Probleme apache2 debian
Bonsoir
Mon apache2 a planté et je n’arrive pas a le refaire fonctionné, il m’envoie comme message d’erreur :
ps :J’ai beau purgé et désinstaller, réinstaller, je n’arrive toujours pas.
-- Logs begin at Wed 2017-02-08 20:25:55 CET, end at Thu 2017-02-09 19:21:22 CET. --
Feb 09 19:20:51 osmc sshd[14705]: Received disconnect from 116.31.116.30: 11:  [preauth]
Feb 09 19:20:51 osmc apache2[14660]: Starting web server: apache2 failed!
Feb 09 19:20:51 osmc apache2[14660]: The apache2 instance did not start within 20 seconds. Please read the log files to discover problems ... (warning).
Feb 09 19:20:51 osmc systemd[1]: apache2.service: control process exited, code=exited status=1
Feb 09 19:20:51 osmc systemd[1]: Failed to start LSB: Apache2 web server.
-- Subject: Unit apache2.service has failed
-- Defined-By: systemd
-- Support: [url]http://lists.freedesktop.org/mailman/listinfo/systemd-devel[/url]
-- Unit apache2.service has failed.
-- The result is failed.
Feb 09 19:20:51 osmc systemd[1]: Unit apache2.service entered failed state.
Feb 09 19:20:53 osmc systemd[1]: Reloading.
Feb 09 19:21:08 osmc sudo[14146]: pam_unix(sudo:session): session closed for user root
Feb 09 19:21:22 osmc sudo[14771]: osmc : TTY=pts/0 ; PWD=/home/osmc ; USER=root ; COMMAND=/bin/bash
Feb 09 19:21:22 osmc sudo[14771]: pam_unix(sudo:session): session opened for user root by osmc(uid=0)
Et dans les logs par hasard tu n’aura pas le début de piste qu’il te manque ?
fichier error.log dans var est vide,
Loaded: loaded (/etc/init.d/apache2)
Drop-In: /lib/systemd/system/apache2.service.d
-forking.conf Active: failed (Result: exit-code) since Sat 2017-02-11 22:58:39 CET; 3min 36 s agoosmc@osmc:~$ Loaded: loaded (/etc/init.d/apache2) -bash: syntax error near unexpected token('
osmc@osmc:~$ Drop-In: /lib/systemd/system/apache2.service.d
-bash: Drop-In:: command not found
osmc@osmc:~$ `-forking.conf
