le trouve ou le module razor ?
La oldstable nest plus mise a jour ?
[quote=“prohand”]Et je le trouve ou le module razor ?
Merci[/quote]
Lenny est encore dans les dépôts bien sur, mais elle n’est effectivement plus maintenue.
Dans le tuto que tu as suivi:
Tu peux essayer ceci:
apt-get remove --purge razor apt-get install razor service amavis restart
Merci je n’est plus d’erreur sous amavis.
:smiley:
C’est quand même plus simple que de réinstaller non ?
Oui cest sur par contre jai aussi un probleme avec prewikka qui m’indique acces refusé mais bon cest un autre probleme
